VWVortex.com - J519 Module Replacement
    Results 1 to 14 of 14
    Thread: J519 Module Replacement
    1. Semi-n00b
      May 8th, 2010
      Toronto, Ontario
      2010 Golf Wagon
      06-22-2010 09:19 AM #1
      I need to replace the J519 module in a 2010 JSW, Can I just copy the long code from the old module and paste it into the new one? Anything else I would need to do?
      Thanks in advance
      Brian
      Feb 11th, 2004
      Magdeburg, Germany
      '67 Ford Mustang Conv.
      06-22-2010 10:14 AM #2
      Which module is currently installed and why do you want to replace it? Mind posting an Auto-Scan from the vehicle in question? Copying the coding (and adaptation) values is indeed part of the replacement but in some cases you may need to make some additional adjustments.
    3. Semi-n00b
      May 8th, 2010
      Toronto, Ontario
      2010 Golf Wagon
      06-22-2010 10:40 AM #3
      I had a local garage install a controller for trailer, seems they used a non-powered version.
      As soon as they checked the brake lights, it fried the left brake light output of the J519. The dealer has confirm there is no output on the left brake circuit from the controller, right and center are still working.
      The replacement module was ordered from Germany, and I just noticed my VIN number is on the label on the box. Since the car is technically under warranty I am now wondering if they have pre-coded the module?
      Thanks again
      Brian.
      Autoscan is attached
      Tuesday,22,June,2010,09:27:26:03141
      VCDS Version: Release 908.2
      Data version: 20100326
      Chassis Type: 1K0
      Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 4F 52 56 62 72 77
      VIN:
      01-Engine -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: Malfunction 0010
      15-Airbags -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      1C-Position Sensing -- Status: OK 0000
      2E-Media Player 3 -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      46-Central Conv. -- Status: OK 0000
      4F-Centr. Electr. II -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door, Rear Left -- Status: OK 0000
      77-Telephone -- Status: OK 0000
      Address 01: Engine (CBT) Labels: 06A-906-032-BGP.lbl
      Part No SW: 07K 906 055 AJ HW: 07K 906 055 M
      Component: 2,5l R5/4V G 5782
      Revision: G6H04--- Serial number:
      Coding: 0000071
      Shop #: WSC 00066 000 00000
      No fault code found.
      Readiness: 1110 0101
      Address 03: ABS Brakes (J104) Labels: None
      Part No SW: 1K0 907 379 AH HW: 1K0 907 379 AH
      Component: ESP MK60EC1 H30 0107
      Revision: 00H30001
      Coding: 114B400C492A00FF880C02E992190041300000
      Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
      Part No SW: 3C8 907 336 AC HW: 3C8 907 336 AC
      Component: Climatic H14 0305
      Revision: 00009001
      Coding: 0000000002
      Shop #: WSC 00066 000 00149
      ASAM Dataset: EV_Climatic A01005
      ROD: EV_Climatic_VW36.rod
      Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
      Part No SW: 5K0 937 084 C HW: 5K0 937 084 C
      Component: BCM PQ35 B 011 0029
      Revision: BG011001
      Coding: 2D380E3F902F3EC400080081440000C401400086535D8D6064 8020000000
      Part No: 1K1 955 119 F
      Component: Wischer 21041 21 0512
      Coding: 009795
      Address 15: Airbags (J234) Labels: 5K0-959-655.clb
      Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
      Component: AirbagVW10G 021 0706
      Serial number: 003C4D0ASR6H
      Coding: 00003046
      ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
      ROD: EV_AirbaVW10SMEVW360_VW36.rod
      Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
      Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
      Component: J0527 056 0111
      Coding: 0000532
      Part No: 5K0 959 542
      Component: E221__MFL-TAS H05 0010
      Coding: 00000130
      Shop #: WSC 00000
      Address 17: Instruments (J285) Labels: 5K0-920-xxx-17.clb
      Part No SW: 5K0 920 870 F HW: 5K0 920 870 F
      Component: KOMBI H13 0112
      Revision: X0013004 Serial number:
      Coding: 370F00
      ASAM Dataset: EV_KombiUDSMM9RM10 A04102
      ROD: EV_KombiUDSMM9RM10.rod
      Address 19: CAN Gateway Labels: 1K0-907-530.lbl
      Part No SW: 1K0 907 530 AE HW: 1K0 907 951
      Component: J533 Gateway H06 0112
      Revision: H06 01 Serial number: 270310F2000244
      Coding: E9807F06001613002002
      Address 1C: Position Sensing Labels: None
      Part No SW: 5N0 919 879 HW: 5N0 919 879
      Component: Kompass 001 0001
      Revision: 00001000 Serial number: 1225223R7TWC05
      Coding: 0000002
      Address 25: Immobilizer (J334) Labels: 5K0-920-xxx-25.clb
      Part No SW: 5K0 953 234 HW: 5K0 920 870 F
      Component: IMMO H13 0112
      Coding: 000000
      Shop #: WSC 00000 000 00000
      ASAM Dataset: EV_ImmoUDSMM9RM10 A01102
      ROD: EV_ImmoUDSMM9RM10.rod
      Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
      Part No SW: 5N0 035 342 B HW: 5N0 035 342 B
      Component: SG EXT.PLAYER H13 0090
      Revision: A1001003 Serial number: 7667870192
      Coding: 010000
      Address 42: Door Elect, Driver
      Cannot be reached
      Address 44: Steering Assist Labels: 1Kx-909-14x.lbl
      Part No: 1K0 909 144 J
      Component: EPS_ZFLS Kl. 69 3001
      Revision: 00H17000
      Shop #: WSC 02069 000 90108
      Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.lbl
      Part No SW: 1K0 907 532 HW: 1K0 907 951
      Component: EZE_2 H06 0112
      Coding: 050B0500
      Part No SW: 8R0 959 591 A HW: 8R0 959 591
      Component: J245EE20SKB13 H01 0220
      Component: J394EE20SKB13 H01 0220
      Address 52: Door Elect, Pass.
      Cannot be reached
      Address 56: Radio (J503) Labels: 5M0-035-1xx-56.clb
      Part No SW: 1K0 035 180 AC HW: 1K0 035 180 AC
      Component: Radio Prem-8 H10 0035
      Revision: -----20S Serial number: VWZ4Z7K3073150
      Coding: 2100040004
      Address 62: Door, Rear Left
      Cannot be reached
      Address 72: Door, Rear Right
      Cannot be reached
      Address 77: Telephone (J738) Labels: None
      Part No SW: 1K8 035 730 D HW: 1K8 035 730 D
      Component: Telefon H08 6900
      Revision: 00008000 Serial number: 00000330656970
      Coding: 412100
      End ---------------------------------------------------------------------
    4. Former Advertiser
      May 27th, 2002
      06-22-2010 04:15 PM #4
      Hello
      More then likely not coded from OE but is possible.
      When transferring coding use the same data from old module.
      Make sure you set your con fig for WSC, equipment #, and importer # in options screen.
      Many modules will not allow coding if this is not present.
      If unsure use the ones you read in your car already to match the origin of the vehicle.
      Some modules will also request security access in some cases.
      If you see a box display like this contact customer support at Ross-tech.
      Be sure to write down any error or make a screen shot.
      Jack
      Feb 11th, 2004
      Magdeburg, Germany
      06-23-2010 10:31 AM #5
      Thanks for the scan and the explanation.
      When it comes to trailer retrofits you should go with the official kits, they come with proper wiring as well as additional control modules which provide the necessary functionality to the rest of the car/control modules. Based on the description it sounds indeed like something went wrong with their installation, haven't seen a BCM going bad that way but there is always a first time for everything.
      Quote Originally Posted by bgraham View Post
      In some cases the coding is indeed being done automatically but those cases are rare. Whats most likely the case here that the module has gotten a vehicle specific parameter setting which has a similar function as the coding but isn't entirely the same. In any case you should double check the coding and if necessary put in the value from the original module, a security access should not be necessary in this particular case.
      As a side note, you should use the latest Beta version of VCDS for MY 2010 and newer.
    6. 06-25-2010 08:00 AM #6
      My 2009 103TDI Golf VI had its Central electrics control unit (J519) replaced today.
      Drove it home and found I could not lock/unlock the doors with the remote control key fob.
      The car's manual has instruction for resynchronising the keys to the central locking (pop cap off handle on door to expose keyslot, press unlock on fob, within 1 minutes manually unlock car, key is then reprogrammed).
      Only one problem ... it does not work.
      Any hints?
      Feb 11th, 2004
      Magdeburg, Germany
      06-25-2010 08:16 AM #7
      The synchronisation only works if you had the remotes previously matched to this specific car/control module, so what you have to do here is match the remotes to begin with. Here's how you do it...
      VCDS > Select > 09 - Central Electronics
      > Adaptation - 10
      > Channel 001
      Enter the number of keys you want to match/adapt, e.g. 2.
      > Test/Save the new value.
      Now press and hold the OPEN button on the remote for 1 second, you should see the blinkers light to confirm the adaptation. Repeat this for your additional keys but make sure that the entire process does not exceed 15 seconds.
    8. 06-25-2010 08:39 AM #8
      Thanks. I presume this must be done by the dealer, not the owner?
      Feb 11th, 2004
      Magdeburg, Germany
      06-25-2010 08:43 AM #9
      Since this is the VCDS forum, if you have a VCDS system you can do it yourself. If you don't, the dealer is your best choice.
    10. Member
      Feb 18th, 2002
      OH
      2017 GTI
      06-25-2010 04:18 PM #10
      I replaced mine with a high line version. I just cut and paste the coding back in. There were a couple of hiccups:
      The remotes for the car had to be re-adapted. The procedure didn't seem any different from the MKV procedure, but the module was delivered in "factory mode". You can't adapt remotes until factory mode is turned off. You can change it in adaption channel 19.
      The TPMS coding was reset to 000000. My original coding was 018705. Also the minimum tire pressure level was set to 5.5 bar. I believe the correct value is 2.3 bar.
    11. Semi-n00b
      May 8th, 2010
      Toronto, Ontario
      2010 Golf Wagon
      06-25-2010 10:57 PM #11
      Quote Originally Posted by aenea View Post
      Replaced my module this afternoon, copy and pasted the long code fine.
      Had the same issues as above, also the sunroof stopped working. That was bit scary, had to open the 4F module and use basic settings to turn it back on.
      Thanks everybody for the help.
      Brian
    12. Semi-n00b
      May 8th, 2010
      Toronto, Ontario
      2010 Golf Wagon
      06-28-2010 12:46 PM #12
      Does anybody know the pin number arrangement on the J519 module?
      This version has 3 connectors labeled A, B and C, however there is no marking for pin1 etc.. and my Bentley manual does not show the pin number arrangement.
      Thanks Brian
    13. Member
      Feb 18th, 2002
      OH
      2017 GTI
      06-28-2010 02:13 PM #13
      There's a picture here:
      http://forums.tdiclub.com/showthread...=265887&page=4
      The pin numbers are marked on the connector. You have to take the shell off to see them.
    14. Semi-n00b
      May 8th, 2010
      Toronto, Ontario
      2010 Golf Wagon
      06-28-2010 08:05 PM #14
      Perfect thanks a lot.
      Brian
