VWVortex.com - MK1 Golf Four Wheel Drive with MK5 R32 Turbo Lump (Under Construction)
    Page 5 of 9 FirstFirst 123456789 LastLast
    Results 101 to 125 of 217
    Thread: MK1 Golf Four Wheel Drive with MK5 R32 Turbo Lump (Under Construction)
    1. 08-19-2010 06:09 AM #101
      [QUOTE=MikkiJayne;67014235]Entirely possible - I've already done it:
      There are also two other Corrados with Porsche-based drivetrains - one with a 1.8T and one with a 16V. There are a couple of Porsches with Audi engines too [/QUO
      Really!?
      Do you know where I could find some pictures and/or info on how this was done?TE]
    2. 08-19-2010 10:11 AM #102
      Decided to tackle the brakes this weekend. I have to replace the existing ones as they got cut whilst the back axle was being put in.
      Got some copper pipes to make up my own.
      Copper pipe
      I took off the old ones and followed the bends with the copper so it fits underneath the car the first time.
      I didn't get the flaring tool from my mate in time so I fitted the newly made lines in a view to flare the ends retrospectively. Gave the line a bit of extra length so I don't come up short when the transfer pedal, servo and master cylinder goes back in.
      Fitted copper brake line (extra long)
      I still haven't fitted a throttle body as I was gonna use the 2.9 VR6 one with an adapter plate. A little birdie tells me I can modify the old R32 throttle body to take a throttle cable. I'll experiment with that on the weekend.
      I'm gonna use a MK2 Golf servo and master cylinder instead of the MK1 Golf stuff as I'm told this will provided better braking and I had one siting in the garage anyways. I dismantled the old tranfer pedal set up, cleaned it up and had it sprayed so it looks a bit better than before. Sprayed the servo too but might change the colour to match the engine bay. I'll fit all that on the weekend.
      brake set up with Mk1 Golf RHD transfer pedal, 1.8 16v Mk2 Golf servo and master cylinder
      1.8 16v Mk2 Golf master cylinder
      Had to run the rear right hand side line up in the section where the tank will be as the tunnel and the prop are in the way of where it would normally run. When i get the car jacked up high enough, I get some pictures.
      Speaking of tanks, I got the BMW E30 one I chopped up early back from the welders. It just needs to be pressure tested then i'll fit it on the car with a couple of straps from the original MK1 Golf. Here are a few pics of the welding job.
      BMW E30 petrol tank modified to fit the Mk1 Golf with rallye back axle set up.
    3. 08-19-2010 10:16 AM #103
      Does anyone have a VR6 or R32 in a MK1 Rabbit/Golf?
      How does it handle??
    4. Member 1.8TRabbit's Avatar
      Nov 15th, 2004
      Garage in the Rockies
      82 Rabbit 1.8L, 84 Rabbit GTI 20vBT, 86 Audi 4000Q, 96 Audi A4Q V6, 02 Audi A4 1.8T,06 BMW 325I
      08-19-2010 10:27 AM #104
      Quote Originally Posted by mymotown View Post
      Tons of people have done that swap. Just check out the VR6 technical section. As far as how they handle? Not from my personal experience but hear all the time that you do feel the extra weight in the front while driving. A respective suspension would accommodate most of those issues though.
      Dwight D. Eisenhower: “If you want total security, go to prison. There you’re fed, clothed, given medical care and so on. The only thing lacking… is freedom.”
    5. 08-19-2010 11:05 AM #105
      Quote Originally Posted by 1.8TRabbit View Post
      Sweet, thanks man. I'll check out the VR6 technical. The issue is I have Mk1 front suspension on the front and MK2 rallye on the back, so its difficult get a set without buying two pair. Got some decent ones on the front but I might have to buy a whole set to get the back syncro ones. Might just go with shocks and uprated springs as suppose to coilovers on the back.
      Front coilovers
    6. 08-19-2010 11:23 AM #106
      drive this car already. cant wait to see it done
    7. 08-19-2010 11:30 AM #107
      Quote Originally Posted by mafosta View Post
      I know man. I gotta work full time 9-5. I only ever get to work on this car on the weekends. But i'm getting there. Might have the engine turning over in about 3 weeks or so, but don't quote me on that.
      Thanks for the encouragement tho.
    8. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      D2 S8, B5 A4 V8
      08-20-2010 06:57 AM #108
      I'm pretty sure the Rallye / Syncro uses mk1 rear shocks as they are shorter than the mk2 ones. Not sure how that would translate to a syncro in a mk1 - possibly they would need to be even shorter still Mk1 coils ought to bolt up, but whether they would go low enough I don't know...
      Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
      Quote Originally Posted by shwak23 View Post
      You could always call your insurance and say that some vandals tried to swap your car to rwd while you weren't looking.
    9. 08-20-2010 08:26 AM #109
      Quote Originally Posted by MikkiJayne View Post
      Got a set of MK1 coilies on the car right now. The back is higher than Amy Winehouse. I think I'm gonna need rallye ones. They've got to be a lot shorted.
    10. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      D2 S8, B5 A4 V8
      08-20-2010 11:01 AM #110
      Lol!
    11. Member syracusegli's Avatar
      Jan 21st, 2005
      syracuse, NY
      project central
      08-20-2010 11:03 AM #111
      wow. awesome
      watching this thread
      Quote Originally Posted by 2mAn View Post
      go crash into a hybrid
      For powder coating and fabrication ---> www.roguemetalworks.com
      IG- Roguemetal
    12. Member polov8's Avatar
      Apr 14th, 2004
      United kingdom of Awesomecestershire
      '02 BMW 530d sport touring, '83 BMW E21 316
      08-20-2010 03:40 PM #112
      compared to a 2wd mk2 Golf, the syncro/rallye rear shocks are shorter, coincidentally all but identical in length to a mk1 shock, so, to fit your rear end, you need shocks that are a similar amount shorter AGAIN< as a mk1 shock is in comparison to a mk2.
      I can measure that if you want?
    13. 08-24-2010 04:48 AM #113
      Quote Originally Posted by syracusegli View Post
      wow. awesome
      Thanks man!
    14. 08-24-2010 05:01 AM #114
      Quote Originally Posted by polov8 View Post
      O right. Thanks for the offer but I think I'll hunt down a set rallye back ones. They'll be the right ones. I've seen a few rallyes on the deck so they are out there.
      Really don't wanna buy a whole kit just for the back ones tho. Anyone know where I could find just a pair for the rear only?
    15. 09-01-2010 10:01 AM #115
      Last weekend was a wash out. Didn't get a thing done. We had to transplant a whole paint booth across the yard. That pretty much took up the whole day. But I made of it this weekend.
      So I've pretty much finished up the brakes at this point. Needs brake fluid and bleeding but that a minor issues. I'll be getting a set of hand brake cables this weekend so I can strike the brakes off the to-do list.
      Finally managed to get my hands on a flaring tool for the copper brake lines. Little John kindly volunteered his kit for a weekend. Nice and easy to use as you don't need a vice.
      Leaving off from the last point of the build, I fitted the overly complicated transfer pedal assembly that comes on the right hand drive Mk1 Golfs/Rabbits. I would of loved to run a brake bias system like the one below that's on my ABA 82' Golf/Rabbit but I wanted to have a servo. I could have used a remote servo but it just seemed like it would complicate the build even more. Plus remote servo kit is like £100.00. That could go towards a custom exhaust system instead.
      MK1 Golf ABA Bias Brakes set up
      Remote Servo
      MK1 Golf with hidden remote servo.
      I flared all the brake line ends under the car and connected them to the lines that come from the brake calipers. Since I'm using a rallye back axle I didn't have to convert the rear brakes from drums to discs as the axle already had it. The copper is so easy to bend so there were no dramas with connecting the lines. I'll get some pictures of that on the weekend.
      Once all the transfer pedal assembly was fitted, I flared the ends of the copper lines and connected them. I made a rookie mistake and forgot to slip on the male connector to join the copper line to the master cylinder so had to cut the line down a couple times after I'd already flared the end. Good think I left a little extra length o the lines.
      Flaring the Copper Lines
      Flared copper line end with Male connector
      Finished product with staggered rear break compensators
      http://lh4.ggpht.com/_IgrVRumxPq8/TH...742%5B1%5D.jpg
      Finished Product - MK2 Golf 16v master cylinder and servo with MK1 Golf transfer pedal setup.
      Also managed to tackle that R32 throttle body and convert it from fly by wire to cable. Wasn't as bad as I thought it would be.
      First step was to strip down the R32 throttle body by taking the black plastic housing off and remove the original spindle to disconnected the motor inside the throttle body. Won't be needing that. A pair of pliers and some gentle persuasion and spindle was off.
      R32 Throttle body with the spindle bent out the way.
      R32 Throttle body with the spindle removed
      The white sprocket that connects the electric motor to the throttle body just slides off once the spindle is removed.
      Spindle and sprocket removed from the R32 Throttle body.
      Next step was to find a donor throttle body to get a spindle off of that is cable operated. A 1.8 8v Mk2 Golf engine that we had laying around came in handy for this part.
      Mk2 Golf 1.8 8v donor engine with throttle spindle.
      Mk2 Golf 1.8 8v throttle spindle.
      One 11mm bolt and a large screw driver later and the part i needed was off.
      The two little legs on the spindle aren't needed so I shaved those off.
      Mk2 Golf 1.8 8v throttle spindle with legs to be chop off.
      Shaved down Mk2 Golf 1.8 8v throttle spindle
      Going back to the R32 throttle body, the pin that the sprockets sits on needs to be cut away to allow full movement of the spindle.
      Sprocket pin chop off
      The spindle can now be put in place of the original spindle that was removed earlier. There are probably a few different ways of fitting the spindle to the butterfly pin, but I opted for the more permanent solution. The welding option. VW Sam wasted no time. More pictures to follow.
      Butterfly pin that 1.8 8v spindle will be welded to.
      The blue wires go to the throttle position sensor so I don't need to incorporate one of those.
    16. Member vwovw's Avatar
      Apr 1st, 2004
      IOWA
      09-01-2010 10:22 PM #116
      great job!!
    17. 09-02-2010 04:19 AM #117
      Quote Originally Posted by vwovw View Post
      great job!!
      Thanks man.
    18. 09-10-2010 09:51 AM #118
      Another weekend spent doing not much on the car at all. Petrol tank is waiting to be pressured test and the radiator core was put on the wrong way around and got damaged when the guy tried to swap it round again.
      The car is going back to the fabricators to have the haldex system put in in two weeks time so i'm hoping to have the tank and rad in place by then along side other bits a pieces.
      Last time I was just finishing off the throttle body mod. CARL the man with the plan gave me all the info I needed to get it done. (I own you big time man). I had some issues with the mod but he helped figured them out.
      R32 throttle body converted to run a throttle cable
      With the 1.8 8v spindle welded on, the case no longer fit so I'll have to get something fabricated. I'll use this set up for now until i get a spare throttle body that i can perfect with a custom spindle.
      Edition 38, one of the England's biggest show and shine events was on the Sunday so I didn't get much done then either. This was my favourite car of the show.
      Edition 38 2010
      Edition 38 2010
      Edition 38 2010
      I managed to pick up some 25mm spacers from the show, so the Borbet A's can go back on the car.
      25mm 4x100 spacer
      25mm 4x100 spacer
      25mm 4x100 spacer
    19. Member
      Jun 14th, 2001
      Music City USA
      79 Scirocco 82 Rabbit Truck 85 Golf D 87 GTI 97 Passat TDI 03 TT
      09-12-2010 10:04 PM #119
      Awesome build. 2 questions:
      is copper strong enough for brake lines?
      on the drivers side motor mount did you have to only remove the original mount for enough clearance or did you have to narrow the framerail as well? IF so how much did you have to trim off?
    20. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      D2 S8, B5 A4 V8
      09-13-2010 07:21 AM #120
      Copper is pretty much the standard DIY stuff for making replacement brake lines. It is here in the UK anyway. You can get Kunifer as well (copper/nickel alloy) but thats harder to flare and bend so not as common for DIY.
    21. 09-13-2010 01:47 PM #121
      Quote Originally Posted by antichristonwheels View Post
      Hi,
      I believe the only time you'd ever have a problem with copper lines are if they are on a moving joint. I have a flexi section of braided hose on the rear arms where I'm likely to have any movement.
      Copper brake like with flexi section.
      We've you'd copper lines on other builds and they are still going strong years later.
      The exiting mounts were removed as I wasn't intending to use them and I didn't want them getting in the way. (some VR6 builds use the existing mounts but I guess i just took the easy way out) There was no need to narrow the framerails on the car. The R32 engine with the mounts attached drop right in with the modification as show below.
      We lowered the engine into the bay and eye up roughly the best position that would allow the drive shafts to best run in their intended position.
      Initial installation of the engine.
      The belt side was fairly easy to mount. We just shaved the raised ridge on the suspension leg away to allow the mount to sit flush in this position. We moved the mount as close to the suspension leg bulk head as possible. (this would have to be cut into the bulk head once the gearbox mount was in place to get the engine to line up straight horizontally.)
      ................cut into the bulk head once the gearbox mount was in place to get the engine to line up straight.
      On the gearbox side we cut a section out of the chassis leg the same width as the mount just leaving the base and back section of the leg. This cut was made from just after the suspension leg bulk head. This is a really crude drawing, hope it helps.
      Picasso version of the modified mounting position on the gearbox side
      ...........cut was made from just after the suspension leg bulk head
      The alternator was hitting the front panel so a section of that got cut out also.
      ............alternator was hit the front panel so a section of that got cut out also
      With the 20v engine I wouldn't worry the belt side mount. You can use a Rabbit GTI engine mount. This should bolt directly to the block as mount like a normal Rabbit GTI engine.[/QUOTE]
    22. Member
      Jun 14th, 2001
      Music City USA
      09-13-2010 10:21 PM #122
      yea, I forgot my buddy with the old British sporting tractors uses copper on restorations. Steel is pretty standard here but I can see how copper would be easier to deal with. I have a PD 150 going into a 79 Scirocco if my shop ever gets the trans ready... I need to do the same MK4 belt side mount that you used. So this makes me feel better, just trim off the factory mount and reinforce the top of the frame rail with a steel plate. We were worried about cutting the side out and thinning the rail. Your pics and answers are a big help. I have a WRD 02A trans mount and I think with only A/C and an alternator I may not have to notch the front, but my shop has done it already on a couple swaps.
    23. 09-15-2010 12:11 PM #123
      Yep, the copper will do the trick nicely, and its really easy to manipulate so no bending tool required. I think if I was to start over on this project I'd mount the engine MK3 Golf style. Would like a lot nicer. O well.....
      Good luck with your project man.
    24. 09-15-2010 01:25 PM #124
      Another weekend of getting busy doing nothing. Was hoping to have the radiator and petrol tank in place so I could complete the plumbing and run the fuel line. No joy, as neither were ready. Got a call from the rad guy. He had to make custom ends to make the whole thing work. I'll post picture when I pic it up on Friday. Might get my tank then too. (fingers crossed)
      The car needs to be sent back to Xport racing to get the Haldex put in place, so the wheels got put back on in preparation for the journey. Junior, who's build a similar beast came down to lend a hand, share some ideas and help figure out the Amy Winehouse issue.
      Front wheels back on car 25mm with spacers.
      Loads of clearance for the Wilwoods.
      The Amy Winehouse issue. (High as a kit)
      It turns out Mk1 Golf/Rabbit rear suspension legs are exactly the same length as Mk2 Golf Rallye/Syncro ones. I'll need to find another solution to get the car to have a some what normal stance.
      MK1 Golf rear suspension leg (yellow) and MK2 Golf Rallye rear suspension leg (blue)
      Junior suggested we take the helper spring off and fit the leg on the car, but that didn't change much. Good suggestion tho. I've been looking on Ebay and found a set of Gaz rear coilovers from a Vauxhall Nova that i've been told are 17.5 inches long compared to the 21 inches of the mk1 Golf ones. They also wind down all the way to the base of the shock. I'm pretty sure this will do the trick if I can get the top mounts to work on the MK1 Golf.
      Vauxhall Nova
      Vauxhall Nova rear coilovers.
      .......also wind down all the way to the base of the shock
      ...... if I can get the top mounts to work on the MK1 Golf.
      I'm open to ideas if anyone knows of a tried and tested method of sorting out the rear ride height. Thanks.
    25. 09-16-2010 12:49 PM #125
      Good work dude By the way it's Junior
      Just found this on the GAZ site and they are based in Essex
      GAZ GOLD (from the image posted they look to be this option)
      Gaz Gold height adjustable kits are a premium range of suspension units designed for tarmac motorsport and the serious track day enthusiast.
      Most of the GHA Listings are available in the Gold range with the addition of struts kits for the classic and retro car market i.e. Lotus, Cortinas, Escort, Mexicos, Capris, Lancia Intergrale and Evo‘s.
      The features are:-
      1. Front and rear units adjust bump and rebound from a single control knob on the side of the unit.
      2. Struts and semi struts have 62mm bodies for increased oil capacity. These units are fitted with 22mm diameter induction hardened piston rods that are hard chrome plated for strength and durability.
      3. All units have multi lip sealing. The outer seal is a metal encased wiper to clean the piston rod. This in turn extends main seal performance and oil retention under extreme conditions.
      4. All the Gold range are fitted with a gas cell in the outer reservoir and filled with a high viscosity index multi grade oil to prevent cavitation and reduce fade in motor racing conditions.
      5. The coilovers and telescopic units in this range utilise lightweight billet alloy components where possible, i.e. bases, end fittings, seats, lockrings, rod guides and gland nuts. The outer tube is steel with a nickel coating to provide the best anti corrosive finish possible. All outer alloy components are anodised.
      6. A full range of springs are stocked at the factory for road and motorsport use.
      All units in our ranges can be purchased individually or repaired by return in the event of an accident.
