Page 6 of 6 FirstFirst ... 2 3 4 5 6
Results 176 to 200 of 200
Thread: No good head units for Corrado..
  1. Moderator Krazee's Avatar
    Jan 25th, 2003
    En Why Sea
    Blog Entries
    9
    Corrado
    02-07-2012 10:48 AM #176
    Quote Originally Posted by LBSOHK View Post
    Any specific model?
    Im clueless on how much power it should have, and if I need 2 or 4 channel.
    If my fleeting audio memory hasnt failed me, I'd opt for a 400/4 (100amps per channel, 4 channels). Run all speakers off the amp, leaving the 4th input for a possible sub. Ensure the amp outputs are RMS rated, rather than peak, so you don't strain the amp.
    Project Corrado RS: Keep Up
    MSD 12v VR6 coilpack setup/components For Sale: Here
    Other items for sale: Sparco, VR6 HVAC box, VR6 radiators, Mocal Oil Cooler: Here
  2. Member G60ING's Avatar
    Jun 27th, 2000
    Northern MX
    TDI Corrado & Honda Refrig
    04-18-2012 04:39 PM #177
    Quote Originally Posted by G60ING View Post
    Becker has some nice head units. Some are available in green.
    I like the look of that CD Jetta one. is it a non-aktiv?
    It had blue and red lighting that matched the mk4 instrument cluster perfectly.
    my current corrado tdi's head unit (from a mk3 jetta tdi so it has green lighting that matches the stock green lighting perfectly):
    for those that are oldschool in your headunit desires:
    http://www.etkashop.com/vwcp/lost-an.../CD-Radio.html
    I just ordered two thru Zeb at www.1stvwparts.com They came out to roughly $130 shipped for two. I had seen these listed on overlandparts' catalog for $30 but they weren't able to get them. Overlandparts listed them as mk3 so I hope the display is green. Hopefully in two weeks I'll be able to tell you the results.
  3. Moderator Krazee's Avatar
    Jan 25th, 2003
    En Why Sea
    Blog Entries
    9
    Corrado
    04-18-2012 04:46 PM #178
    Just sold one at Show & Go. Mine was from VW South America, and I believe it was blue.
  4. Member G60ING's Avatar
    Jun 27th, 2000
    Northern MX
    04-18-2012 04:53 PM #179
    You can't always tell from the the look of the face. Look at my mk3 cassette headunit. 99% of VW people would guess its blue and red.
    even if it is blue & red I should be able to sell them
    Quote Originally Posted by Krazee View Post
  5. Member G60ING's Avatar
    Jun 27th, 2000
    Northern MX
    05-05-2012 09:31 AM #180
    Krazee you were 100% correct, Its blue and red but I might try having a friend convert it to green.
  6. Member 20v GTI Guy's Avatar
    Aug 20th, 2001
    Jacksonville, FL
    02 TT Quattro gt3076r, 92 Corrado, 93 Corrado, 11 Jetta TDI, 07 Tundra
    05-05-2012 10:59 AM #181
    I bought a 2001 gti and it came with that head unit in it. It wasn't until 2002 they went to the double dins.
  7. Member G60ING's Avatar
    Jun 27th, 2000
    Northern MX
    05-05-2012 01:18 PM #182
    Quote Originally Posted by 20v GTI Guy View Post
    I've never seen a stock us spec mk4 with a single din CD headunit unless it was the add-on with just the CD and the a single din radio/cassette. I thought all of them came with a cassette and then a cassette and cd when they went double din.
  8. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    93' SLC VR6 90' G60 99' Jetta
    05-05-2012 01:23 PM #183
    Not really period correct but This is the route i'm going and as you can see, I have a few to choose from
    [B] INSTAGRAM: europeein
    Facebook: facebook.com/addmichael
  9. Member Nightfox's Avatar
    Nov 6th, 2003
    Beaverton, OR, USA
    2009 VW Rabbit
    05-06-2012 12:47 PM #184
    After seeing this thread yesterday, I've been looking for something similar for my Corrado. This one doesn't have USB and not sure about the preamp, but this one is supposedly Blaupunkt/VW and has the black OEM look:
    http://orientalparts.com/VW-Blaupunk...-P2207964.aspx
    And this is the image they have:
    I'm thinking about buying one of these for my Corrado, but one thing I worry about is that it sounds like they don't sell the wiring harness with it. Their page says "Fit most VW with factory pre-wired standard ISO harness". My Corrado has an older Sony stereo in it, so I imagine it has a wiring harness that's not compatible with this stereo.
  10. 05-06-2012 09:29 PM #185
    "You can take my Corrado when you pry it from my Cold Dead Hands".
    http://corradodatabase.com/index.php...orrado&id=4617
  11. Member
    Dec 22nd, 2006
    Portland, OR
    '02 VW Eurovan GLS
    05-29-2012 05:18 PM #186
    Checking... does this radio play MP3's? The (similar) one shown by -skidmarks- does... but this one is cheaper!
  12. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    05-29-2012 09:25 PM #187
    That mp3 player looks like it has a normal cd slot??!
  13. Member Nightfox's Avatar
    Nov 6th, 2003
    Beaverton, OR, USA
    2009 VW Rabbit
    05-29-2012 09:28 PM #188
    I have a head unit for sale. I bought it intending to have it installed in my Corrado but decided to go with another one instead. My ad:
    http://forums.vwvortex.com/showthrea...3-1-DIN-stereo
  14. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    05-29-2012 09:31 PM #189
    Quote Originally Posted by Nightfox View Post
    I quoted the wrong post and the link finally worked. Is that a cd slot???
    Sent while sitting on my ass VIA my iPad
  15. Member Nightfox's Avatar
    Nov 6th, 2003
    Beaverton, OR, USA
    2009 VW Rabbit
    05-29-2012 09:39 PM #190
    Quote Originally Posted by HavokRuels View Post
    Yes, it's a CD slot.
  16. Member Non_Affiliated's Avatar
    Feb 12th, 2002
    Hola Bitchola WA.
    '91 MKIII Scirrocco, '78 SuperCab F-150 Quattro with 460 Cu. In. Of Eco terror.
    05-30-2012 07:41 PM #191
    I'll take the 2 pull out units on the bottom. Bottom looks like a 7280, Second from bottom looks like a 7290, or 7293.
    The other three look of the 7903, 7904 Versions.
    We're the middle children of history, man. No purpose or place. We have no Great War. No Great Depression. Our Great War's a spiritual war... our Great Depression is our lives. We've all been raised on television to believe that one day we'd all be millionaires, and movie gods, and rock stars. But we won't. And we're slowly learning that fact. And we're very, very pissed off.
  17. Member cyrus88's Avatar
    Feb 13th, 2008
    Long Island, New York
    comic green nose candy
    05-31-2012 02:30 AM #192
    Google Parrot asteroid
  18. Member HavokRuels's Avatar
    Jan 9th, 2011
    Rhode Island
    06-02-2012 03:27 PM #193
    Quote Originally Posted by Non_Affiliated View Post
    Tape decks are 7179, 7392s (cd changer equipped)
    Slide out cd are 7903's
    And fixed cd is 7904
  19. Member Tk2g60's Avatar
    Aug 26th, 2010
    Eastern PA
    1993 vr6 Corrado, 04 Frontier crewcab/ 2000 vr6 jetta(sold), 1991 g60(sold); 93 BMW 318ti(sold)
    08-12-2012 10:36 PM #194
    Quote Originally Posted by ZEBLOR View Post
    You gotta pay to play my friend
    WTB: Estyles Headers
    My build thread-->The NeverEnding Story
    If you live in PA and own a Corrado click here-> Pennsylvania's Corrado's
    Shop Spoonfed Tuning for your Corrado essentials
  20. Member TheBurninator's Avatar
    Jan 7th, 2009
    Colorado
    Corrado, Mk1, LG5U Mk3
    08-13-2012 07:19 PM #195
    Extremely difficult to find
    SPOONFEDTUNING - For all of your carbon fiber Corrado needs.
    Quote Originally Posted by ein View Post
    * IMPORTANT* The English language is completely inadequate for describing how spectacularly stupid this thread is.
    Quote Originally Posted by dogger View Post
    Is society really getting dumber or is it just this forum?
  21. Member Nightfox's Avatar
    Nov 6th, 2003
    Beaverton, OR, USA
    2009 VW Rabbit
    08-13-2012 10:08 PM #196
    That isn't difficult to find - you can order those from the web site in the link I shared along with the picture.
  22. Member onavarro8's Avatar
    Oct 3rd, 2006
    Washington
    VW Corrado VR6 '93
    08-14-2012 12:49 AM #197
    One more vote for an alpine deck. The green lights match with the dash.
    Photobucket
    Photobucket
  23. Member turtledub's Avatar
    May 10th, 2006
    1990 20v Corrado(soon), 2001 Outback 250k strong!
    09-26-2012 02:54 PM #198
    I might be on the hunt for a new stereo. Anyone else have a suggestion?
    Women are gentle and soft, but they hit things...
    20v AEB Corrado Build thread.
    Parting a B4 ABA Passat?
  24. Junior Member mcavour's Avatar
    May 15th, 2004
    Fort Bragg, NC
    94 VW Corrado SLC, 99 Audi A6 Avant, 89 Porsche 944 - SOLD
    11-22-2012 01:03 AM #199
    I'm jumping in on this bandwagon...
    Any good iPhone/iPod capable (BT), headunits that can be flush mounted?
    What about the Parrot Asteroid? Anyone has one installed? Pics?
  25. Member Slider388's Avatar
    Apr 30th, 2012
    Columbus, OH
    1992 Corrado SLC
    12-27-2012 05:40 AM #200
    I got an older jvc kameleon kd lx100 with my rado and I love the way it looks, I think it suits the C perfectly. However as some others in this thread have noted, it doesn't sit flush, it sticks out about 1/4". I grabbed my dremel and cut that tab in the back of the bay off and now it fits perfectly. Also ran an aux cable and routed it to my ash tray.
