Originally Posted by
germancarnut51
Yes, you will be able to remove the doorhandle, even with the lock cylinder broken.
Taking the front doorhandles off requires pulling the handle half way, and jiggling like crazy until the handle comes loose from the doorlatch lever, regardless of whether the lock cylinder is intact or not.
You will have to match the rekey the lock cylinders to match the ignition lock key, or at least each other, as doorhandles do not come with matching keys, even when you buy them in pairs.
