Page 1 of 5 1 2 3 ... LastLast
Results 1 to 35 of 172
Thread: Dear E90 BMW 325i: Bite me you steaming pile of shi*...
  1. Member 1320-20V's Avatar
    Sep 20th, 2007
    Upstate NY
    03 Lagrangian Loveseat 1.8t
    07-07-2010 08:21 PM #1
    Dear BMW:
    You are retards.
    Is the weight balance of my slushbox car so critical to warrant placing the battery in the trunk? Because I was pretty damn pissed today when i realized that I could not open the electrically operated trunk release today with the battery dead. Oh sure you provided me with a wildly inconveniently placed positive terminal and no ground. I suppose this whispy 1" long hex hex standoff into the body will suffice.
    I would also like to thank you for making it totally impossible to put the car in neutral without it running. Shift lock override? nonsense. Who would ever need that? I appreciated this when the car was about as movable as Stonehenge in the garage, with its right side battery post buried in the right hand stall, up against the wall where it was nearly inaccessible. Thankfully my GTI has a left mounted battery, in the left garage stall so that its terminals are 400' away from the BMW's. I of course had to construct the most rube-Goldberg arrangement of jumper cables known to man, breaking out a dilapidated set that was once used by Ben Franklin and a lightning bolt. After stringing then through both engine compartments, several trash cans and boxes I was able to connect both cars together.
    Magic happened. The BMW springs to life, it's headlights illuminated, the dual zone climate control sensed the 104 degree ambient temperature and throttled the fans to full afterburner. The seats moved, the steering wheel moved, the radio tuned in and blared, and the dash illuminated the full FAA-Approved set of landing lights, back-lights, side lights, a video played in the screen, everything you could ever ask for and then some. I pushed the engine start button, and nothing....
    Apparently the disco that is initiated upon space docking the five times larger than a normal key-keyless "key" had exhausted the allspark in the trunk. You know the trunk that was locked, protecting the allspark as if it was royalty. Several more attempts resulted in nothing more than a click.
    My impromptu transmission line was enough to open the trunk however, which I might add cannot be opened with its key. the key will unlock the trunk, but does not pop the solenoid. Wonderful. What a kick in the pills. The 22 stray electrons that made it over to the BMW took pitty on me and joined forces to pop the solenoid from the inside button. I had cracked into the trunks norad like defenses, surely the allspark would be mine in short order.
    It was not to be. I cont even figure out how to get the 13 layers of ballistic plastic away from the positive terminal. the negative terminal sits there naked, taunting me. The positive of the allspark however is covered by a fuse-able link, a circuit breaker, a roll over protection switch, a gas vent, and of course a metal bracket to hold the battery down in the event the car is dropped from the space station and lands inverted. I pull on all the above, but the force is strong and the 104 degree heat is melting away my will to live.
    I surrender and replace the battery cover.
    I scream at the car, unleashing a slew of profanity which clearly alarmed the neighbors in our relatively upscale neighborhood. The women and animals are spooked, and the men understand.
    I return to the pleasant confines of the air conditioning and let the BMW trickle charge. If it starts fire, i don't care. Fire might be cooler than the outside temps anyway.
    30 minutes later I go outside and sit in the car. I have a man to man with the dash, and mention that i have 5 gallons of unleaded, and 2.5 gallons of premix if it wanted to get lippy with me and refuse to start. I'm pretty sure I intimidated it. I pressed the key, engaged disco mode, and went for the starter button. It worked! the car was running and I backed it out of the garage for better access.
    I sent my sister out in it and told her to take it for a long drive to let it charge. specifically telling her to drive it a while and not turn it off. I just got the call from her a minute ago. of course she drove it for 5 minutes, and turned it off.
    I'm on my way over there now.
    Thank fully the temperature has plummeted to 98. Hopefully I will succumb to heat stroke before I have to open the hood for the second time today.
    The ultimate driving machine is not the ultimate starting machine.
    Here before the crash, here for Zero Forums, Here for V Bulletin too. TCL for LIFE!
  2. Member VadGTI's Avatar
    Feb 24th, 2000
    Hollywooooooood, CA
    E36 M3/S60R
    07-07-2010 08:27 PM #2
    Instant TCL classic.
    <-- had to jump an Audi with a battery located under the rear passenger seat and underhood terminals last night... In the dark .
    Fizzy - Team My Little Pony
    What Al Gore creates, Dustin Adler takes away.
  3. 07-07-2010 08:31 PM #3
    So for your troubles...that was awesome
  4. Member Lepsis3942's Avatar
    May 15th, 2008
    Flint/Blacksburg
    1988 BMW 535is
    07-07-2010 08:31 PM #4
    Just for the record, most newer cars are putting the battery in the trunk.
    Our 300C has it in the trunk and that was 2005
    1988 535is
    Go Hokies
  5. Member VarianceVQ's Avatar
    Jun 26th, 2005
    Connecticut
    2009 Nissan Altima 2.5S
    07-07-2010 08:33 PM #5
    This thread would be 10x more entertaining if the OP had a FWD Chrysler sedan.
    Alucard -- Autonomous Legion of the Glue Factory...of Death.
  6. Member jetta2.8's Avatar
    May 18th, 2009
    Reading,PA
    TT, S10
    07-07-2010 08:38 PM #6
    Epic, just pure epicness
    1.8tQuattroAviator Grey
    RDG
    flickr
    CBTuning
  7. Member G2BForReal's Avatar
    Jul 2nd, 2002
    Central MA
    Emkay Too, '09 Jetta S, Camry Work Beater
    07-07-2010 08:39 PM #7
    Great read...sad story. I feel your pain about the heat...this is ridiculous.
    Unaffiliated.
  8. Member Gbeav's Avatar
    Jun 12th, 2010
    07 a3 3.2
    07-07-2010 08:40 PM #8
    That was awesome.
  9. Member Ed52's Avatar
    May 21st, 2001
    Toronto, Canada
    07-07-2010 08:50 PM #9
    Please, may we have more of your entertaining rants. They are worthy of being published in "Motor Trend". Your bit was the best laugh I've had all day...Seriously..
    Awaiting eagerly for you next report!
    2001 Jetta TDI
    1997 Jetta GT
    1995 Golf GTI VR6
    a Vdub guitar
    Kid's 94 Golf
  10. 07-07-2010 08:53 PM #10
    Lmao. That sucks, but so funny. Mymsister would have done the same dumbass thing and would have blamed me in the end.
  11. Member Nobelium's Avatar
    Apr 25th, 2007
    Miata on 20's, bagged cherokee, Rusted E30.
    07-07-2010 08:54 PM #11
    ha.
  12. Member Lepsis3942's Avatar
    May 15th, 2008
    Flint/Blacksburg
    1988 BMW 535is
    07-07-2010 08:54 PM #12
    Quote Originally Posted by Ed52 View Post
    You should read Juniper Monkey's thread as well
    1988 535is
    Go Hokies
  13. Forum Sponsor Brendan@bwalkauto's Avatar
    Nov 28th, 2009
    Redwood City, CA
    07-07-2010 08:56 PM #13
    My friend has an E90 325, and while I've made fun of it for years now, this just gives me more ammo.
    Great read!
    Brendan Dolan
    Shady - Team My Little Pony
    Boardwalk Auto Center
    Volkswagen l Nissan l Chevrolet l Lotus
    My Nissan LEAF Blog.
  14. 07-07-2010 09:07 PM #14
    holy sh*t that was funny
    looking forward for the rebuttal once OP returns from another jump start
  15. 07-07-2010 09:08 PM #15
    Dear BMW:
    You are retards.
    Talking about retards, why in the hell didn't you just use the key to open the trunk?
    2007 E90 AW 323i Step Premium | Lowered 1.25"/1" | BMW Performance Exhaust | PBX | Debadged | Scangauge II | Style 162 18" & 161 17" wheels
  16. 07-07-2010 09:08 PM #16
    ****ing classic!!!
    ARE YOU SURE YOU WEREN'T DIGITALLY RAPED IN YOUR SLEEP BRO?
  17. 07-07-2010 09:12 PM #17
    Sounds like me attempting to charge the battery in my mom's Smart, battery in the passenger footwell, underneath 5" of carpet, sound deadening and finally....STYROFOAM! Shaped very awkwardly to mold around the battery tray and tucked somewhat at the corners below the dash.
    It also has a shift lock that is not key-bypassable, needs juice from battery to unlock the shifter.
    You should submit your story to Satch @ Roundel.
  18. Member VarianceVQ's Avatar
    Jun 26th, 2005
    Connecticut
    07-07-2010 09:15 PM #18
    Quote Originally Posted by fahrfrumlosin View Post
    Sounds like me attempting to jump my mom's Smart, battery in the passenger footwell, underneath 5" of carpet, foam and finally....STYROFOAM!
    As if any more proof was needed that Smart is the most ironically-named car brand in world.
  19. Member
    Feb 16th, 1999
    Ellicott City, MD
    2005 Civic, 2008 Taurus X
    07-07-2010 09:24 PM #19
    Quote Originally Posted by Saintor View Post
    He did...
    Quote Originally Posted by OP
  20. Member 1320-20V's Avatar
    Sep 20th, 2007
    Upstate NY
    07-07-2010 09:31 PM #20
    Dear Saintor:
    There I was. Just me and the prey. I was waiting for just the right moment. It was if I was a lion crouched down motionlessly in the Serengeti. Hot saliva dripped from my mouth as i crouched motionless like a statue, stalking my prey. The tiny antelope grazed peacefully unaware of the grim circumstances of the all too near future. I was the apex predator, and the tiny antelope was enjoying the sweet succulent taste that embodies its last meal of wild grass. The hot breeze blew over my tensioned body. Now was the time.
    I should strike now. Like a Ninja I withdrew my roundel emblazoned dagger from its futuristic and redundant sheath. In an instant the supernova-like sun gleaned off the tiny instrument of death. I had been made. I unleashed all of my muscles in one smooth thrust of deadly fury. I buried the dagger deep leaving no room for error. Like the last gasping breaths of the antelope as i suffocated it with my powerful jaws. I tasted the life slip out of the trunk lid as I drove the little dagger home.
    Yet the animal would not die. I grasped hold of my killing weapon thrashing vigorously left and right. The sun shone down on me as the only witness to my valiant efforts to slay the mighty-yet tiny baby antelope. Then it happened. Like a swift hoof to the face I knew i was defeated. All my stalking, and hunting had been for naught. The key struck deep but there were no internal organs. It unlocks the trunk alright, but in no way pops the solenoid to open it. It is purely electric with no mechanical backup.
    I felt the tension of the herd in the air. The distant thunder of a thousand hooves closing in on me. I was defeated. My only hope of survival was to escape. My pride broken, I watched at the tiny antelope scampered away. I too ran, back to the safety of my air conditioned den. I needed to restore my energy. I may have lost the battle today, but the war was far from over.
  21. 07-07-2010 09:35 PM #21
    I am lmfao here..
    The allspark!! lol
    "One thing I’ve noticed over the years is that if you drive into London at 6am, half of the cars on the roads are Porsches and Astons. Whereas if you go in at ten to nine, they’re all Renaults. Simple solution, then. You want a nice car? Get up earlier and do more work."
    -- Jeremy Clarkson
  22. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    07-07-2010 09:37 PM #22
    Quote Originally Posted by 1320-20V View Post
    I saw that coming.
    Thanks for posting.
    That was a good laugh.
    _______________mazda__________________ http://www.spellchecker.net/spellcheck
    ||||||||||||||||||ɯɐzpɐ|||||||||||||||||||||
  23. 07-07-2010 09:38 PM #23
    Quote Originally Posted by 1SICKLEX View Post
    I am lmfao here..
    X2 This is a fantastic thread... waiting to see what else can become of this
  24. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    07-07-2010 09:43 PM #24
    Quote Originally Posted by blackvw0484 View Post
    If I was more eloquent with text, I could have written a good yarn about the RX8's tiny battery and starter, and how it takes 30 minutes to unflood one-> all with that tiny battery and starter!
  25. 07-07-2010 09:45 PM #25
    Funny.
    With texts like this, not surprised that one can be misleaded.
    I doubt this. I had to jump start my E90 about 10x times in its first 4 weeks and unless my memory doesn't serve me right or there was enough current, I was able to open it by key even if the battery was dead. However it was insanely *hard*. I even thought that it was not working intermittently and even complained to my BMW dealer on March 04/2008 ... I have the work order in front of me. The written correction; "Checked with other 3 series for similar effort, all the same".
  26. Member
    Sep 13th, 2007
    Chicago, IL
    Z4 M Coupe, Solstice GXP
    07-07-2010 09:46 PM #26
    I traded my Smart for a Pontiac Solstice GXP. To replace the battery on a Solstice, you have to remove a front fender! Y'all can siddown now.
    These pretzels are making me thirsty!
  27. 07-07-2010 09:48 PM #27
    Please do! Hopefully its as entertaining as this
  28. Member
    Nov 7th, 2001
    The Village
    KAR 120C
    07-07-2010 09:49 PM #28
    Love it.
    Yet another reason an E90 won't be making it onto my must shop list...ever.
  29. 07-07-2010 09:57 PM #29
    "specifically telling her to drive it a while and not turn it off.. ..of course she drove it for 5 minutes, and turned it off."
  30. 07-07-2010 09:57 PM #30
    "allspark."
    Great reference!
    Germans tend to over-engineer things. It is like they are still trying to build machines to outfox the allies and win WWII.
  31. 07-07-2010 09:58 PM #31
    Quote Originally Posted by epbrown View Post
    Hahaha and I thought replacing headlight bulbs on Megane was bad.
  32. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    07-07-2010 10:02 PM #32
    Quote Originally Posted by LhW View Post
    "allspark."
    Great reference!
    Does BMW really stand for Enigma Machine?
  33. Member choochoo's Avatar
    Nov 12th, 2008
    OC
    1989 GTI 16V
    07-07-2010 10:09 PM #33
    Could you have lowered the back seats and pull on the emergency, glow-in-the-dark, trunk release? That's assuming you have the optional folding back seats..... which is beyond me why it isn't a standard feature.... this car does have some design flaws/oversights.....
    By the way, your rant was quite educational.
  34. Member WannaCorrado's Avatar
    Apr 30th, 2000
    NYC
    Corrado, UrS6 Avant, MK5GTI
    07-07-2010 10:54 PM #34
    Quote Originally Posted by choochoo View Post
    even if the car came with the split-fold seats, you can only fold them down via the trunk..
    The Ski-pass through would provide just enough room to reach into the trunk for the fold-down levers, if you have long arms
  35. Member esrballa's Avatar
    Oct 8th, 2008
    Los Angeles, CA
    98 BMW M3
    07-07-2010 11:00 PM #35
