#71
I am not sure what pressure those are rated for ....
I would just suggest terminating with a barb and using a small runner of hose with a clamp.
HAD - 1991 V8Q | 1990 Jetta 1.6 | 1984 Rabbit 16v | 1990 Audi CQ | 1988 Audi 80 10v | 2005 GTi 1.8T | 1991 GTI 2.0 ABA | 2002 Audi TT S362 |
HAVE - 2001 TT 180Q F23 wifes | 1989 Jetta VR6 GLI | 2004 F250 PowerStroke |
Looking for Custom Tuning, Shoot me a PM ! ME7.X !
#73
on a awd tt 225ps if you keep the stock in tank fuel pump and add at the filter position a bosch 044 will you have starvation below the 1/4?????
#74
My Build
FS: New in box, primer'd 20AE body kit (front+rear valences and side skirts) -- PM me for details
FS: Fiberglass 20AE replica spoiler. No scratches. Reflex Silver.
#76
So, if I wanted to use my stock fuel pump to feed a surge tank, would I be fine just using the stock fuel line to feed the surge tank? Could I get away with using the stock fuel pump feeding into a Bosch 044 inline (with stock fuel filter before the inline pump)? This setup will be to support 700+hp.
And lastly, where did you find the Integrated Engineering surge tank (without pump) for $199?
"You know you have a bad idea when Ford guys are making fun of you."
FS: Autronic SM2, 500r CDI, Misc. Related Parts.
#77
#78
stock fuel pump can feed a surge tank just fine at most any power level
stock fuel lines can feed the surge tank
I'm not a big fan of inline pumps..but you could go pump -> filter -> 044 ...and it'd work... But I'd recommend to go with a surge tank instead. Just seems like a much smarter setup.
I got the $199 off their website. Maybe that was an intro price. I don't know what it is now.
PS... IE and INA both make great surge tanks...but they fit different applications. So pick the one that suits your build best.
My Build
#79
1) You left your car in the driveway overnight. Gauge says... --------->0psi
2) You open the car door. You hear the pump prime. Gauge says... --------->36psi
3) You turn the key to the ignition ON phase. Gauge says... --------->36psi
4) You crank the engine and the car turns over. Gauge says...--------->34psi
5) You rev the car while in idle. Gauge says...--------->34psi
6) You go for a drive and you don't really get into it (<5 psi boost). Gauge says...----->36-40psi
7) You stomp on it. You are holding 1 BAR boost. Gauge says... --------->44psi
8) After stomping on it you suddenly release the gas pedal. Gauge says...--------->>34psi quickly
This is what I see...
..and 10min after you shut the car off the fuel pressure is back down to zero....
#80
#81
I'm looking to move my Bosch 044 to the fuel filter location however when I go to lookup the fittings on the badger-5.com site I do not see it. Can anybody tell me if those fittings/adapters are available elsewhere? If they are not available, would it be possible to just run 5/16 high pressure fuel line from the back all the way up to the front?
Thank you
Stage 3 04 GLI & Stage 2 07 GLI.
#82
My Build
#84
Does anyone know the fittings required to run AN fittings for this A4 fuel filter?
http://www.ecstuning.com/Audi-B5_A4-...lter/ES258818/
2001 Audi A4 1.8t Quattro 6spd Black on Black
2L • BorgWarner S259 • AEB Head • ST Valves & Springs • IECVA1 Race Cams • JE Pistons 8.8:1 • ID1000s • Bosch 044 • Aeromotive FPR • Apexi Intercooler w/ 3" piping • 80mm Hemi TB • HKS SSQV BOV • Custom Big Plenum NubWorks IM • Turbonetics 38mm WG • Eurodyne Maestro • FX 850 SS • 01E Swap •
#85
Just an update to the above.
the two fittings that you need are m12x1.5 and m14x1.5 with whatever AN size you want on the other I went with -6an.
I will post a picture up if I remember
#86
just an FYI: Went to Summit yesterday to grab the Aeromotive 15117 fitting an it would not lock on to the stock MANN filter.![]()
#87
This part works:
http://www.summitracing.com/parts/RUS-640863/
My Build
#89
What are you trying to do exactly?
If you're running the stock fuel line, why not just run 5/16" fuel hose from the factory fittings and be done with it?
Good option for factory hose...
http://forums.vwvortex.com/showthrea...and-180-degree)!!!
Otherwise, if you've already converted the lines to -6AN male, then get a -6AN Female -> barb fittings
Again, what are you trying to do?
My Build
#91
This is an excellent thread. I am almost done with my full stainless line conversion (hard and soft). This would have saved me a BIT of time.
Share this.
#92
I know this thread is a little old but...
Is it a big deal if I don't change the line form the stock pump to the filter and just run a 3/8" line the rest of the way?
If I need to run that line what is the best line to use? Looking at doin the rest in stainless hard line.
Is it fine to leave the stock return line or should that go bigger?
At what point should I be looking at a surge tank ?hp? I'm just over 400whp like to go more.
Thank you for any help..
Gt3076r .....
#93
My Build
#94
Would that line be big enough to keep it filled and how safe is it to have that there on a daily drive car? I do run the inline walbro up there but I'm look at moving it back to the filter location.
Problem I'm having is leaning out as I get pass 25psi (a/f 13.4) .. Not sure if its a line issue or I need bigger pump , surge tank, or bigger injectors
Gt3076r .....
#95
Your lean out issue must be diagnosed.
Go start your own thread with a detailed overview of everything and lets go from there.
Ps... 5/16" (stock) lines can flow a lot
My Build
#97
My Build
#98
#99
Brute 20mm Connecting Rods, ACL Bearings, Wiseco 83mm Pistons, FSI Crank, AEB Head, CatCams 3658, PagParts GT3076R Bottom Mount V-Banded Turbo Kit, PagParts Garret 550HP Core, VF Engineering Motor Mounts, SEM IM, Labonte W/M, 70mm TB, Tial Q BOV, Tial Wastgate, Turbosmart Dual Stage Boost Controller, Peloquin LSD, Clutchmasters FX400, 910cc Injectors, IE Surge Tank, Eurodyne with Maestro.... PAGPARTSClear Water Dubs
#100
Cheers for the reply, that's answered my question
Does anyone know of any fittings that can be used to cut the oem line and connect to it
Cheers
#101
My Build
#102
Would like to go to -6AN fittings which will feed my surge tank but was just hoping to have the join out of sight![]()
#103
My Build
