VWVortex.com - Door Lock Switch decals
    Results 1 to 18 of 18
    Thread: Door Lock Switch decals
    1. 07-11-2010 02:17 AM #1
      Couldn't find a reference to this problem using search function...
      The plastic facing/decals on the power door lock switches on my rear doors (2006 Passat) have blistered badly and are flaking off. I took to the dealer who said I would have to replace the switch assembly as they could not replace just the decals.
      I was double checking that answer in this forum. Had the same problem with the front switches while the car was under warranty and the dealer fixed or replaced them several years ago, but I never asked what the dealer did to correct the problem.
      Do other have a similar problem and is there an alternative to completely replacing the switch?
    2. Member tmanpikos's Avatar
      Jul 13th, 2009
      Tarpon Springs, FL
      '05 Honda S2000
      07-11-2010 03:01 AM #2
      The ones on the rear doors are really bad right now, on my '06. Front, not as bad. How much is it to replace all of them when out of warranty? That's what I need to know!
      '05 Honda S2000 Sebring Silver
      '06 Passat 2.0T (SOLD)
    3. Member PASSAT888's Avatar
      Jan 27th, 2010
      Arkansas/Florida
      2006 VW Passat
      07-11-2010 08:47 AM #3
      Im having the same prob on my fronts......anybody have any ideas on cheapest way to fix?
    4. Member briankstan's Avatar
      May 22nd, 2009
      West Jordan, Utah
      06' 3.6 Passat 4-Motion
      07-12-2010 12:46 PM #4
      ECS tuning has the switches available....
      http://www.ecstuning.com/Volkswagen-...earch/WINDOW/2
    5. Member tmanpikos's Avatar
      Jul 13th, 2009
      Tarpon Springs, FL
      '05 Honda S2000
      07-12-2010 01:59 PM #5
      Quote Originally Posted by briankstan View Post
      Lock switches, not window. Those are still holding up lol
    6. 07-12-2010 03:17 PM #6
      The dealer service dept "person that calls the customer back but doesn't know squat about what they are talking about or know any details" gave me a price of $158 to replace the lock switch(es?)... but I don't know if that was for one or both sides as I was so floored by the need to replace the whole switch that I didn't think to ask!
      Mine are so blistered that they are flaking off. I was thinking about scraping off the material and then maybe painting it matte black (which would cover the internal illumination light). Outside of that option, haven't come up with any others.
    7. n00b
      Aug 10th, 2010
      Thornton, PA
      2006 VW Passat 3.6L
      08-15-2010 09:11 PM #7
      So does anyone have a DIY on how to replace the switch? Do you have to take the door panel completely apart to replace it?
      Only my driver's door is bubbling so that's the only one I am looking to replace.
      - Jim
    8. Member RWM3's Avatar
      Dec 1st, 2008
      Albany, NY
      06' GLI 6mt, 99' Land Rover Discovery II
      08-16-2010 02:05 AM #8
      mine are totaly the clear base plastic color on my driver controls, the front passerner is getting really bad, and the rears are fine. again, i have an 06.
      was this problem unique to 06's?
    9. 08-16-2010 09:52 AM #9
      Yes this problem is unique to the 06 Passat. VW at first said it was your hand oils that made the covering bubble. Yeah sure, buttons and switches that will bubble and flake because of oil on your hands. Sometimes the dealer will replace under warranty. In all reality, it is just another poorly crafted part that the consumer is stuck with or has to pay to have them replace with better switches. My 06 is currently at the dealers and two bubbling buttons is on my list of issues to be looked at. I have 51k on the car. CPO warranty. I will let you know what happens.
    10. Member
      May 10th, 2010
      North Jersey
      2016 Tiguan SE 4Motion
      08-16-2010 10:08 AM #10
      1stvwparts has the front door switches for $20.34 each
      APR Stage 1/Morimoto 5500K D3S bulbs/Hella XY 9006 bulbs... keeping the mods light on this one...
    11. Member stres's Avatar
      Mar 17th, 2009
      Lake Tahoe\ABQ
      06 passat 2.0T
      08-16-2010 02:25 PM #11
      it is not just the 06 b6 a buddy of mine has the same issue on his 08 jetta as i have this issue aswell get it right vw
    12. Member euro2envy's Avatar
      Jan 9th, 2010
      SoMD
      Low n Slow B6
      08-16-2010 02:42 PM #12
      y is VW charging us for something that is a known issue, why not just recall it
    13. 08-16-2010 02:46 PM #13
      Quote Originally Posted by euro2envy View Post
      Do the math. Say 1 million units sold. 1 million units return to have a $1.00 switch replaced. $1 million dollars out of their pocket. Normally a recall needs to be a safety related issue. Since crappy cheap interior materials are not safety related there will be no recall issued.
    14. 08-07-2011 03:49 PM #14
      My 06 passat just started having this problem on all 4 door locks and everytime I or passengers push the decals, flakes come out and it's looking really bad!!!! Need a solution please!
    15. Semi-n00b
      Mar 23rd, 2011
      1993 Corrado SLC 1988 Bmw 325ic 2006 Passat 3.6
      08-07-2011 05:26 PM #15
      You need to order new door lock switches. I believe the part numbers are as follows (Double check...I could be wrong) :
      Left front - 3C0-962-125-B-REH
      Right front - 3C0-962-126-B-REH
      Left Rear - 3C0-962-135-B-REH
      Right rear - 3C0-962-136-B-REH
      I plan to order these. I have already ordered replacements for the window switches and the mirror switch. Can anyone give any insight onto the procedure for removing the door card to get to the switch?
    16. Junior Member
      Aug 16th, 2011
      Everett WA
      2006 B6 2.0T Passat
      08-29-2011 08:18 PM #16
      I think I may have a solution for this. I am going to take a picture and edit it in Photoshop. Find a place to print these off as stickers and then take the locks out trip them down put the stickers on and paint with Duplicolor paint and then peel the sticker off. THis should fix the cheap SOFT TUCH Paint VW and other GERMAN cars use.
      ALso I am painting the door handles with Duplicolor paint after I strip them. Make the car look better and resolve the issue.
      Will keep you guys posted when I find a shop that can make these as stickers.
    17. 09-13-2011 08:28 PM #17
      My 06 Passat has the same issue. The back lock switches are completely peeled off and the front are on their way. The front door arm rests are also peeling very badly. Not good. This is really early in the life to be having these issues. I'm afraid of what will peel next
    18. Member Serbmatic's Avatar
      Mar 20th, 2011
      Maine
      Golf MKVI 2.5
      09-22-2011 10:47 PM #18
      http://pandapeeps.com/euro-chrome-sw...7a1b8f00feaf71
      Im getting this deal soon, go and check out the site
