Update to my post...
I received a call from the service adviser in the afternoon (same day as I posted). He advised that his Manager would replace the rear rotors as "one time courtesy". I am not happy with the one time courtesy replacement since this is an ongoing issue with the vehicle. I made an appointment and rotors were replaced. My issue is still with VW. I can't blame the dealer at this point. I have been thinking of getting aftermarket brakes and rotors as some of you have. I guess it's the principal of VW knowing they have inferior brake parts and continue to use them. They should not be left off the hook that easy IMO.
I could not get them to clear the brakes! The diameter obviously was not a problem, as this wheel is 3 inches bigger than my stock wheel, but the caliper protrudes out to far to allow the wheel to seat. After putting my stock wheel back on, I see that it only just clears the caliper... just.
How are your latest set of brakes holding out?
The front brakes are squeaking a good bit when they get hot. I don't feel any grinding under the pedal or hear grinding, but definitely squeaking after a lot of city driving and when it's been hot outside as it has been the past couple of months. Enough squeaking to make you cringe at times, both driving the vehicle and when at the end of the driveway playing with the kids when Spouse rounds the corner turning into the driveway.
