not sure from your description. 80 to 90 psig would be normal if you were checking without the compressor running. i guess it's possible that the compressor has died. test the low side with the compressor off and again with the compressor on. is there any difference in pressure? and you are sure that when the compressor is running that the end plate of the compressor clutch is spinning?
