VWVortex.com - How do I remove car lot "windshield marker"?
    Results 1 to 14 of 14
    Thread: How do I remove car lot "windshield marker"?
    1. Member CdnCorrado's Avatar
      Jul 2nd, 2004
      Canada
      1995 Corrado
      07-21-2010 12:47 AM #1
      I just bought a car at auction and am wondering about the easiest way to remove the grease marker (or whatever it is) that they used to mark the vehicle year & auction number on the vehicle's side window. Simple glass cleaner doesn't work at all. Should I try a clay bar, or is there a better/easier way?
      TIA
      Aug 30th, 2009
      2006 Jetta
      07-21-2010 03:08 AM #2
      Razor blade
    3. Member CdnCorrado's Avatar
      Jul 2nd, 2004
      Canada
      1995 Corrado
      07-21-2010 06:16 PM #3
      Thanks for the reply.
      I was hoping to avoid the razor blade option ...the last time I used the razor blade method I remember it being very tedious.
    4. Member BRZ's Avatar
      Mar 7th, 2005
      SWO
      '05 330cic ZHP, '16 GTI
      07-21-2010 09:28 PM #4
      Get the majority off with the blade, then use some steal whole to completely remove the rest.
    5. 07-21-2010 10:06 PM #5
      I would try a plastic razor blade first, then move on to the metal blade. Douse it liberally with rubbing alcohol as you go along to make it a bit easier to remove.
    6. Member Beersix's Avatar
      Oct 19th, 2007
      12 valves of Fury Since 2003
      07-22-2010 01:46 AM #6
      use some adhesive remover. it worked for me,, Don't scratch the glass with the razor blade!
      BEERSIX
      VRSociety # 105
    7. Junior Member
      May 1st, 2009
      So Cal
      02 GTI totalled, 04 pg jetta
      07-22-2010 02:05 PM #7
      ouch no razor blade. steel wool and lots of glass cleaner or water
      Jan 29th, 2004
      South London, UK
      2002 Audi A4 2.0, 2005 Honda Transalp XL650v
      08-03-2010 11:23 AM #9
      WD40.
      No really.
      Aug 30th, 2009
      2006 Jetta
      08-12-2010 12:59 AM #10
      Quote Originally Posted by kai_ascencio View Post
      It's glass (!), you aren't gonna scratch it with a razor blade. I used to remove stickers from paint without damage using a razor blade.
    10. 08-13-2010 03:32 PM #11
      you thought u didnt hurt the paint, but i bet you did take some of the clearcoat up.
      2002 Jetta GLI 24V VR6
    11. Member
      Dec 12th, 2004
      09-12-2010 10:41 PM #12
      I'm not sure how tedious it is to scrape off the window markings, should take a couple of minutes, but brakleen on a paper towel will take it right off as well. Obviously be careful not to get it on the paint. Shouldn't harm most cured paint, but it will certainly strip any wax/LSP whatever.
    12. 09-12-2010 10:53 PM #13
      I dont know if you have done this yet, but I do this almost every day at work. Ive done this to thousands of vehicles so far, and here is what works.
      1. Get window wet, glass cleaner works well.
      2. Razor blade with clean blade, gliding over white marks. apply almost no pressure. Window will not scratch unless you dig in with an awkward angle. It take less then 10 seconds for the entire process. No need to purchase some expensive goo remove kit or anything like this.
    13. Member TXR32's Avatar
      Jun 4th, 2006
      Webberville, TX
      '04 R32 '07 Cayman '11 TRD Tacoma
      09-13-2010 05:19 PM #14
      Quote Originally Posted by 67Customs View Post
      Steel wool and vinegar or goo gone.
