VWVortex.com - Software Update
    Results 1 to 9 of 9
    Thread: Software Update
      Aug 13th, 2009
      San Diego
      2016 GTI PP 6M
      07-26-2010 02:01 PM #1
      I just heard there's a software update on the Mk6 - something about an 02 sensor?
      Jun 4th, 2010
      Regina, SK
      2017 Golf R, 2010 GTI
      07-26-2010 04:07 PM #2
      If this is true does it mean they would have to flash my ECU? ****.
    3. 07-27-2010 04:24 PM #3
      How would we find out if this is true?
      And would this mean for anyone who has the APR Stage 1, then once the VW dealer flashes with this software update it will overwrite the APR programs, so then APR would have to do another flash?
      This brings up a question... when you get an APR flash and you're getting multiple programs, is the APR "stock" program written on there by APR? Or does APR not affect the program that VW put on there, and APR just adds additional programs?
    4. Member mike3141's Avatar
      Feb 16th, 1999
      2012 A3 2.0TQ
      07-29-2010 10:11 AM #4
      The stock program on an APR'd VW is APR's. If VW issues an ECU update, it will overwrite the APR flash.
    5. Member afrost's Avatar
      Oct 29th, 2002
      Midwest
      2004 R32, 2015 Golf R
      07-29-2010 11:55 AM #5
      It sounds like to reflash with APR software after the first time they can just do it through the port though right? Does this still hold true if the dealer overwrites the APR flash? If the ECU had to be removed again that would suck.
    6. Member
      Jul 16th, 2005
      05 GTI, 07 Rabbit
      07-29-2010 01:01 PM #6
      I just had mine done, all they do is update the ECU and change out the rear oxygen sensor. But I think this is only for the TDI vehicles.
    7. 07-29-2010 04:11 PM #7
      can anyone answer the question about the re-flash: Is this done via the port or does it require removal of the ECU again?
    8. 07-29-2010 11:42 PM #8
      Quote Originally Posted by fredf View Post
      port
      Mar 10th, 2009
      2006 Passat 2.0t 6mt
      07-30-2010 09:00 AM #9
      TDI's have a software update to change the working range of some sensors.
      Some GTIs/Passats/Tiguans/CCs have an update for the run time of the after run pump.
