VWVortex.com - Car randomly dies while driving on freeway
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 38
    Thread: Car randomly dies while driving on freeway
    1. Junior Member
      Jul 20th, 2003
      2003 20th AE GTI, 2013 Passat TDI SEL
      07-26-2010 06:31 PM #1
      Within the past six months or so, I've had a problem that has randomly occurred twice that I have not been able to find an explanation for. I have an 03 GTI 20th with 115k mi.
      While cruising on the freeway (approx 70 mph), the car suddenly dies. The gas pedal suddenly does not work, the rpms fall down to zero, engine shuts off, red battery indicator light on instrument cluster turns on, power assisted steering doesnt work anymore, but all the electronics seem to work (radio, dashboard lights, etc are still lit up). After slowly pulling over to the side of the freeway, I am able to turn the ignition key to the off position and then start the car with no problems. So WEIRD!!
      Reading the forums, some people suggest fuel pump or MAF sensor but no definitive solution.
      A few months back, I took it to a shop to diagnose this issue with no results. They "inspected the electrical system" (which probably means they just checked to see if any CEL codes were thrown) and concluded everything was fine. I also took it to a dealer a few weeks back and they did a free "26 point" inspection and found nothing wrong with the car too.
      Anybody have any insight into what this might be?
    2. Member lilman1's Avatar
      Dec 26th, 2007
      milltown NJ
      04.5 GLI, 05 Jetta, 09 Rabbit
      07-26-2010 06:41 PM #2
      whats done to the car?
      money can't buy you happiness but its a good downpayment
    3. Junior Member
      Jul 20th, 2003
      07-26-2010 06:49 PM #3
      Car's completely stock.
    4. 07-27-2010 11:13 AM #4
      I know this!!! Its %100 your crank angle speed sensor is bad!!! It happened to me ages ago.. The sensor sits in the lower right block just below the oil filter housing.. Thank me later...
      Here's what it looks like...
      http://www.mjmautohaus.com/catalog/p...oducts_id=1367
      01' BT Jetta
      14' Audi Q5 TDi
      14' JSW TDi
    5. Member guanatozridez's Avatar
      Jan 8th, 2008
      San Jose CA
      2015 Audi S4. 2015 VW GTI S, 2011 Mustang GT Sold: 2004/VW/Jetta GLI
      07-27-2010 10:08 PM #5
      Quote Originally Posted by nivlag View Post
      dude this just happened to me on sunday.
      was cruising like at 60 and just shut off just like urs with battery light lite up, pulled over and didnt want to start the first time but the second time it turned on like nothing. extremely weird.
    6. Member DowNnOuTDubin's Avatar
      Jun 21st, 2006
      Portland, Oregon
      20th AE 3366
      07-27-2010 10:25 PM #6
      I've had the same thing happen to me. The first time I thought I ran out of gas and was able to coast to a gas station! It went away over time
    7. Junior Member
      Jul 20th, 2003
      07-28-2010 03:47 PM #7
      Quote Originally Posted by EF9Si View Post
      thanks for the tip. can anybody else confirm that this problem is a failure of the crank angle speed sensor?
      Oct 9th, 2007
      Rockville,MD
      2002 VW GTI 337
      07-29-2010 03:10 PM #8
      Yeah man. This just happen to me Last week. I was Driving...battery light came on...after a 2 miles or so...lights started dimming then eventually went out so i pulled over and had to get it towed. It was My Speed Sensor and i also had a issue with the immobilzer
    9. Member jar_bond's Avatar
      Oct 8th, 2006
      Irvine, CA
      2003 BMP GTI 20th AE
      08-03-2010 03:20 AM #9
      this happned to me a couple months ago, and it turend out to be my fuel pump going bad.
    10. Junior Member
      Jul 20th, 2003
      08-03-2010 03:47 AM #10
      Quote Originally Posted by jar_bond View Post
      yeah...i've been suspecting the fuel pump too. i've been hearing abnormal/inconsistent sounds coming from under my rear seat (where the fuel pump is located) and figured i'd just order a new one. the symptoms seem to indicate a failing fuel pump. i'll let you guys know the results.
    11. Member Ryan E.'s Avatar
      Oct 1st, 2002
      Huntington Beach
      '08 CW R32, '74 BMW 2002tii
      12-11-2010 11:37 PM #11
      Did you ever figure it out?
      Rigi Cola.
      "The VR6 was an orchestra of well-tuned cylindrical delights." - jalopnik.com
    12. Junior Member
      Jul 20th, 2003
      12-11-2010 11:43 PM #12
      It ended up being the fuel pump for me. Replaced it months ago. Weird noises from underneath the backseat disappeared. Random car dying stopped. Everything seems to be running great now. I hope it's the same fix for your situaton.
    13. Member Ryan E.'s Avatar
      Oct 1st, 2002
      Huntington Beach
      05-11-2011 04:05 PM #13
      I finally changed the engine speed sensor but am still having issues. There was no communication coming from the sensor, but now my fuel pump sounds like it's making a sound. The car still will die on the freeway, holding the gas down for about 5 seconds makes the car go again. Gonna try and find out how to test the fuel pump with VCDS.
      Rigi Cola.
    14. Junior Member
      Jul 20th, 2003
      05-11-2011 04:12 PM #14
      from what i remember, testing a fuel pump required doing a fuel pressure test with a gauge that you connect to the fuel line (not a ODBC/VAG test). i didnt have the proper tools to perform one and figured instead of paying a shop to diagnose/perform the test, it would be cheaper to just replace the fuel pump. fuel pump cost me $160 at MJM Autohaus. There are probably cheaper options, but i wanted OEM.
      Quote Originally Posted by Ryan E. View Post
    15. Member Brimjolt's Avatar
      May 16th, 2008
      Burlington, ON
      '12 Jetta GLI
      05-11-2011 06:23 PM #15
      had that happen to my mk3 Jetta. Def the crank sensor.
      Quote Originally Posted by Zhine
      Power sliding is not worth it, I realized I was addicted and have taken up a much healthier safer hobby called high school girls
    16. Member SuckerPunch's Avatar
      Jul 20th, 2003
      LBC, CA
      1986 951, 1978 Rabbit, 1957 T1
      05-11-2011 07:08 PM #16
      Quote Originally Posted by Brimjolt View Post
      read the thread next time
    17. Member redsoxreturns's Avatar
      Oct 18th, 2004
      W211 E550; 2007 SRX
      05-12-2011 12:28 AM #17
      Quote Originally Posted by SuckerPunch View Post
      I think if it were me, I'd check all my grounds before throwing a pump at it. I seriously doubt a shops "electrical check" would cover that, and I know a XX point inspection won't either.
      just a thought.
      Big Bopper to March Hare..We're still in the game okay? Understand this, that scag, and his floozy....They're gonna die!
    18. Junior Member
      Apr 16th, 2012
      Jacksonville, NC
      07 2.5l wolfsburg jetta
      08-09-2013 12:51 PM #18
      I had my oil changed then shortly after my check engine light came on and the code was lean reading in bank one. I messed around with my maf and got the code before and used some maf cleaner and got rid of it. But now the car dies and the dash lights don't come on or anything turn the key nothing so what could cause that. I have fully power and acceleration when the car is running. Plz help with suggestion and by the way I think the car still has original fuel filter and the car has 85k
    19. Junior Member
      Jul 20th, 2003
      08-09-2013 01:21 PM #19
      Sounds like a different problem than the original post based on the symptoms you are describing. I know this sounds ridiculous, but have you checked your battery terminals for corrosion? I've seen similar problems that make you scratch your head where power seems to get cut off unexpectedly caused simply by a bad connection to the battery.
      Quote Originally Posted by Zimm the Mkv racer View Post
    20. Junior Member
      Apr 16th, 2012
      Jacksonville, NC
      08-09-2013 03:29 PM #20
      I did have some corrosion and I cleaned it off which reset the car. The thing is I have all the normal power and accerlation that I usually have it will just shut off and there is nothing on the dash it goes black and the doors unlock I don't know what is going on. I have a short ram air intake and they sprayed something in the filter and then the check engine light came on
    21. 08-07-2014 10:28 PM #21
      I've replaced it all and I still randomly stall at quarter tank or less. I'd like to urge everyone who has this problem to file a safety complaint with the NHTSA at*http://www-odi.nhtsa.dot.gov/complaints/
      I'm tired of throwing money at an issue that is obviously so common and dangerous it should've been recalled by now. If enough of us complain to the NHTSA they might get the ball rolling for us and in the process actually figure out what's causing it once and for all. Have your VIN handy for filing the safety complaint.
    22. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      THE IY AWD BT 20TH and Ti edition RS4
      08-07-2014 11:00 PM #22
      Ummmw what
    23. 08-08-2014 08:53 PM #23
      Quote Originally Posted by 87vr6 View Post
      Ummmw what
      Thread title: Car randomly dies on freeway.
      Willing to bet everyone who is randomly stalling at highway speeds is at a quarter tank of gas or less. It's an epidemic, there are many threads on many sites for what seems to be the same problem. Seems like the car is starved for fuel then just comes back to life a few seconds later or whenever it wants. Replacing the fuel pump or crank sensor might seem to fix it for a minute, but the problem usually returns. It's dangerous if you're not ready for it, and sometimes even if you are. I thought reporting it to NHTSA would be the best way to try and get this problem solved and recalled on VWs dime instead of us throwing money at our cars replacing sensors and fuel pumps and crossing our fingers that it fixes it. Capiche?
    24. Senior Member 87vr6's Avatar
      Jan 17th, 2002
      SLC snow life
      08-08-2014 10:17 PM #24
      good luck.
    25. Member Rockerchick's Avatar
      May 10th, 2005
      Cary, NC
      '03 BMP 20th GTI, '84 TD Jetta
      08-08-2014 11:53 PM #25
      You could also not run your tank low if you know that causes it...
      And when you say you "replaced it all", what does that mean? What have you replaced? What troubleshooting did you do?
      Quote Originally Posted by TM87 View Post
      VW-making mechanics out of owners since 1957.
      The project - '84 Jetta 1.6TD
      The Wheelbarrow - '82 Rabbit Pickup
      Hers - '03 BMP 20thAE GTI
      His - '16 GLI SE
