Page 1 of 2 1 2 LastLast
Results 1 to 35 of 50
Thread: ***South Bend Clutch Kits From BSH***
  1. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    07-27-2010 07:39 PM #1
    Heavy duty version of the stock O. E. clutch. The Pressure Plate has an increase clamp load for extended life. The disc is dual dampened for smooth engagement and increased transmission life. Premium friction material ensures rapid heat dissipation increasing the life of the clutch. Recommended for spirited and daily driving.
    Stage 2 Daily
    Engineered for HP modifications. This Heavy Duty Pressure Plate has an increased clamp load with little or no increase in pedal pressure. The Organic disc material has a high metal content that increases the co-efficient of friction by two times over a stock lining and increases rotational strength up to a 12,000 RPM burst point. This clutch system maintains a stock feel while offering strength and durability. Recommended usage is daily, street and moderate race.
    Stage 2 Endurance
    An SFI approved single mass flywheel is recommended for this application to get optimal performance. This clutch system is designed for the racing climate. The pressure plate is precision balance for vibration free operation at high RPM. The pressure plate fulcrum is altered for a positive disengagement and a quick shift. The disc is engineered with a Dual Damped design to provide accurate control when accelerating through corners. The friction material is a hybrid using a full face Feramic (Sintered Iron) lining on the flywheel side and a high metal content Organic lining on the pressure plate side. Engagement is positive yet buffered due to the high graphite content unique to Ceramic facings. Recommended uses are daily and street with an emphasis on Rally and Endurance racing.
    Stage 2 Drag
    Drag racing requires a Single Mass SFI approved Flywheel to be included with each kit when the original design is Dual Mass. This system features a Heavy Duty Pressure Plate modified for a puck style disc with no cushion between the linings to keep the clutch pedal travel short and quick. The puck design disc reduces rotational mass and total drive surface area while increasing pounds per square inch on the surface of the friction material. This combination minimizes inertia, accelerating the transfer of torque from the engine to the wheels. The friction material used for this race application is Graphite Impregnated Ceramic. This compound exceeded all other friction materials when testing for durability, reduced chatter, heat transfer and torque capacity. Recommended uses are drag racing, drifting and limited street.
    Stage 3 Daily
    Recommended for single mass flywheel (SMF) when original design is DMF. This clutch package is designed for high HP vehicles desiring a start performance similar to O.E. The pressure plate is Race Engineered (SS) and SFI approved with significant load increase over stage 1,2 pressure plates (+600-800 lbs.). Expect a pedal effort increase of 20%-25%. Discs are assembled with heat-treated wear resistant hubs; drive plates and springs for high load transfer and dependable operation. The sprung centers on the disc in conjunction with the marcel fin between the linings create a dual dampening effect that simulates O.E. start performance. A Performance Organic friction material with a high metal content increases torque and RPM capability and maintains low operating temperatures which reduces wear and glazing. Recommended usages are daily, spirited street and occasional track.
    Stage 3 Endurance
    Recommended for single mass flywheel (SMF) when original design is DMF to achieve optimal performance. This kit uses the same Race Engineered SFI approved pressure plate as stage 3 daily package. The disc is designed for the special needs of a vehicle with circuit racing in mind. Kevlar friction material is used for its unique static to dynamic ratios of friction co-efficient at high energy levels. This translates to a perfect transition from one gear to the next. Discs are assembled with only performance components and equipped with torsion springs functioning as a damper between engine and gearbox. Recommend usages are Rally, endurance race, club sport, autocross, street and daily.
    Stage 3 Drag
    Drag racing requires a Single Mass Steel Flywheel to be included with each kit when the original design is Dual Mass. This clutch package is built to handle heavily modified cars and designed to function according to the specific needs of the ¼ and 1/8th mile track. The pressure plate for this kit is SFI approved Race Cover engineered to disengage with less pedal travel shortening the shift time. Discs are a puck design, which reduces rotational mass and are assembled with all high carbon component pieces for maximum strength. The friction material used is Graphite impregnated Feramic perfectly suited for drag racing because of its maximum friction co-efficient, rapid heat dissipation and abrupt engagement characteristics. Recommended uses are drag, pulling, drifting.
    All clutch kits come with lightweight flywheel, throw out bearing and all hardware needed for installation. Free shipping on all South Bend Clutch Kit orders in the lower 48 states. International shipping also available.
    Ordering:
    All website orders can be done directly through our site. Please just click any of the product links above to go directly to our site.
    Phone:
    Call us at (602) 606 7973 to place an order by phone
    Payment:
    We accept all major credit cards, Paypal, money orders and wire transfers. if you are interested in paying by money or wire transfer, Please call us at (602) 606 7973
    Shipping:
    All orders will be shipped FEDEX.
    International orders are available, please contact us for shipping quotes.
    Hours of operations:
    Monday - Friday from 9AM to 5 PM
    Saturday and Sunday we are closed but http://www.bshspeedshop.com is never closed!
    Contact info:
    Phone: (602) 606 7973
    E-Mail: sales@bshspeedshop.com
    AIM: salesatBSH
  2. Former Advertiser
    Sep 10th, 2001
    Speedshop, Arizona
    06 FSI GT3076R, 10 TSI
    07-27-2010 09:22 PM #2
    The power from this engine is put to the ground courtesy of Southbend Clutch!
  3. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    08-02-2010 02:16 PM #3
    Get away from your dual mass and get the single mass with this kit!!
  4. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    08-04-2010 06:18 PM #4
    1 Day Left in Our Summer Sale!!!
  5. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    08-11-2010 07:33 PM #5
  6. Member Murphyman20thGTI's Avatar
    Oct 5th, 2008
    Worcester MA
    2003 VW 20th Anniversary edition #2082
    08-11-2010 11:08 PM #6
    Looking for stg 3 clutch for a 2003 20th gti O2M 6-spd, Do you have and how much thanks.
    I HAD STAGE 2 SOUTH BEND CLUTCH AND IT WAS GREAT!
  7. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    08-12-2010 01:31 AM #7
    Quote Originally Posted by Murphyman20thGTI View Post
    All Kits are 5% off and free shipping in the lower 48 states!!
  8. 08-13-2010 10:34 PM #8
    Quote Originally Posted by Phil@BSH View Post
    I come to just take a peek cuz the 1.8t thread is dead tonight and damn.... outa curiosity whats the 2 tanks in the front there
    o n im runnin a stg3 on my 50 trim n it rocks
  9. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    08-14-2010 06:28 AM #9
    Quote Originally Posted by weenerdog3443 View Post
    That is our custom catch can for our shop car that has our WOA/KEA turbo kit.
  10. 08-14-2010 07:05 AM #10
    Quote Originally Posted by johna@bsh View Post
    looks nice man
  11. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    08-17-2010 07:13 PM #11
    looks nice man
    Thanks, The bigger tank is the windshield washer res. We relocated it when doing our custom intake.
  12. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    08-19-2010 12:05 PM #12
    The Stage IV Extreme From South Bend can handle over 600 ft/lbs of torque!
  13. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    08-20-2010 04:50 PM #13
    All Clutch Kits 5% off + free shipping!!!
  14. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    08-23-2010 07:54 PM #14
    Always on Sale!!!
  15. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    09-08-2010 02:44 PM #15
    Lowest Price!!
  16. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    09-16-2010 05:49 PM #16
    bump
  17. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    09-23-2010 07:23 PM #17
    Big things coming soon from BSH!!!
  18. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    10-06-2010 01:25 PM #18
  19. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    10-08-2010 01:25 PM #19
    Our first day of the sale, shipping out the door yesterday!!
  20. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    10-11-2010 02:55 PM #20
    When ordering online enter code: vwvortex in the notes section and get a free BSH goodie with every order.
    While supplies last
  21. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    10-12-2010 12:56 PM #21
    "Caught in action" One of our fab guys doing our mani up
  22. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    10-14-2010 01:45 PM #22
    TSI WOA in Development!!
  23. Member anonymous911's Avatar
    Oct 19th, 2009
    West Chester, PA
    '10 GTI 4DR 6M
    10-14-2010 02:26 PM #23
    which clutch is perfect for APR Stage 2 Daily Driven?
  24. Former Advertiser
    Apr 10th, 2009
    10-21-2010 07:23 PM #24
    I think the stage 2 daily is the best all around clutch for a the street cars.
    Call in and we can go over the differences to figure out what is best for you.
    602 606 7973
  25. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    10-25-2010 12:59 PM #25
    Be on the lookout for this weeks opp kicker sale with Snow Performance!!
  26. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    10-26-2010 07:14 PM #26
  27. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    10-27-2010 03:21 PM #27
    All Snow Performance products 15%off til Sunday!!
  28. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    10-28-2010 02:03 PM #28
  29. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    10-29-2010 12:54 PM #29
    Everyone at BSH would like to wish everyone a safe and Happy Halloween!!
  30. Former Advertiser
    Apr 10th, 2009
    11-01-2010 03:21 PM #30
  31. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    11-03-2010 06:28 PM #31
  32. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    11-04-2010 01:59 PM #32
    1 week left in our ROCKTOBERFEST SALE!!!
  33. Former Advertiser Tech@BSH's Avatar
    Jun 15th, 2010
    11-05-2010 03:25 PM #33
    Everyone have a safe weekend!! Last weekend of the Rocktoberfest Sale!!
  34. 11-07-2010 05:20 PM #34
    THose kit are also good for the audi a4 B8?
  35. Member
    Apr 14th, 2010
    LI
    03' Grand Cherokee, 11' B8 S4
    11-07-2010 05:28 PM #35
    nice !
