VWVortex.com - FS: MK2 Jetta Golf AC Components
    Results 1 to 20 of 20
    Thread: FS: MK2 Jetta Golf AC Components
    1. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      1983 Rabbit 16V GTI, 1989 Jetta GLI 16V, 1982 Quantum 1.6TD Wagon, 2001 Jetta TDI, 1982 Caddy Diesel
      07-29-2010 01:39 AM #1
      MK2 Diesel AC Hoses:
      Low Pressure hose. This is the big one that wraps around the back of the motor and hangs off the firewall. I think that nearly all of these came off 1991-1992 ECOdiesels. I'm not sure what the difference might be, but one of the hoses has a longer piece near the bend (see close-up). $45
      High pressure line. This is the one that connects the evaporator (via the expansion block) to the condensor. This is the hose with the sight glass. Again, I think these all came off late 1990+ cars and/or ECODiesels. I am pretty sure the earlier cars are different, but these should work the same, and clear any OEM airbox you may have. $40
      High Pressure hose: This is the one that connects the AC compressor to the condensor. Comes with pressure switches. $30
    2. Member jonny_neffs's Avatar
      Feb 10th, 2010
      Neffs, PA
      82 rabbit p/u
      11-18-2010 08:05 AM #2
      do you have any good Mk2 diesel A/C hoses - mine are very rusted and I am afraid they may have pin holes - I would like to get the A/C working in the spring. if you do can i see some pictures?
      thanks,
      jonny
    3. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      11-18-2010 02:53 PM #3
      Quote Originally Posted by jonny_neffs View Post
      thanks,
      jonny
      I do indeed have some AC hoses. I'll post some pics later.
    4. 11-18-2010 09:40 PM #4
      Do you still have the whole bracket, and do you have all the bolts for it?
    5. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      11-18-2010 09:46 PM #5
      Quote Originally Posted by deere4440 View Post
      Yes indeed. Send me a private message (PM) here on vortex for details. I work with you on a shipped price.
      Or, contact me directly via email at tochtli83@hotmail.com
    6. Member jonny_neffs's Avatar
      Feb 10th, 2010
      Neffs, PA
      82 rabbit p/u
      03-24-2011 07:45 PM #6
      I have an '89 NA and need a High pressure line. I believe mine is similar but back by the connection for the evaporator where it goes into the expansion block I think mine is a flexible hose. Mine is very corroded and i would like to replace as I am going to try to get the A/C going next month.
      thanks,
      jonny
    7. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      11-21-2011 03:01 PM #7
    8. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      01-20-2012 12:24 AM #8
    9. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      02-20-2012 08:41 PM #9
    10. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      03-05-2012 12:20 AM #10
    11. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      04-25-2012 12:20 AM #11
      It's that time of year again...
    12. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      05-11-2012 07:25 PM #12
    13. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      06-16-2012 09:57 PM #13
      Bleep Bleep.
    14. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      08-16-2012 02:20 PM #14
    15. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      11-12-2012 01:52 PM #15
      UP
    16. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      12-08-2012 03:44 PM #16
    17. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      01-06-2013 09:08 PM #17
    18. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      11-05-2013 05:49 PM #18
    19. Member
      Oct 5th, 2004
      Sterling, VA
      2K6 1K2 BRM / 2K8 7L6 BWF / 85 19 MF
      01-13-2014 10:38 PM #19
      Quote Originally Posted by tochtli83 View Post
      <a href="http://s182.photobucket.com/albums/x82/tochtli83/?action=view&amp;current=DSCN4678.jpg" target="_blank"><img src="http://i182.photobucket.com/albums/x82/tochtli83/DSCN4678.jpg" border="0" alt="Photobucket"></a>
      <a href="http://s182.photobucket.com/albums/x82/tochtli83/?action=view&amp;current=DSCN4679.jpg" target="_blank"><img src="http://i182.photobucket.com/albums/x82/tochtli83/DSCN4679.jpg" border="0" alt="Photobucket"></a>
      Are these still available? Is there any PN pressed on the part between the junction and the expansion valve (the one with the valve and black/white cap)?
    20. Member tochtli83's Avatar
      Nov 14th, 2005
      Nash Vegas
      04-22-2015 04:47 PM #20
