Page 2 of 8 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 36 to 70 of 277
Thread: OBD1 motronic tuning thread?
  1. Member Jefnes3's Avatar
    Aug 17th, 2001
    Connecticut
    08-30-2010 08:22 AM #36
    re: Blow thru maf
    Sure this works already. The issue is density error at the maf.
    So, once you able to properly map the fueling, you'll be able to map out the error.
    -Jeffrey Atwood
    Mar 20th, 2010
    Minneapolis
    08-30-2010 06:22 PM #37
    Quote Originally Posted by Ex-ricer01 View Post
    all very intresting, definatley watching. dont quite understand all of it yet but it is something i would like to learn.
    one question though... does this have the potential to convert tunes to blow thru maf tunes?
    To do this by altering the tables is going to be kinda tricky. What I am doing is opening the door for you guys. What you do when you get in is up to you.
  3. Member tomslik's Avatar
    Nov 1st, 2006
    Richmond Hill, ONT
    1984 Jetta, 1992 Golf, 1992 Passat, 1996 Golf, 2007 City Golf
    08-31-2010 07:42 AM #38
    Hey thanks for the post... I need zero to hero help but this is a good start. The beginning of the tread, well that wasn't the English I recognize
  4. Member B4S's Avatar
    Apr 16th, 2003
    Marionville, Ontario, Canada
    1997 Ford Aspire, 1989 Dodge Colt GT Turbo
    10-15-2010 09:24 AM #39
    Back from the dead...
    The software I was talking about earlier now seems to be heading for an update to v.2...complete with M2.9 configuration data already included . Next wed is the day I'll be springing for the update, can't wait!
    Mar 20th, 2010
    Minneapolis
    10-17-2010 08:40 AM #40
    Everyone have your bin file downloaded? Its time to get this party started.
    http://www.easy-share.com/1911398084/ABA_OBD1.bin
  6. Member B4S's Avatar
    Apr 16th, 2003
    10-17-2010 11:37 AM #41
    I'm ready coach!
    Mar 20th, 2010
    Minneapolis
    10-17-2010 12:08 PM #42
    You dont need any of these things yet to learn this and if your tuner already has them you may never need them
    This is the equipment you will need eventually,however most places that have a dyno already have these things.
    BURN2 Chip Programmer [BURN2] - $85.00 : Moates.Net
    This is the ostrich. Most honda tuners now have the V2.0 ostrich so this can be done by them.
    Ostrich 2.0 : The New Breed [OSTRICH_2] - $175.00 : Moates.Net
    And a couple of EEPROMs. I would get two or three of these. Most of your tuning is going to be done with the emulator. Again this is something that most honda tuners already have in stock.
    C2 SST 27SF512 Chip [C2] - $5.00 : Moates.Net
    Mar 20th, 2010
    Minneapolis
    10-17-2010 12:11 PM #43
    Now for the free software that you will need to download.
    here is a good hex editor that will be used for a while to show you the principles of how to do this. Most of the things we will be learning are going to be done automatically by the software that we will be using as well.
    http://www.x-ways.net/winhex.zip
    Here is the main tune software that we will be using.Its called tunerpro and its a configurable software the is specifically for tuning chip files.Its free however I recomend giving the developer some $$$.
    TunerPro and TunerPro RT - Professional Automobile Tuning Software
    Also get your winols demo right here. Its very good for identifying maps.
    Download WinOLS DEMO 1.098 - Free Download Review at Shareware Connection Software Portal, No Crack Serial Number, No Key Warez
    Mar 20th, 2010
    Minneapolis
    10-17-2010 12:14 PM #44
    Before we can do anything we need to know how to correct the checksum. Once you learn how to do this you will be ready to start (kinda).
    Lets start out with the 93-95 OBD1golf/jetta chip file.Everybody get it downloaded and we will start here.
    Now open up your hex editor(winhex) and open up the file.The first thing we need to do is find the checksum and be able to recalculate it.
    The checksum in most motronic chip files is by the file ID tag.This is usually located after most of the code and the maps in the file(we will get to that later).In this case its at CF00 and CF01.The checksum is a 16bit checksum and is the total of the block from 0000-CEFF.If you click edit- define block and type in the 0 for the start of the block and CEFF for the end of the block the hex editor will highlight that part of the chip file.Now you have the block selected to checksum.Click tools-calculate hash.On the drop down pick 16bit and then OK.That will spit out the checksum of the block.You will also notice this matches the locations CF00 and CF01.
  10. Member
    Mar 20th, 2010
    Minneapolis
    10-17-2010 12:17 PM #45
    Ok when everyone gets caught up here we will move forward on how to set this up to do it automatically in tunerpro. I just want everyone to understand what we are doing here first and it give everyone a chance to get used to dealing with what seems to be a bunch of random numbers and letters.
  11. Member B4S's Avatar
    Apr 16th, 2003
    10-17-2010 04:25 PM #46
    That checksum is a pain in the behind, having tunerpro fix it automatically will make tuning a lot easier.
    Mar 20th, 2010
    Minneapolis
    10-17-2010 04:28 PM #47
    Quote Originally Posted by B4S View Post
    Well if you have a good checksum when you start the car you will be fine until you shut it off if you emulate. Then all you would need to do is to checksum when your done tuning,but the easiest way is to have the checksum update everytime you upload.
  13. Member B4S's Avatar
    Apr 16th, 2003
    10-17-2010 04:34 PM #48
    Nice, good to know. I've barely had a chance to emulate any OBD1 cars yet, but the ones I have tinkered with never popped a CEL during emulation...always wondered why. I'll be playing with winhex tonight, thanks for the info!
  14. 10-18-2010 01:59 PM #49
    how does this timing map look for a 8.5.1 compresion vr6t base map if i alter all three 16x1 wot timing maps to the same value
    plus the 4 12x13 timing maps to the same value marked yellow is the peak load areas
    on the stock timing map and lower pic is the lowered timing map example
    im aware i will have to be carefull with det and log timing with vag-com to see if any is being pulled
  15. Member B4S's Avatar
    Apr 16th, 2003
    10-18-2010 02:19 PM #50
    With low compression, I'd say you're definitely on the safe side of the timing at WOT/boost.
    I really love the 'tune-it-yourself' community
  16. 10-18-2010 03:11 PM #51
    Quote Originally Posted by TIGninja View Post
    i find tunerpro only corrects the checksum upon saving the altered bin . then as you say you have then upload the saved bin to the emulator again then all is good no checksum fault code
  17. Member
    Mar 20th, 2010
    Minneapolis
    10-18-2010 07:27 PM #52
    This thread isnt really about tuning theory but that looks decent. One thing to keep in mind is there is another map that is either a 1 by 12 or 1 by 16 that runs full throttle timing. That could pretty easily make for a bad day for you.
    Also your XDF looks good but we need to scale the MAF on to give the flow readings.
  18. Member Daskoupe's Avatar
    Oct 9th, 2006
    941 frying pan
    mk2 coupe,mk4 golf both 2.0hhhhhhhhh
    10-18-2010 07:59 PM #53
    Quote Originally Posted by Jefnes3 View Post
    If you guys want some help just ask.
    Jeffrey Atwood
    United Motorsport
    you wanna do a 660 setup for obd1 2.0's?.I'd love to get some more without changing my setup
    I'll be watching and listening
    12.2@116mph-293whp305wtq 22psi stock aba-AC-DD My Jetta
    Current Want list-sunroof delete,paint
    Fifteen52 - Urotuning
  19. Member Daskoupe's Avatar
    Oct 9th, 2006
    941 frying pan
    10-18-2010 08:06 PM #54
    tig!
    when i click on the winols demo it takes me here?
    what do i click
    http://www.evc.de/en/default.asp
  20. Member B4S's Avatar
    Apr 16th, 2003
    10-18-2010 08:20 PM #55
  21. Member Daskoupe's Avatar
    Oct 9th, 2006
    941 frying pan
    10-18-2010 08:31 PM #56
    having problems finding the checksum.I find the cf00 and then i click and its gone...
  22. Member
    Mar 20th, 2010
    Minneapolis
    10-18-2010 10:05 PM #57
    Quote Originally Posted by Daskoupe View Post
    There should be no need to click on it. Just look at it. CF00 and CF01
  23. Member
    Mar 20th, 2010
    Minneapolis
    10-18-2010 10:07 PM #58
    E64F is the checksum. This is the total of everything in the chip file from zero up until CF00
  24. Member Daskoupe's Avatar
    Oct 9th, 2006
    941 frying pan
    10-18-2010 10:24 PM #59
    alright
    Now what do we do with this tuner thing
  25. Member IHookItUuup's Avatar
    Aug 5th, 2008
    Naples, FL
    MK4 GTI VR6-T, MK2 Corrado VR6-T
    10-18-2010 10:53 PM #60
    lots of info here. I wish this was OBD2.
    MK4 GTI VR6T PT62 C2 630cc tune Peloquin Southbend Stage IV
    http://i168.photobucket.com/albums/u...6/IMG_0856.jpg
    MK2 Corrado VR6T PT6262 Custom SEM AWIC Peloquin Southbend Stage IV
    Under construction: http://www.floridagerman.com/forums/...t=11413&page=2
  26. Member
    Mar 20th, 2010
    Minneapolis
    10-18-2010 11:11 PM #61
    There isnt alot of difference between OBD1 and OBD2
  27. 10-19-2010 11:48 AM #62
    =TIGninja;68043946
    One thing to keep in mind is there is another map that is either a 1 by 12 or 1 by 16 that runs full throttle timing.............we need to scale the MAF on to give the flow readings
    the full throttle 16x1 (wot) timing map is what i have shown in the picture ignition wot map1 there is three in total but only one seems to be in use
    what do you mean by scale the maf to give flow readings ?
  28. Member
    Mar 20th, 2010
    Minneapolis
    10-19-2010 01:46 PM #63
    Quote Originally Posted by magner View Post
    Oh ok I see it there now I cant really see it on my netbook but the rest of the maps look ok. Just keep an eye on knock.
    By MAF I mean the other scale RPM/MAF on your tables. When you do it properly the MAF reading on your tune map will match what the vag com reads.
  29. 10-19-2010 02:35 PM #64
    ok i see what you mean but i think its rpm vs load on the timing and fuel maps with obd2 you can log mass air flow g/s
    but with obd1 i can only log load% and i have no idea of the factor and offset for it
    but i dont need to know the factor to tune with data tracing i can see what area of the map is being use at the given load point and just see what the wideband says then adjust the map to the desired afr while driving.
    if any one is intrested i will try get some vids up of this in action.. there is three fuel maps in use out of them all one is the idle map1 then it switches to the part throttle map1 as you cruise around then when you put the foot down it goes to the wot fuel map at about 60% tps so you have to tune the fueling in three maps
  30. Member
    Mar 20th, 2010
    Minneapolis
    10-19-2010 06:29 PM #65
    Well I will be showing everyone how to set it up in g/s like you are saying. I havent bothered trying to log this either but I know it can be done. I dont have alot of time right now but it is on the list. I dont have a car here to confirm alot of these things so alot of this I am doing from memory. The goal here is to get people going and then let them take over with the development.
  31. Member IHookItUuup's Avatar
    Aug 5th, 2008
    Naples, FL
    11-12-2010 07:50 AM #66
    Any news - I'm still following along....
  32. Member
    Mar 20th, 2010
    Minneapolis
    11-12-2010 01:28 PM #67
    Quote Originally Posted by IHookItUuup View Post
    Actually yes. I just bought a winter beater and it just happens to be a OBD1 2l
  33. Member B4S's Avatar
    Apr 16th, 2003
    11-12-2010 01:45 PM #68
    Sweet!
  34. Member B4S's Avatar
    Apr 16th, 2003
    11-15-2010 02:34 PM #69
    I'm a hair's breadth away from ABA'ing my daily B3 syncro wagon...this would be handy info .
  35. Member B4S's Avatar
    Apr 16th, 2003
    11-29-2010 02:08 PM #70
    G/S?
