VWVortex.com - 01 VR6 Code P0638 Need Help
    Results 1 to 4 of 4
    Thread: 01 VR6 Code P0638 Need Help
    1. Member DiabloKbron's Avatar
      Oct 15th, 2008
      Westchester NY
      01 VR / 95 VR
      08-03-2010 04:53 PM #1
      I have a 01 VW GTI Vr6 with a code P0638.
      STORY: i about a moth a ago my engine blew. so a few days ago i finally put a used engine on to it. the cars was sitting for that long without battery. when i finally started up it came up with a P0638 running at a bout 1000 rpm and not response at the throttle. i called the dealer ship and they told me that the throttle had be aligned. Long story short, they tried to alinged but no luck, the codes comes back on right away.!!. and stills runs at high idle.
      i dont know whats alse to do... i barrowed one from a friend and still does the same..i disconected the cable that goes to the TPS and it makes no diference on how the car runs.!!!
      anyone have gone with this problem ???
    2. Member DiabloKbron's Avatar
      Oct 15th, 2008
      Westchester NY
      01 VR / 95 VR
      08-03-2010 09:33 PM #2
      no one got this problem before??
    3. Senior Member .LSinLV.'s Avatar
      Nov 13th, 2009
      Vegas Bitches!
      12' V6 TDI ........ 00' VR6T ..........72' 914-6.................15' Honda CTX700N
      08-03-2010 09:38 PM #3
      Quote Originally Posted by DiabloKbron View Post
      you need to use a REAL VAGCOM to perform a TB adaptation.
      Larry
      Demokratikally Elekted Minister of Shekels and Cuddles Therapist of the Independent People's Republik of Offtopikstan
      Quote Originally Posted by atomicalex View Post
      The boobs. I am waiting on the boobs here.
    4. Member XSUMZX's Avatar
      Sep 2nd, 2007
      Raleigh-ish
      8P A3
      11-16-2010 12:06 PM #4
      Bump-- curious of the outcome of the adaptation.
