Page 2 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 36 to 70 of 199
Thread: Mk1 1Z/AHU M-TDI
  1. Member funnee84bunny's Avatar
    Jul 30th, 2007
    state of jefferson oregon
    84 300sd
    09-05-2010 09:10 AM #36
    this thread has lots of good starting points....
    http://forums.tdiclub.com/showthread.php?t=142679
    you could start by hammering the dimple into your ps frame rail that you'll need eventually.
    Quote Originally Posted by Skot53 View Post
    Damn you and your odd statehood.
    We'll accept Canadians but draw the line at Texans.
  2. Member funnee84bunny's Avatar
    Jul 30th, 2007
    84 300sd
    09-06-2010 08:41 AM #37
    Quote Originally Posted by A1steaksauce View Post
    i skimmed a few of the diesel swaps and no one was doing this. i know there is zero issue with the alt tensioner fitment in the aba swaps and from what i gather zero issue in the diesel ones as well.
    skimming and reading aren't the same unfortunately. taken from the first thread in the link I posted above. I've seen this swap personally twice, and the clearance issue came up as well.
    Quote Originally Posted by MrDave View Post
    When I put the engine in, I ran into clearance problems with the tensioner for the serpentine belt. A block of wood and a good motivator (read: 2lb sledge) cleared the frame rail for everything to fit.
    http://forums.vwvortex.com/showthrea...ing-the-Engine
  3. 09-06-2010 02:06 PM #38
    reading is for dummies.
  4. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Central Ontario, Canada
    Because MK1
    09-06-2010 06:33 PM #39
    I dunno if it matters or not the Mr.Dave is swapping an ALH? possibly different setup?
    Either way thank-you to both of you, I will most likely clearance that whole lip on the frame-rail anyway to make sure T-belts in the future aren't a hoe.
    Also A1 I think the tails should be straight forward, make a little test to see what plug end wires do what on both, write it down and splice. Just so long as all the harder shhhtuff will match I'm set lol
    I read in a thread about how some guy actually used the entire brake setup from the mk3 and swapped it all over, (pedal cluster, booster, MC the whole works) This is probably more than I need to do though I think.
    I got the axles out lastnight and was planning on having the coolant out too but the axles took a little longer than expected.. so what can you do right? lol
  5. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Because MK1
    09-06-2010 06:42 PM #40
    A1 man, come on! Those were informative posts!! whatthefook.
  6. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Because MK1
    09-08-2010 10:06 AM #41
    anyway,
    i have read that the mk3 drums are a step up over the mk1 stuffs (200mm>180mm), and cross referencing ETKA shows the axle stubs for the two to be the same. So what it looks like to me is that one would only need to swap over the back plate and hardware.. yes?
    Totally upgrading
    Also how do you feel about mk3 seats in an mk1? gotta shorten the seat track.. but its doable. I already have mk2 seats in there.. worth the trouble to go to mk3 seats?
  7. 09-08-2010 05:20 PM #42
    Quote Originally Posted by 8v-of-fury View Post
    Yes, go on.....
  8. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Because MK1
    09-09-2010 11:23 AM #43
    I had to show some mad love to my mk1&2 today, so I did not get ANYTHING done on the TDI
    Mk1 needed a bunch of **** to pass a last minute Certification tomorrow and the mk2 needed brakes all around.. Took up my whole day. fook
  9. Member funnee84bunny's Avatar
    Jul 30th, 2007
    84 300sd
    09-09-2010 10:34 PM #44
    another person to pm about this swap; tongboy. I gave him a mk1 shell he swapped a tdi into...he's all over the pnw forums....
  10. Member RAINWAGEN's Avatar
    Sep 25th, 2008
    issaquah
    80 16v 4dr on megasquirt
    09-11-2010 07:27 AM #45
    I was gunna do the same swap and have decided it was not what I wanted. a 2.0aba16vt should be much more fun.
    a local shop finetuning in Washington has done a lot of tdi swaps u can email them questions thru the site. the owner is building his own big turbo scirocco tdi as we speak 170hp ish ask for cris he's on here too so that's who is talk to
    Mk1 love
  11. 09-11-2010 11:28 AM #46
    Quote Originally Posted by funnee84bunny View Post
    Hmmmmm..... nice.
  12. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Because MK1
    09-12-2010 08:37 PM #47
    Quote Originally Posted by RAINWAGEN View Post
    Don't get me wrong, that sounds a totally richeous engine.. I just hate the inefficiency of gas engines... Anything under 40mpg is heinous and can suck it I had tons of fun with the 1.6 N/A.. almost 2x the HP and almost 3x the TQ... I think I'm still gonna have loads of fun Don't you? lol
    What is needed to be done to make the mk1 axles mate with the mk3 inner cv's exactly? I have read there is grinding needed, I have also read direct swap.. nothing definitive, whats the deal?
  13. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Because MK1
    09-12-2010 11:19 PM #48
    On using the rear brakes from the 98 on the 81.. It looks as though the back plate and actually brake hardware (shoes, springs, bearings) is all that is needed to make the swap, as the stub axle is the same part.
    EGR deletion.. I pulled off the intake tube to have a look and the dreaded blackness is taking over my intake with a litle over %25 i'd say of blocakge.. How is this deleted.. almost looks likt one or two blocking plates on the back of the intake.. Confirmation?
    thanks for reading
  14. 09-13-2010 08:38 AM #49
  15. Member funnee84bunny's Avatar
    Jul 30th, 2007
    84 300sd
    09-13-2010 08:59 AM #50
    yeah, I only met him the day I gave him the car. Super cool cat. I think he ended up putting the tdi in a mk2 though...... he still made it look good in a mk1 though for a bit.
    this was how we met
    http://forums.vwvortex.com/showthrea...no-motor-trans
  16. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Because MK1
    09-15-2010 04:59 PM #51
    how do i delete the EGR?
    Also what is all involved in swapping of the brakes ?? just hardware swapping?
  17. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Because MK1
    09-18-2010 11:03 PM #52
    Anybody??
  18. Member Baron VonZeppelin's Avatar
    Apr 15th, 2008
    CetaneCity, NorthCarolina
    5 old VW Diesels
    09-19-2010 12:45 AM #53
    On the brakes, leave everything together on the backing plates.
    Undo the eBrake cables (adjust them all the way out to create slack), and hyd brake lines.
    Remove the backing plate assys and bolt them onto your 81.
    Hook up the eBrake cables and hyd lines.
    Repack the wheel bearings.
    Bleed, and fine tune the eBrake adjustment.
    The backing plates, drums, shoes, and about half the springs are dfrnt 180 vs 200.
    The upside to 180 is new drums are only $8 each.
    What is the ring&pinion - and the 5th - on your TDI 02a tranny ?
  19. 09-19-2010 03:35 AM #54
    Anybody??
  20. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Because MK1
    09-20-2010 11:24 AM #55
    does anyone know where the Trans ID is o nthe 02A transmissions? I can't seem to figure out what trans I have.. thanks
  21. Member deathhare.'s Avatar
    Apr 1st, 2008
    Isle of Man
    2 stroke
    09-20-2010 11:27 AM #56
    Not sure if this helps but it should be pretty obvious.
    http://forums.vwvortex.com/showthread.php?4684026
  22. Banned
    May 26th, 2005
    o HI o
    84 coupe, 90 b3 td wagon, 81 coupe, BURNT TOAST
    09-22-2010 11:51 PM #57
    i just picked up a $600 98 jetta tdi toady.. i am going tdi-m with it as the current fuel pump = junk..
    i even worked a deal for a landrover tdi pump... rumor is thats the pump to use.. now gotta reserch it and what i gotta do..
    inital install will be into my rusty test bead winter beater 81 coupe.. then after i get it all sorted and such ill rotessery my 84 rust free coupe (and do a full rebuild of the tdi too).. and do it with the 98 style mounts and so on..
    i plan to keep the 02a and hydro set up.. i also plan to keep the ac which is why i am using the 98 style mounting.. rattle free.. vs stock mk1 as ac weighs too much. and the good ac diesel motor mount is NLA.. .
    i put a tdi into a 90 jetta back in 02 for someone.. this one is mine...
    on your brake qustion.. the 98 is a 200mm set up.. you will need to rember this as pree 90 200mm are different then 98 ones.. the back plate is too.. gotta keep them matched up.. but yes they are bolt on... for the fronts.. you best off with a pair of caliper cariers from a audi 4000 quattro.. they are a direct fit.. bolt caliper to them and they fit right onto the mk1 hub/wheel bearing assembly.. no adapters, no screwing around making mk3 ones fit mk1 stuff..
    egr = check engine light... gotta figure out the crack to keep it turned off.. another reason for tdi-m..
    i plan to cut and mod my set up to eleminate it.. else euro intake manifold and block off on exhaust..
  23. Member 2mAn's Avatar
    Oct 15th, 2006
    Seattleish
    E30 Daily & Mk1 Jetta Coupe Project
    09-23-2010 12:51 AM #58
    http://www.dieselgeek.com/servlet/Ca...e+Pipe+%26+EGR
    get back to work...
  24. 09-23-2010 06:12 AM #59
    Anybody??
    Yes.
  25. 09-23-2010 01:58 PM #60
    did you get the harness that goes from the Cluster to the fuse box? easy one to miss..... ask me how i know....
  26. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Because MK1
    09-25-2010 11:28 PM #61
    Quote Originally Posted by crsmp5 View Post
    Yeah TDI in a Mk1 seems like a good power-to-weight ratio. Yeah the stub axles are the same part number right through.. so it seems the backing plates and hardware should bolt right up. Good luck on the M-TDI
    Quote Originally Posted by 2mAn View Post
    Thank you very-much good sir So from what I can gather there is a coolant pre-heater back there as well? All I want to stop is the blow-by going in to the intake.. which do i choose??!!?? lol
    Quote Originally Posted by IronGTi View Post
    I DO! Little harness with a red and white connector. I actually have questions here, I was thinking of doing a full CE2.. but I think it will be too much all at once and un-necessary to do so really. So what I revised was to do A1's piggy backing of the fuse-box, and only run the engine harness and cluster for my swap.. That will really be easiest to me, the cluster and new box will handle the engine and the old box will handle the rest of the inner car stuff.
    I was thinking of the Drive By Wire setup, and some people have had success of using the entire pedal assembly from the mk3. I'll have to rip it to really get a good mind-grip on it.
    OMG I CAN'T WAIT
  27. Banned
    May 26th, 2005
    o HI o
    10-04-2010 03:46 PM #63
    do yourself a favor.. do the ce2.. splice in the lights/heater.... you will want to use the tdi wiprer/turn so you can use the cruise too.. actually.. a mk2 pre 88 cruise turn stalk will also work..
    there is way more screw up ability trying to splice in the engine harness then lights/heater... lights/heater tend to share same color wires even i did ce2 into my 81 coupe.. took me like 4 hours to splice all the fusebox plugs into the original harness just do 1 harness at a time.. have bently diagrams..
    next.. just did a 89 jetta ce2 meld with a 96 passat tdi and 98 jetta tdi harness... aka all ce2.. 1 issue you will find with it all is lack of wiring info on the check engine light.. its missing in the bently...
    if you dewired the tdi properly and reuse all its wiring.. this will be non issue as again.. lights/heat simple..
  28. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Because MK1
    10-05-2010 12:00 AM #64
    Big night last night,
    I got the engine pulled, clutch cylinder out, and the wiring harness and fuse-box out. All that is left is the Drive by wire module, shifter and cables, rear brakes.
    However, I went a little gung-hoe in taking the wiring harness out of the car.. I disconnected almost all the fuse box before i thought to myself.. sh!ttt labels! likely though I thought to myself I am only keeping the engine side of the stuff.. so it shouldn't really be too complicated to get it all sorted out. The only inside car stuff I will be using is mounting the fuse box above the other one (A1steaksauce's method), the wiring up to the cluster, and the wiring to the ignition switch.
    Also a quick question about the rest of the wiring in the harness, I am somewhat strapped for time, as this is being done in my driveway.. and winter is quickly approaching! lol motor in and at least able to be moved around would be good. If I simply just cut off the ends for the stuff I do not use.. (A/c stuff, heater stuff, airbag stuff, door lock stuff, headlight stuff, fan stuff, rear window defroster..) Will it throw any codes from the ECU? or does it mainly just manage engine related stuff on CEL basis? I would love to remove every wire i do not use.. But i feel it would be more set to my time limit to just hack off ends and leave them in the harness.. no?
    If anyone has wiring diagrams for the 1998 Jetta TDI, I would greatly appreciate it!
    I think the only other issue now is.. mounting the clutch cylinder, mounting shifter, and fabbing engine mounts.
    thanks a bunch guys.
  29. Senior Member IronTrap's Avatar
    Jun 14th, 2001
    Gilbertsville, PA
    '50 Dodge Pilot-House, '52 DKW 125W, '76 Rabbit Ocean Bleu X2,EA Cabriolet,'77 Scirocco
    10-05-2010 08:47 AM #65
    get a mk3 bentley. it shows in the bentley what each plug in the back of the fusebox is for. if you are doing the piggyback method, you only need the plugs for the engine harness, the 2 plugs/harnesses for the cluster/gauges, and the power/ground wires. Everything else you can trash. leave all of your stock body wiring in place on the mk1.
    but really, with a swap like this, you need to stop and buy a bentley first and foremost.. some of these questions you are asking would be simply answered if you did a little reading first..
  30. Banned
    May 26th, 2005
    o HI o
    10-05-2010 02:05 PM #66
    instrument cluster not so good to "wire in" i am serious when i say bently screwed the pooch on this.. it really lacks the info you seek.. i am serious..
    http://tech.bentleypublishers.com/th...40723&tstart=0
    and
    http://www.haywood-sullivan.com/vana...ring_LONG4.pdf
    rember i just went thru this this past weekend...
  31. Member lagomorph's Avatar
    Oct 30th, 2000
    PNW
    10-05-2010 02:19 PM #67
    When I did my TDI swap, I mounted the shifter box from the top, to make it sit a little higher on the car,and only had to do minor trimming of the floor and the box to make a good fit. Then ran the cables through the auto trans shifter hole in the firewall. I had to make one hole right next to it for the second cable.
    I used to have pics of how I solved the pedal scenario. I used a 96 tdi passat pedal, and since they use a separate potentiometer from the pedal, I mounted the PT to the firewall, and built a little box to hold it, and then removed the top of the pedal on the passat and welded it to the rabbit pedal. It has a slider adjustment on it to take up a little slack, and then just bent the pedal to suit my needs. I seem to remember that I grumbled about it while doing it, but it's worked fine for 4 years or so.
    I used the whole mk3 wiring harness,fuse box, etc., and mounted the sensor for the interior fan wiring in the vent tube to the passenger side of the dash. Had to splice on a bunch of plugs, but the end result was a massive improvement to the brightness of all the lights on the exterior. IIRC, I ran a 90 cabby rear taillight harness, as it was a direct plug-in to the fuse box. You could use a mk2 CE2 harness as well. I do remember that the dash wiring was a pain to figure out from the bentley, but I went from MK3 to Mk1, if you used a mk2 dash and mk3 cluster, it would be pretty easy to mix/match harnesses and make it all factory.
    I'll try and remember some of the other tricks I did when doing the swap.
    Your internet stance club sucks.
  32. Member daunicorn's Avatar
    Apr 20th, 2005
    Jax, FL
    81 Caddy, 93 cabby (wifes), 09 Ninja, 2011 A3
    10-05-2010 02:39 PM #68
    Watchin this one, like to see how you do your clutch set up. Im going to have to tackle this when I can have my rabbit back with me at my next duty station.
  33. 10-05-2010 03:29 PM #69
    Quote Originally Posted by Hypa-R 1.8t View Post
    same here, really interested. Cheers.
  34. Member 8v-of-fury's Avatar
    Jul 14th, 2008
    Because MK1
    10-05-2010 11:31 PM #70
    and
    Hey man thanks for the helpful links! But I am not simply wiring in the cluster to the mk1 harness, I am wiring it alongside the mk1 harness. I will be keeping all the in car stuff on the old fuse box (ie. cabin fan, interior lights, headlights(relayed), pretty much everything but the engine lol), and running the mk3 fuse box above it with it running the engine, ECU, and cluster.. completely separate from the other fuse box. Search A1steaksauce and his method of piggy backing, a good method.
    Quote Originally Posted by lagomorph View Post
    This I think is gonna be what I will do, as I kinda like the fact of not reaching to the floor to shift gears . I made this mistake in my first mk1, I cut the shifter 4" lol Still driving it and still regretting it lol. Seems a lot easier than mounting it up from the bottom.. plus it will allow a bigger exhaust down the tunnel i would think. At least easier routing.
    It looks as though it won't be too hard to fab something up to hold the DBW unit, and use the stock pedal to pull the cable it utilizes.
    That would be greatly appreciated thank-you!
    I will most likely do what Funksoulkitty or vdubspeed (I think..?) did and fab a bracket on the stock pedal to push the clutch cylinder in.
    Quote Originally Posted by puebla View Post
    Do you have a swap planned as well Puebla?
