VWVortex.com - DPF Delete
    Page 1 of 4 1234 LastLast
    Results 1 to 25 of 76
    Thread: DPF Delete
    1. Junior Member
      Jul 9th, 2010
      Phoenix, Az
      2010 JSW TDI, 2002 tacoma, 2007 prius
      08-04-2010 10:09 PM #1
      So a friend of mine and I have started talking about making a complete DPF replacement pipe. I am wondering who all would be interested in this?
    2. 08-04-2010 10:15 PM #2
      Quote Originally Posted by TheDivineGuy View Post
      it would probably throw codes if you remove it...you will need something to trick the ECM???
    3. Junior Member
      Jul 9th, 2010
      Phoenix, Az
      08-04-2010 10:37 PM #3
      Quote Originally Posted by 53 willys View Post
      Looking into that also!
    4. Member
      Jul 16th, 2005
      05 GTI, 07 Rabbit
      08-05-2010 02:07 AM #4
      I would be interested if it works and doesn't throw codes
    5. Junior Member sjjaskow's Avatar
      Jun 24th, 2010
      2010 Golf TDI 6M CW
      08-05-2010 08:26 AM #5
      Not to be Debbie Downer or anything (although my even saying this is being just that...) messing with emissions control devices is illegal most everywhere in the United States for primary road going vehicles. Unless of course you're building this for track cars
      Why not leave all the DPF gear hooked up, but remove it from the exhaust system? You could trick the ECU into thinking its still there and operational but actually just route the exhaust around it. You could also try creating some sort of dual exhaust with a switch that would route your exhaust through a bigger pipe, but leave the DPF gear installed in case you have an emissions test.
      Thanks,
      Steven
    6. Junior Member
      Jul 8th, 2010
      Jazz blue Mk5 Rabbit 5speed, Rising blue mk6 Golf R:.
      08-05-2010 06:14 PM #6
      Count me in!!!
    7. Member Arne's Avatar
      Jun 27th, 2004
      Eugene, OR
      '16 A3 e-tron, '84 911 Carrera, '10 Mk6 Golf TDI MT6 (pending buyback)
      08-05-2010 06:28 PM #7
      Do we really think that there would be enough performance benefit to notice?
      Current - 2016 Audi A3 Sportback e-tron, 1984 Porsche 911 Carrera coupe
      Pending Buyback - 2010 GOLF 2-DR TDI MT6
      Past - 1978 Scirocco | 1981 Scirocco S | 1986 GTI 8v | 1990 Corrado G60 | 1991 Jetta GLI 16v (bought new in '91, given to son in 2010)
    8. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      2016 MkVII e-Golf, 2017 MkVII Golf Alltrack, 2000 B5 4M Passat Wagon
      08-05-2010 07:53 PM #8
      You can get close to 180hp with a simple ECU tune, DPF intact. Not worth it. Also, the DPF is there for a reason...
    9. Member Arne's Avatar
      Jun 27th, 2004
      Eugene, OR
      08-05-2010 08:08 PM #9
      Well, that's my opinion as well. No particular advantage to not having the DPF that I can see.
    10. Member RogueTDI's Avatar
      Dec 12th, 2002
      USA
      2010 Golf TDI 4DR MT6 SB 1989 AW11 MR2 4AGE 150whp 2250lbs
      08-05-2010 09:21 PM #10
      Quote Originally Posted by Arne-240Z View Post
      I see what you did there.
      On topic, I must concur, removing the DPF is almost certainly not worth it.
    11. Junior Member
      Jul 9th, 2010
      Phoenix, Az
      08-05-2010 10:43 PM #11
      power gain, torque gain and 10-20 mpg? you're right no gain at all! Just google a little bit the tdi dpf removal. It's all over in Europe
    12. 08-05-2010 11:24 PM #12
      Sorry guys, but there is a HUGE advantage to removing the emissions devices. (not just bypassing) they are very restrictive and very heavy. There will definitely be a mileage increase (2-3 MPG conservatively?) a power increase, and also allow you to tune the engine much more without worry about the DPF.
      But, it's also very illegal for on road use, and difficult to do considering the DPF is pretty much tied into the turbo/exhaust manifold (or so I believe, I could be completely off base there)
    13. Member quailallstar's Avatar
      Dec 2nd, 2001
      Ormond Beach, FL
      @LuvGermanCars
      08-06-2010 06:20 AM #13
      Do tell.... Gotta look into this.
      Check this out
      http://chiptuningtools.eu/index.php?...&products_id=3
      DPF removal DP1 VW, Audi, Seat, Skoda - all EDC16 & EDC17 €500.00
      This is module DP1
      Removing of FAP / DPF is easy ! All you need is to read original file from car and process it with proper ECUsafe module, designed to find and remove all important DPF structures automatically, without your attendance.
      File can be then directly written in ECU, or it can be tuned by you and then - written into car. DPF can be removed from car, sensors left unplugged (no sensors at all) or left in the exhaust. It does not matter.
      No more regeneration, no more black smoke behind. No more DPF check light or lamps on the dashboard. Add DPF removal offer to your workshop capabilities !
      Following modules can cover your car range:
      DP1 - VW, Audi, Seat, Skoda - all EDC16 & EDC17 diesels (1.4 TDI, 1.9 TDI, 2.0 TDI, 2.5 TDI, 2.7 TDI, 3.0 TDI, 4.2 TDI, 5.0 TDI etc. )
      - DP2 - Fiat, Opel, Alfa, Lancia, Saab, Chevrolet - all EDC16 & EDC17 diesels (1.9 JTD/CDTI, 2.0, 2.4 JTD, etc.)
      - DP3 - Peugeot, Citroen, Renault, Nissan - all EDC16 diesels
      - DP4 - Ford, Jaguar, Honda, Volvo EDC16 and Siemens SID diesels
      - DP5 - BMW, Mini EDC16 & EDC17 diesels.
      You can buy selected modules from list above or bundle set of all for discount price.
      2Ø16 Golf 7 Variant Highline R-Line Pure-Weiß 1,8 FSI « 2Ø11 Golf 6 2,0 6-Gang DPF 2,0 TDI BLUEMOTION Technologies™ Highline Candy-Weiß 5-Türen« Ø8 Golf 5 .:R32 Deep Blau Perleffekt 3,2 VR6 DSG 4-MOTION™ 3-Türen « Ø6 Golf 5 GTI 2,0 FSI DSG Tornadorot 3-Türen « Ø2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen. I Euro-spec OEM Mods
    14. Member
      Sep 19th, 2006
      WA
      TDI
      10-15-2010 05:36 PM #14
      There are Huge gains after removal of DPF. Power gain, torque gain and 10-20 mpg. The Cheapest way to do this mod would be removing your PDF of the car. Cutting out a section,removing filter material inside and welding it backup. ECU will also need to be modified/re flashed so ECU No longer requests any regeneration, this is what dramatically improves MPG. If you can read the ECU file yourself i can modify your file to delete DPF so there would be no regeneration and not codes thrown for DPF. PM me if anyone is interested.
      examples
    15. Member sfpegasus's Avatar
      Jul 23rd, 2009
      San Francisco
      10-15-2010 05:43 PM #15
      I can see where mileage would increase without the DPF. If you understand how the DPF works, you'd know that raw fuel is tossed downstream to the DPF at just the right temperature to burn all the soot out.
      Imagine if you could use that fuel, for say - driving?
      Here in California we have some pretty stiff penalties for messing with the emissions. I guess I better pass on this mod.
      2010 CW Golf TDI DSG 2DR - Euroswitch - LED tails, turns - Clear corners - GTI sideskirts - Audi stainless tips - Porto alloy spare - Plastic battery box - 9W7 Bluetooth
      2013 RS Golf 2.5 6AT 2DR - Bone stock
    16. Junior Member
      Nov 3rd, 2010
      NC/VA
      2010 VW JSW TDI
      11-05-2010 10:27 PM #16
      PM sent to djeuroalex
    17. Member Ryephile's Avatar
      Jun 1st, 2006
      Metro Detroit
      '92 Turbo Miata, '17 1SS 1LE, '15 Triumph Daytona 675R
      11-06-2010 01:13 AM #17
      I'd be very interested to see what kind of power and efficiency improvements are to be had by nixing the DPF, assuming we can keep the ECU happy of course. Yes I understand this increases stuff leaving the tailpipe, but at the moment I'm just thinking out loud experimentally.
      "This is like O. Henry and Alanis Morissette had a baby and named it "this exact situation"."
      Sterling Mallory Archer
    18. 11-06-2010 04:58 AM #18
      I'm going to tune as far as I can without removing it, and when it clogs or breaks or the warranty runs out, then I'll remove it!
    19. Senior Member Son's Avatar
      Aug 10th, 2000
      Munich, GER
      MY16 VW Golf 1.4 TSI R-Line (prev. owner: VW AG, Wolfsburg)
      11-06-2010 05:44 AM #19
      Can't be arsed to Google, really, but DPF removal is all over in Europe? How do you trick the OBD to believe the DPF is still there. We have both emissions check and OBD check at technical inspections here.
    20. Member Branman's Avatar
      Oct 5th, 2004
      DE
      2017 GTI
      11-06-2010 08:19 AM #20
      A friend of mine removed the Dpf on his 08 f-250 and saw huge gains in power and fuel economy. I dont see why it would be much different for the tdi guys. The Dpf does nothing for the cars performance only hurts it. The Dpf for the environment is a different story but I'm just hitting the benefits of removal.
      11 mk6 gti APR KO4 12.0@119 GoAPR
    21. 11-06-2010 01:49 PM #21
      What I am really hoping is that we can run full bio-diesel with the DPF delete. All the environmental concerns surrounding this issue would then be smashed in my opinion. Please chime in if anyone has experience with the running b20 or above on a newer VW with DPF delete. It would be pretty awesome if I could have over 200hp running off vegetables
    22. Junior Member
      Nov 3rd, 2010
      NC/VA
      2010 VW JSW TDI
      11-06-2010 05:55 PM #22
      Hello guys im a noob here and hope to put in some of my knowledge form what i have researched, i have been a diesel mechanic as a job for over 6 yrs but have just recently got into the computer aspect of vehicle modifications. I also hope to hear alot of advice form the veterans on here too!
      epic designs- From what i have read and understand is that you really cant get the mixture right to get real power out of these little beasty engines because the computer will sense more soot adn heat in the DPF and will actually shut it down on the power and the air/fuel ratio. But without this crap in the computer you can tune it to unbelievable numbers because the computer isnt trying to stop the soot from happening.
      Son- Yes it has been all over europe for awhile now even in other countries. They simply remove the DPF 'file' or program from the ECU because they dont have EPA breathing down their neck.
      Branman- from what i have read searching the net. The EPA has mandated that the DPF is now a smog device on the TDI but wasnt on the trucks a few years back. They (EPA) is now making it tougher for the old saying "off-road" to be used.
      Germangorilla- You would be able to run pure WVO or biodiesel because the DPF will not clog up. That is our limiting factor in using those types of fuel is they dont burn the same way as reg diesel so they gum up the worm holes and other passage ways in the DPF.
    23. 11-06-2010 07:18 PM #23
      Great info Dieselfreak. Thanks for the help, I'm probably gonna wait a couple years or 36 months than do it
    24. 11-06-2010 08:05 PM #24
      I already have a stage 2 malone tune, and its quite powerful even with the dpf system intact.
      The computer doesn't seem to be limiting anything, and the power difference is obvious. Stock, the car could not break traction, and now the ESP light flashes even in 3rd gear under hard acceleration.
      That being said, obviously I am near the limit of power output with the DPF intact. If I sustain full-throttle, high load, after about 20 seconds the EGT limits are reached and the engine reduces power output.
      However, by the time 20 seconds is up I am going way too fast for public roads anyways, so it has only affected long uphill climbs at high speeds on the highway.
    25. Junior Member
      Nov 3rd, 2010
      NC/VA
      2010 VW JSW TDI
      11-06-2010 08:52 PM #25
      Thanks germangorilla. i hear you on the waiting game. I have to wait til its paid off. Its a deal the wife gave me.
      epicdesign thanks for the info. when does your car start leveling out in the RPM range? in stock form mine seems to level out at 3500rpm into almost redline.I have the 6mt and its hard to keep traction on the roads in 1st and second but 3rd HOLY CRAP! I couldnt imagine having that much power and torque.
