VWVortex.com - Build Thread: The Greenland Polo
    The Car Lounge
    Page 11 of 25 FirstFirst ... 78910111213141521 ... LastLast
    Results 251 to 275 of 613
    Thread: Build Thread: The Greenland Polo
    1. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      D2 S8, B5 A4 V8
      09-21-2010 05:21 AM #251
      Great progress
      Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
      Quote Originally Posted by shwak23 View Post
      You could always call your insurance and say that some vandals tried to swap your car to rwd while you weren't looking.
    2. Member NJRoadfan's Avatar
      Sep 16th, 2006
      Northern NJ
      2013 Audi A4 2.0T quattro
      09-21-2010 07:43 AM #252
      Quote Originally Posted by the brit View Post
      1. Put fluid in
      2. Don't build pressure. Just put pedal down.
      3. Bleed air.
      4. Pull pedal up if needed.
      5. Put pedal down once.
      6. Bleed air.
      7. ???
      8. Profit.
      Worth a shot..
      Reverse bleed the clutch using the brake system. http://www.audifans.com/kb/Clutch_Bleeding
      The Nice Car:
      2013 Ibis White Audi A4 quattro 2.0T - Have HEX+CAN VCDS, PM Me
      The Hoopty Beater: SOLD
      1987 Alpine White Audi 4000cs quattro "special build"
      Jul 8th, 2003
      Philly.
      09-21-2010 08:03 AM #253
      hot damn thats a sweet stache.
    4. Member Crispyfritter's Avatar
      Nov 21st, 2001
      SW KS
      09-21-2010 09:17 AM #254
      THat is a sweet stache. Mine grows down when it gets to the sides of my mouth. I would love one that went wide like that.
      Chris
    5. Moderator the brit's Avatar
      Jun 23rd, 2003
      Pottstown, PA
      VW Fox 16v
      09-21-2010 11:44 AM #255
      Posting from somewhere in central PA, just left the DMV headquarters in Harrisburg with the (freaking sweet) plate for the car. More updates later, of course!
      | œ Orchid Euro Importation œ |
      Currently driving or working on too many cars...
      | '93 Fox 16v - PVW | '99 Greenland Polo Diesel | '89 Rallye Golf | '83 Golf GTi RHD | '75 Swallowtail |
      | '82 Caddy 1.9D | '85 VW LT Car Transporter | Mk2 Jetta Limo | '90 Jetta 8V | '96 VW LT35D | '03 SpintLT35 | '02 GTI 337 | '03 GTI 20v |
      | '09 Aprilia RS125 | '81 Kawasaki AR80 | '59 NSU Quickly | '64 Honda Cub C65 + '65 C105 | Trek Emonda SLR9 | Trek Crockett 9 |
    6. 09-21-2010 11:51 AM #256
      That thing in your hand interests me. More specifically, how it got there......
    7. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      12 Golf 2.5, 90 Jetta GLI 16v, 99.5 Cabrio Highline, 92 Golf GL
      09-21-2010 11:56 AM #257
      I'[m glad you went with the Mk3 radio Though tbh, it probably had a B4 Passat (and late mk3) style radio OEM!
      Man oh man i wish i could see/help... I won't even be at H2O this year can't afford a place to sleep haha
    8. Moderator the brit's Avatar
      Jun 23rd, 2003
      Pottstown, PA
      VW Fox 16v
      09-21-2010 12:09 PM #258
      My brothers driving right now
      Nothing difficult today. I transferred the military title months ago, nothing unusual and all very legit. I did not get a tag at that time as I didn't want to keep insurance on a car that didn't have a engine (in most usual circumstances in PA all cars with valid tags must have insurance). I had to come out to the Harrisburg area for some parts for some of my other cars anyway so it's cheaper to get tags directly from Penndot, and you can get cool tags same day too.
      Quote Originally Posted by VDub2625 View Post
      Yeah, I know the late style radio is more correct (although it should be able to tune to odd and even FM stations instead of just 90.5, 90.7, 90.9 etc), but I just like the look of the simpler ones, especially the Blaupunkts. I'm worrying about radios when the car still hasn't driven 12 inches
      For the show, I might have a spare sofa there if you want it. I'd have to ask Ben/Eric too.
      Jul 8th, 2003
      Philly.
      09-21-2010 12:12 PM #259
      yes!
      i love tigers.
    10. Member reddfoxx's Avatar
      Sep 18th, 2005
      CMH OH
      '87 VW Fox wagon turbo, 2014 Cruze
      09-21-2010 12:54 PM #260
      I've just been watching, I just don't have any suggestions to offer. It's a great thread, and a great subject- big power in a small car Hope it's running soon.
      Not red, not blue- red, white, and blue
    11. Moderator the brit's Avatar
      Jun 23rd, 2003
      Pottstown, PA
      VW Fox 16v
      09-21-2010 03:22 PM #261
      Arrived home from the early morning roadtrip and found that the main fuel pump had arrived. Thanks BJ (great seller!).
      In-tank pump is installed (left it out to let the epoxy vent), and the fuel lines back there are hooked up. I also took another look in the engine bay, and there's plenty of room for the main pump so I'm starting to build a little mounting strip for it. The factory fuel line can be cut and reused for it.
      I also just installed the coolant temp sensor and the rest of the hose clamps on the system. It's now ready to be filled so I can try to spot any huge leaks before pressurising it (by hopefully running the engine) later. I'm making a shopping list as I go, so far it has gasoline and distilled water on it..
      I need to sort out a fused 20 amp switched power feed for the pump, and another relay for a couple of other things (injectors etc). I was hunting around for a nice bosch relay with holder, but instead found the factory relay with fused strip from the Polo, which was used for the glow plugs and radiator. Its mounting points are right there on the firewall, so i'm going to use this for everything instead. I'll need to wire it in, and make a little match wire to switch it, but otherwise it should be a nice factory solution.
      I'm studying the wiring diagram and making some pasta for lunch right now
    12. Moderator the brit's Avatar
      Jun 23rd, 2003
      Pottstown, PA
      VW Fox 16v
      09-21-2010 03:50 PM #262
      I'll post this here in case anyone who is a electrical engineer or who is 12 years old and taking basic science in school is reading it.. I do feel dumberer for not being able to remember how to read the schematic..
      Are Pins 1 & 3 the grounds?
      Pin 2 is coming from a ignition switched +12v, which I think it allowing the relay to then be activated by the switched grounds that are controlled by the ECU. I think this is what is confusing me, so just want to double check.
      In other words, to make it a 'dumb' relay (i.e. no ECU control), I can connect pins 1&3 to permanent ground, pin 2 to ignition switched +12v (low amp), then that will give me outputs marked RV and GK as equally amperaged +12v outlets (high amp). And of course pin 30 gets direct +12v from the battery
      edit: Just realised that it looks like:
      Pin 3 is the ground that switches RV
      Pin 1 is the ground that switches GK
      Pin 2 is the +12v that is the master switch for the whole relay.
      So, not that it matters for my purpose, but if 2 = 0, then 1&3 cannot control it; but if 2 = +12v, then 1 or 3 can be on/off independently.
    13. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      09-21-2010 04:12 PM #263
      Why not put the factory fuel pump relay on the fuse block and wire the in from the ECU and the out to the fuel pump where it needs to be?
    14. Moderator the brit's Avatar
      Jun 23rd, 2003
      Pottstown, PA
      VW Fox 16v
      09-21-2010 04:47 PM #264
      One that sits on top of the relay panel?
      I don't have one, and I'd like to give this pump a nice clean install in the simplest / shortest way possible. Please tell me if i'm going mad and my glow plug relay is a terrible idea though!
    15. Moderator rs4-380's Avatar
      Dec 12th, 2000
      Maine
      VWs & Audis
      09-21-2010 05:29 PM #265
      figure out where 51 goes (just find trace 51 and look for the same box marked 46),
      Don't hot wire the grounds on the relay. You do not want your fuel pump ti be ignition switched. If you get in an accident and are incapacitated the fuel pump will continue to run, not to mention if will run constantly if you ever leave the car with the ignition on but engine not running.
      Dave
    16. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      09-21-2010 05:57 PM #266
      The glow plug relay isn't in the fuse box? it's on top?
      Your thoughts on what pin does what are correct (you can reverse the 12v and ground too, and have one ground and 2 switching 12v wires if you want). I wouldn't re-use the glow plug relay, a generic one should be just fine (you have no need for the dual switching, though you could use just half if you wanted). And like the poster said above, hook it to the ECU, you will want it switching off if it needs to.
    17. Member
      May 28th, 2000
      Maple Grove, MN
      8V, 16V, 20V, 30V
      09-21-2010 06:03 PM #267
      Nice project!
    18. Member Burnitwithfire's Avatar
      May 14th, 2005
      Quebec, Canada
      2005 Legacy GT LTD 1992 Miata sunburst yellow
      09-21-2010 07:15 PM #268
      The glow plug relay is a timed relay, it shuts off after a while.
      Quote Originally Posted by SAV912 View Post
      Going to church is bland. Eating vanilla ice cream is bland. Dating somebody from your local Ayn Rand book club is bland. This car makes all of those things seem as exciting as doing 12 lines of cocaine. With Katie Perry. While she's on fire...in Times Square. And you're naked.
    19. Member KahviVW's Avatar
      Feb 26th, 2009
      lurking since 2000
      09-21-2010 07:22 PM #269
      Well now you've forced me to post twice in this thread. Let's setup a import company for east cost distribution.
      TSA got my last bottle, @#$@@$#!
      Quote Originally Posted by rich! View Post
      i'd lock this thread but i have no clue how...
    20. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      09-21-2010 07:27 PM #270
      Quote Originally Posted by Burnitwithfire View Post
      I think on the newer models it's controlled by the ECU. Makes sense from the diagram posted above, the two contacts in the relay are both controlled by the ECU. THough I don't know why there are two banks of glow plugs.
    21. Moderator the brit's Avatar
      Jun 23rd, 2003
      Pottstown, PA
      VW Fox 16v
      09-21-2010 07:28 PM #271
      ECU controlled though, right? Maybe i'll work on a different solution tomorrow, seeing as how no-one else likes my idea..
    22. Moderator the brit's Avatar
      Jun 23rd, 2003
      Pottstown, PA
      VW Fox 16v
      09-21-2010 07:28 PM #272
      So...
      Tuesday,21,September,2010,19:27:03:51206
      VCDS Version: Release 10.6.0
      Address 01: Engine Labels: 058-907-55x-AEBN.lbl
      Control Module Part Number: 8D0 907 557 P
      Component and/or Version: 1.8L R4/5VT MOTR AT D07
      Software Coding: 06051
      Work Shop Code: WSC 00082
      VCID: 3D7AE7201D19
      4 Faults Found:
      17834 - EVAP Purge Valve (N80): Open Circuit
      P1426 - 35-00 - -
      17956 - Boost Pressure Regulation Valve (N75): Open Circuit
      P1548 - 35-00 - -
      17881 - EVAP Leak Detection Pump: Open Circuit
      P1473 - 35-00 - -
      18021 - MIL Control Circuit: Open or Short to Plus
      P1613 - 35-00 - -
      Readiness: 0110 0101
    23. Moderator the brit's Avatar
      Jun 23rd, 2003
      Pottstown, PA
      VW Fox 16v
      09-21-2010 07:48 PM #273
      Quote Originally Posted by WRXGuy View Post
      A small request-- video of it firing up for the first time! Yeah, we live vicariously through ya...
    24. Geriatric Member VDub2625's Avatar
      Jan 3rd, 2003
      Fall River, MA
      09-21-2010 08:35 PM #274
      It lives! Now don't kill it
      And i appreciate the bed offer but we've made other plans already my nice wheels won't be in in time anyway
    25. Moderator vanaman's Avatar
      Aug 26th, 2003
      OhiO
      97 Jetta GLX, 99 Cabrio, 03 Sierra SLE, 97 tracker, 84 ATC200X, 78 CB750F, 66 S90
      09-21-2010 09:32 PM #275
      if you need a nice relay with socket holder look at a napa ar419. i just bought one today for my new fog lights.
      its a 40 amp relay.
      steve
