VWVortex.com - US VW Radio Navigation MFD2 DVD - Auxiliary input (aux)
    Results 1 to 3 of 3
    Thread: US VW Radio Navigation MFD2 DVD - Auxiliary input (aux)
    1. Member JetTurbo's Avatar
      Sep 17th, 2001
      Cincinnati, OH USA
      2012 Golf R, 2008 b6 Passat 4-Motion
      08-05-2010 11:17 AM #1
      This information has been posted on this forum in the past.
      At this point in time I can not access it - this is a re-post to answer an off-topic question in another thread.
      Converting factory aux input supplied with Premium 7 (both single CD and six CD)
      The factory aux connection supplied with the above head units is incorrect for the MFD2 DVD.
      MFD2 DVD has more inputs than Premium 7 (both types).
      The Premium 7 (both types) support Aux -OR- iPod connection (via external CD changer connection).
      The MFD2 DVD supports Aux -AND- iPod connection (via external CD changer connection).
      As a result, the nav's aux uses a different connector that would have no place on a Premium 7.
      To convert for MFD2 DVD, the aux connection needs to be removed
      from the 12 pin blue connector on the back of the head unit
      found in positon # 6
      and moved to a new 18 pin connector (VW PN 7M0-035-727 ).
      Remove the 12 pin blue connector from the head unit, identify pin positions # 2, # 8 and #9,
      and mark the wires in those positions to keep track.
      Disconnect and disassemble the 12 pin blue connector to insert or remove pins.
      The outer shell has ridges molded inside that when slid in place restrict the pins from moving.
      It is a simple disassembly, the inner black pin holder slides out of the outer blue shell.
      There is a release tab on the open side of the blue shell
      red arrow is release tab for the inner pin holder, blue arrow is connector to radio release tab
      and a circular opening on the other side
      Pull back the release tab for the inner pin holder and push a small tool through the hole on the other side
      to release and slide out the inner section.
      Once you have removed the outer shell, use a pin removal tool to extract pins from the holder
      move wires
      from 12p blue connector pin 2 - to new 18p connector pin 2 - AUX Ground (black wire on the kit referenced below)
      from 12p blue connector pin 8 - to new 18p connector pin 11 - AUX Left (white wire on the kit referenced below)
      from 12p blue connector pin 9 - to new 18p connector pin 12 - AUX right (red wire on the kit referenced below)
      More than likely the wire color codes on your factory aux connection will be different.
      To select the Auxiliary input, first select the CD page, and then select the Aux soft key on the lower right
      Reference: US head units, pin assignments for the 12 pin blue connector at position 6
      (items in green US 2007+ Premium 7 only)
      1 - Satellite radio tuner input, audio left
      2 - CD changer, left and right port, audio Ground (GND) or Aux GND
      3 - Satellite radio tuner input, audio Ground (GND)
      4 - CD changer, voltage supply, positive, terminal 30
      5 - Satellite radio tuner input continuous positive, terminal 30
      6 - CD changer, DATA OUT (data exchange for CD changer control from radio system to CD changer)
      7 - Satellite radio tuner input, audio right
      8 - CD changer, left port audio, CD/L or AUX L
      9 - CD changer, right port audio, CD/R or AUX R
      10 - CD Changer, control signal
      11 - CD changer, DATA IN (data exchange for CD changer control from CD changer to radio system)
      12 - CD changer, CLOCK (internal test protocol for monitoring data flow)
      The factory iPod connection is the same for a Premium 7 six disc, Premium 7 single disc and MFD2 DVD,
      plug and play swap.
      If you have a factory iPod connection and want to add an aux input too,
      an inexpensive kit is available from VW,
      VW part number 000-051-444-M - aux cable for DVD navigation head unit
      Reference VW aux install instructions for US MFD2 DVD
      FYI This is the flip side of the instruction sheet in the pic of the aux kit (above).
      The side pictured in the pic is the EU instructions, NOT the SAME,
      EU MFD2 DVD aux uses the blue connector, but different pins
      2102 US Golf R, 2008 US b6 Passat 4-motion - sold 2006 US Mk V bmp GTI mt (230,000 miles/ 7 yrs)
    2. Member JetTurbo's Avatar
      Sep 17th, 2001
      Cincinnati, OH USA
      08-05-2010 11:18 AM #2
      Whenever I post screen shots like the one at the head of this thread,
      I inevitably receive private messages asking how to reach that screen.
      Accessing the MFD2 DVD service menu
      The Service menu on the MFD2 DVD Navigation head unit
      is accessed from the System settings screen.
      Find the Syst. settings screen in your MFD2 DVD
      via [Syst. Settings] soft key found on various settings menus.
      Syst. settings
      Press and hold the [Factory set.] soft key and do not release it
      until the screen changes to Service menu. (about six seconds).
      If you release to soon, you will reset your unit,
      but if the service menu appears, nothing is reset.
      Service menu
      Checking firmware version
      First access the service menu as per above.
      Select [System info] which will take you to the first Version page,
      Version (page 1)
      Select the down arrow soft key on the right
      to reach the second version page
      The firmware version is the last two digits of the entry titled HW - HU.
      In the screenshot below the US firmware version is 47.
      Current US version is 50.
      Version (page 2)
      Note
      The setting displayed at Cntry codes can not be changed in the head unit.
      It is changed in another controller and the nav and radio both use that controller's setting.
      The non-US country setting is what completely disables the nav nag-screen.
      Chalk one up for US tort laws.
      Instrument Cluster Control Module J285 — 5th digit sets country
      Alternately, you can always read firmware version with a VAG-COM
      firmware version highlighted in red
      Address 37: Navigation Labels: 1K0-919-887-MFD2.lbl
      Part No: 1K0 919 887 G
      Component: Navigation 0047
      Coding: 0000101
      Shop #: WSC 01287 785 00200
      No fault code found.
      BTW US firmware revision 47 does play red book audio CDs in the internal DVD drive (nav is disabled)
    3. Member JetTurbo's Avatar
      Sep 17th, 2001
      Cincinnati, OH USA
      08-05-2010 11:18 AM #3
      Another tip that may not be so obvious.
      Under some conditions it may be desirable to turn the nav screen off
      while still using the radio and / or nav.
      The nav voice prompts continue to function with the displays muted of course.
      Press and hold the Day / Night switch (circled in the pic below) until the radio beeps, then release.
      You will see this messge until the screen blanks.
      Touch any nav key on the dash to restore.
      Volume and radio control through the steering wheel buttons
      does not release the screen blanking :thumbsup:
      At night in heavy fog on rural roads or similar conditions
      I will turn off both the nav screen and the MFD
      and crank the rest of the instrument lights to minimum.
