Page 2 of 4 FirstFirst 1 2 3 4 LastLast
Results 36 to 70 of 140
Thread: :: ECS Tuning :: ECS Mk6 Sportwagen Fog Light Kits - Now Available !!!
    Apr 9th, 2007
    DC
    Too many to list here
    02-14-2011 05:03 PM #36
    whats the difference between this kit and the OEM one by oemplus?
    Follow my MK1 build on Instagram. User name: jkrew or http://ink361.com/#/users/322773/photos
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    02-14-2011 05:08 PM #37
    We include an ECS wiring harness with our fog kits, they are relay based and do not tie into the CECM like the OEM harness does. I suspect the kits from OEMplus use a Kufatec harness which may require coding along with pin changes to function properly.
    Apr 9th, 2007
    DC
    02-14-2011 05:50 PM #38
    ahhh gotcha. Thanks
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    02-15-2011 01:14 PM #39
  5. Member Code3VW's Avatar
    May 5th, 2004
    Gilbert, AZ
    '10 CW JSW TDI 6MT
    02-16-2011 11:40 AM #40
    Quote Originally Posted by jon@ecstuning.com View Post
    It also requires a midline or highline CECM depending on whether or not you want the ability to have the oem bixenon headlights installed...
    OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
    Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    02-16-2011 11:48 AM #41
    Correct, the OEM or similar style harness require the correct CECM, coding and possible pin changes to get everything installed and working properly.
    To clarify, our ECS harness will work with all CECM versions and does not require coding changes.
  7. Member Jedidub's Avatar
    Oct 6th, 2010
    Earth
    Magic carpets powered by unicorn turds
    02-22-2011 04:47 PM #42
    Pm sent
    It's ok if you disagree with me, I can't force you to be right.
    2010 JSW TDI
    2011 CC R-line
    2012 Beetle turbo
  8. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    02-22-2011 04:59 PM #43
    PM responded!
  9. Junior Member
    Nov 13th, 2010
    2012 Golf TDI - 2005 Jetta TDI - 2003 Jetta TDI - 2001 Golf TDI
    02-23-2011 06:33 PM #44
    Just ordered mine. Look forward to installing it.
  10. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    02-23-2011 07:34 PM #45
    Thanks for the order!
  11. Member roshlioBG's Avatar
    Nov 4th, 2004
    NNJ
    Top Secret
    02-24-2011 12:54 AM #46
    any link to install steps?
    I just need to see what work is needed to make it work and I'm in... do you have a deal on it with the switch?ziza yellow bulbs ?
  12. Member Code3VW's Avatar
    May 5th, 2004
    Gilbert, AZ
    '10 CW JSW TDI 6MT
    02-24-2011 09:31 AM #47
    The worst part of the install is getting the harness through the firewall...everything else is relatively easy...
  13. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    02-24-2011 03:56 PM #48
    Quote Originally Posted by roshlioBG View Post
    Unfortunately we do not have any install instructions available currently, however as mentioned above, getting the wiring through the firewall is typically the most difficult part. I believe there are a few DIY's that go over running wires from the engine bay into the passenger compartment that may offer some insight.
    Unfortunately we do not have any package deals available, but yellow bulbs are available separately.
  14. Member
    Mar 16th, 2003
    Ft. Bragg, NC
    mk6 bachelor wagen tdi
    02-24-2011 04:11 PM #49
    before I place an order I just want to clarify for my 2011, I would not need to have any VAGCOM or other software changed in order to have these run? thanks in advance.
  15. Member
    Jul 20th, 2010
    WNY
    '10 JSW-S
    02-24-2011 04:13 PM #50
    Quote Originally Posted by MK4Jetta View Post
    The answer was just a few posts up ...
    '10 JSW-S-2.5
  16. Member
    Mar 16th, 2003
    Ft. Bragg, NC
    02-24-2011 04:16 PM #51
    Quote Originally Posted by DoDoubleGeo View Post
    sorry! im head first in one of my law books and gave myself a quick 2 minute break. So I was a tad rushed. thanks again. hope you understand
  17. Member Code3VW's Avatar
    May 5th, 2004
    Gilbert, AZ
    '10 CW JSW TDI 6MT
    02-25-2011 09:01 AM #52
    Obvious brag post is obvious.
  18. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    02-25-2011 11:15 AM #53
    Thanks for the orders everyone!
  19. n00b
    May 30th, 2001
    NC
    2002 Passat Wagon 4M - 2011 JSW TDI 6MT
    03-03-2011 01:58 PM #54
    Well, enough debating/researching- I think I'm ready for my first upgrade. Looks like the chrome euro switch is back in stock.
    PM sent
  20. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    03-03-2011 05:07 PM #55
    PM responded
  21. Junior Member
    Mar 9th, 2011
    Los Angeles, CA
    2011 Jetta 2.5 SE
    03-09-2011 10:49 AM #56
    any chance these would fit on a 2011 Jetta 2.5 SE? I really want fog lights but mine didn't have them stock!
  22. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    03-09-2011 04:01 PM #57
    Quote Originally Posted by vmster10 View Post
    Unfortunately this kit will not fit the sedan models, but we should have kits up for the sedan models here in the next day or so. I'll post up and confirm once the kits for the sedans are up on the website.
  23. Junior Member
    Mar 9th, 2011
    Los Angeles, CA
    2011 Jetta 2.5 SE
    03-09-2011 05:04 PM #58
    Thanks! Looking forward to it!!
  24. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    03-10-2011 06:08 PM #59
    Just got word back from the parts guys, we have things partially built into a kit, but we are waiting for our Mk6 Jetta Sedan to arrive so we can test and confirm the harness. It will be a little bit longer of a wait, but we want to make sure the kit is plug and play like the versions for the other models.
  25. Junior Member
    Mar 9th, 2011
    Los Angeles, CA
    2011 Jetta 2.5 SE
    03-10-2011 11:35 PM #60
    Thanks boss! I'll be checking back soon..
  26. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    03-30-2011 10:48 AM #61
    ECS Tuning
  27. Junior Member
    Mar 9th, 2011
    Los Angeles, CA
    2011 Jetta 2.5 SE
    03-30-2011 11:34 PM #62
    has the kit been built for the MK6 Jetta Sedan yet?...looking forward to it!
  28. Member NotLowEnough's Avatar
    Mar 23rd, 2011
    Blount County, TN and Chatham County, NC
    Mk.6. Mondeo Hybrid. E46 ZHP. Jeep 4x4.
    03-30-2011 11:44 PM #63
    Sweet! Will this be a package deal with the Euroswitch?
    New guys: READ THIS FIRST. | 8V Society: #369 | VW / Audi & BMW Indy Technician (PM for VCDS / GT1 Coding) | I know Jett Daley.
    Quote Originally Posted by LWW View Post
    Gas prices are so high that OJ Simpson and Robert Blake are carpooling as they search for the real killers.
    GirlsLoveIt.
  29. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    03-31-2011 07:32 AM #64
    Quote Originally Posted by JohnIBarr01 View Post
    Unfortunately it will not include the Euro switch, it would need to be purchased separately, partially because there are a few different options on the style of switch.
  30. Member NotLowEnough's Avatar
    Mar 23rd, 2011
    03-31-2011 09:38 AM #65
    Ah gotcha. So I'm assuming they'll be a switch and fog light kit for the 20111 S, then?
    GirlsLoveIt.
  31. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    03-31-2011 09:46 AM #66
    Correct, once we can confirm the wiring harness and fitment of fogs for the Jetta Sedans, we will be putting together a fog light kit that includes the wiring harness. We will also work on getting the available Euro switch options up on the website as well.
  32. Member
    Sep 17th, 2007
    Texas, USA
    04-01-2011 03:30 PM #67
    is there an illuminated indicator light that comes on on the euro switch when activated?
  33. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    04-01-2011 03:53 PM #68
    I can't say I've looked for it first hand, but I believe there should be an icon that lights up on the Euroswitch when the fog position is on. If anyone with this kit installed would like to confirm, please feel free to do so.
  34. Banner Advertiser ECS Tuning's Avatar
    Oct 2nd, 2006
    Wadsworth, OH
    Modified ones
    04-03-2011 05:39 PM #69
    ECS Tuning
  35. Junior Member
    Mar 9th, 2011
    Los Angeles, CA
    2011 Jetta 2.5 SE
    04-07-2011 12:02 AM #70
    ECS Tuning
    Hey Jon, I know that the fog light kit for the Sedan isn't out yet, but when it does come out, will it be approximately the same price as the one you have in the first posting of this thread? Also, will it be an easy install for an average guy like me who doesn't know much about modding cars?
