VWVortex.com - Window Fuse Location?
    Results 1 to 4 of 4
    Thread: Window Fuse Location?
    1. Junior Member BEEF SUPREME's Avatar
      May 27th, 2009
      2005/Audi S4, 2001/VW/Jetta GLX(RIP)
      08-07-2010 12:53 PM #1
      Hi all, i was wondering if someone could point me to the location of the power window fuses and relays in a 2000 passat. I tried searching and came up with nothing. This is my friends car so i haven't had a lot time to look at it, but he did say all of the window fuses in the main box were good yet none of his windows work. Any help would be greatly appreciated. Thanks
    2. Member tryin2vw's Avatar
      Dec 29th, 2006
      Greensboro, NC
      01 B5.5 1.8T; 02 MK4 TDI
      08-07-2010 09:06 PM #2
      If one works, the fuse is good as all are powered by the same fuse. Check for broken wires in the door loom.
    3. Junior Member BEEF SUPREME's Avatar
      May 27th, 2009
      08-25-2010 09:36 PM #3
      i looked under the dash and the 40 amp fuse was good too. all of the locks and sunroof and lights work but there is a clicking in the doors when u try to open/close the windows.
    4. Member skennedy1023's Avatar
      Mar 4th, 2006
      Holland, MA
      1998 Passat GLS 1.8T 5 speed, 2003 Jetta GLS 1.8T
      08-26-2010 12:11 AM #4
      tell your friend to check the CCM and the floor to see if it is wet in front of the driver seat. that could be causing your problems
