Page 1 of 8 1 2 3 4 5 ... LastLast
Results 1 to 35 of 254
Thread: **Manual Timing Belt Tensioner Solution from INTEGRATED ENGINEERING!**
  1. 08-09-2010 06:28 PM #1
    At Integrated Engineering, we have long appreciated the simplicity of the old style mechanical tensioner setup. However, this setup previously had the side effect of decreasing belt wrap on the crankshaft- a common place for the belt to strip it's teeth. We have gone the extra mile to engineer a billet idler roller mount bracket, which will maintain belt wrap on the crank pulley. This will prevent any unnecessary wear on the timing belt, which leads to premature belt failure. It also prevents excess belt vibration between the tensioner and pulley. The manual tensioner will not lose pressure on the timing belt, like the OEM gas-charged tensioners do. This kit is a direct fit for ALL 06A 1.8T engines!
    Features:
    -Great upgrade from faulty OEM tensioner
    -CNC machined in house, from 6061 T6 aircraft grade aluminum
    -No charge red anodized finish
    -Roll formed threads for added strength
    Available in a COMPLETE kit with IE billet idler plate, idler roller, manual tensioner, ContiTech timing belt, and all necessary mounting hardware, including a 4140 steel high strength stud. This is everything you need to convert your 06A 1.8T to a manual timing belt tensioner setup!
    (click below to purchase)
    INTEGRATED ENGINEERING 1.8T Manual Timing Belt Tensioner Kit
    Already have a manual tensioner setup?
    The IE billet idler roller kit is also available. This includes: IE billet idler plate, idler roller, and mounting hardware. This is a great option for you if you already have a manual tensioner setup.
    INTEGRATED ENGINEERING Billet Idler Roller Kit
    INTEGRATED ENGINEERING Your solution for forged connecting rods, forged pistons, valvetrain, and oem parts!
    www.intengineering.com 801-484-2021
    Check us out on Facebook
  2. Member zerb's Avatar
    Mar 18th, 2005
    Highland, NY
    1990 2.0l 20v Audi 90q
    08-09-2010 06:41 PM #2
    awesome fu(king piece. really cool.
  3. Member simon-says's Avatar
    Oct 20th, 2007
    Portland,Oregon
    1978 Miami Blue 16v Rabbit on side drafts, 1980 Jetta Coupe,1988 Vanagon Wolfs., 2003 TDI Golf, and,
    08-09-2010 06:42 PM #3
    Just what the Dr. ordered.
    Good stuff guys!!!
    VW&AUDI Performance Maintenance Repair.
    http://doublejmotorwerks.com/
    Northwest Premiere UnitedMotorsport Software Dealer
    APR Dealer. TDTuning Dealer. VAG-COM.
  4. Member ejg3855's Avatar
    Sep 23rd, 2004
    Rochester, NY
    1989 16v, F250 Diesel, 2001 TT
    08-09-2010 07:00 PM #4
    about a week ago I said to myself, self you should really design a manual tensioner setup that works.
    Then like bahm pete was in my brain.
    HAD - 1991 V8Q | 1990 Jetta 1.6 | 1984 Rabbit 16v | 1990 Audi CQ | 1988 Audi 80 10v | 2005 GTi 1.8T | 1991 GTI 2.0 ABA | 2002 Audi TT S362 |
    HAVE - 2001 TT 180Q F23 wifes | 1989 Jetta VR6 GLI | 2004 F250 PowerStroke |
    Looking for Custom Tuning, Shoot me a PM ! ME7.X !
  5. Member smugfree3's Avatar
    Feb 20th, 2006
    baltimore
    91 coupe
    08-09-2010 07:35 PM #5
    how often do the stock ones really fail
  6. Banner Advertiser pete@integrated's Avatar
    Jan 1st, 2009
    Salt Lake City, UT
    '92 Gti 20v, '96 M3, '10 Shop Van :)
    08-09-2010 08:03 PM #6
    The stock tensioners fail all the time, if you do a little searching.
    Glad you guys like these, we put some work into them to make them really nice.
    .:IntEngineering.com:. .:Facebook:.
    Check out some cutting edge R&D Work on our blog! IE Behind the scenes Blog!
  7. Member dubbin_boho's Avatar
    Dec 3rd, 2007
    NJ
    imola 20th
    08-09-2010 10:20 PM #7
    you guys make awesome stuff
    i'll probably pick one of these up for my motor build
  8. 08-10-2010 01:01 PM #8
  9. Member coolvdub's Avatar
    Feb 19th, 2000
    California City,CA
    '02 Jetta GLS, reigning high mile champ 371,675k miles and counting
    08-10-2010 03:40 PM #9
    Pete,
    Great job as usual, I love the attention to detail you put into this. Most people would overlook the fillet radius at the boss. Great job, no stress risers built into it. Looks like I will be buying this at my next TB change. To bad I just did the TB due to a failed bolt from one of Chris' early kits.
    Don
    CANCER SUCKS but KAISER SUCKS MORE/But so far I kicked it's ASS
  10. Banner Advertiser pete@integrated's Avatar
    Jan 1st, 2009
    Salt Lake City, UT
    08-10-2010 04:07 PM #10
    Ya- thanks! The thread is also roll formed for extra strength-
    Those early studs were unfortunate- the stud we provide is 4140. It cost about 6 times what the other option was, but this is one of those areas where nothing but the best will do. Of course it just uses a spacer and a nut, which ensures it is always loaded in tension rather then bending.
  11. 08-10-2010 04:14 PM #11
    I might consider this next time when i do my timing belt...
    01' BT Jetta
    Disco Potato Club
  12. Banned
    Mar 28th, 2010
    speeding-g60
    E PLURIBUS UNUM
    08-10-2010 05:37 PM #12
    mine should be here today or tomorrow.
    will put up tha PIX when i get it and put it on the new IE stroker motor
  13. Member White Jetta's Avatar
    Mar 17th, 2002
    Massachusetts
    Why don't you take a seat over there
    08-10-2010 10:10 PM #13
    Very nice and about time someone else did this. I have one of the earlier PD Performance kits and heard of the bolts failing. Mine has been fine, asked for a new one, never got it. But that's another story.
  14. Banned
    Mar 28th, 2010
    speeding-g60
    E PLURIBUS UNUM
    08-11-2010 01:50 PM #14
    WOOHOO!!!!!
    so i will put up a few more pix when the head is on and the belt is on.....
  15. Member VRT's Avatar
    Dec 7th, 2001
    Canada
    90 corrado 20/20 haldex, 2003 jetta
    08-11-2010 02:54 PM #15
    No love for the 058 block?
  16. 08-12-2010 03:08 PM #16
    Not yet at least. We'll consider it though.
    Integrated Engineering- Highly developed & engineered engine parts.
    IE Rods & Billet Parts : JE Pistons : Wiseco Pistons : Mahle Pistons : Supertech Valvetrain : Ferrea Valvetrain : ARP
    Hardware : Fuel Injectors & Pumps :
  17. Banned
    Mar 28th, 2010
    speeding-g60
    E PLURIBUS UNUM
    08-15-2010 02:13 AM #17
    so, i like this piece..... its really nice.
    here is a few more shots of it installed, and what it looks like in action on the priming the oil pump vid....
  18. Member CD155MX's Avatar
    Dec 18th, 2007
    SoCal
    20V Mk3 GTI (BT build in progress)
    08-15-2010 03:14 AM #18
    Quote Originally Posted by VRT View Post
    Quote Originally Posted by Dave@integrated View Post
    I would be in for one for the 058 block.
  19. Member
    Feb 21st, 2007
    Hawley Pa.
    08-15-2010 09:50 AM #19
    THAT BELT LOOKS TIGHT? WHAT METHOD DID YOU USE TO ADJUST TENSION KILLER BUILD
  20. 08-15-2010 10:10 AM #20
    def gonna have to get this when it comes time to do my rods
  21. 08-17-2010 01:55 PM #21
  22. 08-17-2010 05:34 PM #22
    Just what I needed, email sent
  23. Member O2VW1.8T's Avatar
    Jul 9th, 2003
    2013 335I, 2012 Tundra 4x4
    08-17-2010 08:37 PM #23
    Will be ordering a kit when i reach 100k. I already changed the belt at 70k but i used ecstuning kit and it looked like knock off parts lol.
    02 GTi 1.8T haldex'd w/35r-SOLD 7.3@102mph 27psi on 93 octane--04 A4 1.8T converted to AWD also- SOLD--'11 JSW Tdi 6speed Manual- Gone--
    13' BMW 335i M-sport EBII
  24. 08-18-2010 12:08 AM #24
    ok having only done one belt on an AWP, how do you get the belt on there with no ability to "un-tension" the tensioner?
  25. Banned
    Mar 28th, 2010
    speeding-g60
    E PLURIBUS UNUM
    08-18-2010 12:20 AM #25
    Quote Originally Posted by Sketchykid View Post
    the manual tensioner is based upon an eccentric center section. you use the tool and you can tighten it.
    the center portion, the bolt hole is not "centered" rather it is off-centered. so when you turn it, it rotates off-center and gets tighter by pushing on the belt.....
    look CLOSELY at the manual tensioner piece..... if you had one in had you would understand better i think.
  26. Member schwartzmagic's Avatar
    Apr 29th, 2007
    MIA
    2011 Jetta TDI; 05 VW Jetta GLI 5857BT
    08-18-2010 12:24 AM #26
    PLEASE make the bracket in black so it'll match with everything else going on my engine, i.e., black an fittings, black tial wg & bov, etc etc etc.... Otherwise I'm gonna have to spray bomb such a beautiful bracket.
  27. 08-18-2010 01:08 AM #27
    We don't have any plans to do them in other colors. You could however buy a raw finish one though and ano it black yourself.
  28. 08-23-2010 09:08 PM #29
    Thank you IE !!!!!
  29. Member zerb's Avatar
    Mar 18th, 2005
    Highland, NY
    08-23-2010 09:21 PM #30
    did someone say black. (powdercoated)
  30. Member
    Jan 8th, 2009
    farmingville,ny
    03 vw gti ...WWW.STEVEBILT.COM
    08-24-2010 06:37 AM #31
    send me one i gave you guys beer
  31. 08-24-2010 12:15 PM #32
    Nice, I like the powdercoat!
  32. 08-25-2010 12:34 PM #33
    Sounds good to me Mike... just send me the other 46 beers first
  33. Banned
    Mar 28th, 2010
    speeding-g60
    E PLURIBUS UNUM
    08-25-2010 12:42 PM #34
    i will beat him to the punch, Dave....
    oh yeah, i am seeing alot of this type stuff on other threads and websites, BTW.
  34. Member simon-says's Avatar
    Oct 20th, 2007
    Portland,Oregon
    08-25-2010 12:46 PM #35
    Damn. that's alot of beer.
    And good pick of the booth.
