Closed Thread
Results 1 to 31 of 31
Thread: Blinker fluid??
  1. 08-12-2010 03:04 PM #1
    I have no blinkers or hazards on my car and have replaced the blinker switch, relay, and fuse. Reading some of the archived posts mention blinker fluid....is this a joke or real? If its real, where can I check the level for it? My only other probable cause seems to be the bulb cassette in the rear according to others that have had the same problem...
    97 Jetta GLS
    May 8th, 2010
    Murrieta, CA
    97 GTI VR6
    08-12-2010 03:05 PM #2
    Wow.
    There is no blinker fluid on your car
    Any car.
    Light bulbs need electricity
    Electricity and fluid dont mix.
    Quote Originally Posted by vento86 View Post
    Welcome to the vortex, where we smash all of your hopes and dreams.
  3. Member vcampg's Avatar
    Aug 24th, 2007
    KansasCity/PNW
    08-12-2010 03:06 PM #3
    this is good
    wtb: great plates
  4. Member Mobius1's Avatar
    Dec 18th, 2004
    NH
    98 porcelain jetta
    08-12-2010 03:06 PM #4
    Quote Originally Posted by 97Ginster View Post
    Wow.
    Any car.
    bwaaaahahaha
    dude make sure its topped off with sae g25 from the mopar parts counter
    Quote Originally Posted by mikey69
    NOW THATS SOME VORTEX FOR YOUR ASS
  5. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    Jahre ABF, A4 B6, R6
    08-12-2010 03:11 PM #5
    Quote Originally Posted by dankvwguy
    They toed my car to the toe yard
    THE CBOX KREW ----Mk3 16V club--------www.AWOL.tv---- STANCE|WORKS
  6. 08-12-2010 03:19 PM #6
    Don't listen to the idiots in here...they're just trouble makers.
    Don't go to the dealer because they overcharge for it. You want to go here to get quality blinker fluid.
    http://kalecoauto.com/index.php?main...&products_id=6
  7. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    08-12-2010 03:24 PM #7
    Listen to tdogg, he's got more posts than everyone in this thread combined
  8. Member Mobius1's Avatar
    Dec 18th, 2004
    NH
    98 porcelain jetta
    08-12-2010 03:24 PM #8
    get off his nuts petter
  9. 08-12-2010 03:25 PM #9
    Wisdom. I posses it.
  10. Member Scorp67's Avatar
    Apr 30th, 2009
    JHB, South Africa
    '00 Mk4 TDi, '96 Mk3 1.6
    08-12-2010 03:25 PM #10
    Quote Originally Posted by tdogg74 View Post
    This, fixed my problems, im now harder, faster and longer
  11. Member csrgti's Avatar
    Aug 18th, 2009
    past Scirocco, Gli16V, Scirocco16v, Cabriolet, present 84GTi,96GTi
    08-12-2010 03:26 PM #11
    If you think your blinkers need fluid you should not be working on your car.
  12. Member Mobius1's Avatar
    Dec 18th, 2004
    NH
    98 porcelain jetta
    08-12-2010 03:26 PM #12
    opulence i has it
    mini-giraffe content
  13. Member effdbmx1's Avatar
    Dec 26th, 2007
    Everett
    95 glx
    08-12-2010 03:27 PM #13
    I only use Redline High Temp blinker fluid because anything else overheats in my car
    I got mine at Pepboys but any auto store should have it. And you can check the level with the little dipstick by the transmission
  14. Member johnbeck4's Avatar
    Nov 17th, 2006
    '99 Daily
    08-12-2010 03:28 PM #14
    got some about a week ago and it does help. ive noticed a major difference. blinker fluid from autozone doesnt last as long as this does.
  15. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    08-12-2010 03:28 PM #15
    Quote Originally Posted by Mobius1 View Post
    1 second nut-swinging and you stopped playing alpine crawler just to comment on it
  16. Member Mobius1's Avatar
    Dec 18th, 2004
    NH
    98 porcelain jetta
    08-12-2010 03:30 PM #16
    i'm hooked on angry birds now
  17. Member PettR's Avatar
    Nov 2nd, 2008
    Norway/Florida
    08-12-2010 03:32 PM #17
    One day I will get it right. One day.
  18. Member
    May 8th, 2010
    Murrieta, CA
    97 GTI VR6
    08-12-2010 03:32 PM #18
    If you are gonna use that stuff, be sure to mix it with some sae g25 like Mobius said to gain optimal performance. That should get you up to 2 million blinks
    And be sure to break the fluid in by driving in the fast lane with your left blinker on for a couple of miles.
  19. 08-12-2010 03:36 PM #19
    I'm thinking all these years of working on these cars and I never heard of blinker fluiid....how can that be?? This can't be real! LOL Anyway, I have no blinkers, the hazard light just lights up and doesn't blink...stepping on the brake makes no difference....any suggestions on what to check next?
  20. Member effdbmx1's Avatar
    Dec 26th, 2007
    Everett
    95 glx
    08-12-2010 03:36 PM #20
    No actually you have to drive with the emergency blinkers on. You wouldn't want to have one side blink more than the other
  21. Member dubsonparade's Avatar
    Jul 3rd, 2006
    Abbottstown, Pa
    1997 Golf 4 door/ 1987 Cabriolet ABA swap/ 2008 civic ex 5speed
    08-12-2010 03:36 PM #21
    Quote Originally Posted by maddhatter1 View Post
    97 Jetta GLS
  22. Member effdbmx1's Avatar
    Dec 26th, 2007
    Everett
    95 glx
    08-12-2010 03:38 PM #22
    Mine failed once and it wasn't the fluid and I read somewhere that you have to go in reverse as fast as you can for about 6.5 miles and it will reset the BCM(blinker control module) it worked great for me
  23. Member filthyillness's Avatar
    Feb 13th, 2010
    North Carolina
    1991 GTI, 1995 GTI, 2007 GTI
    08-12-2010 03:40 PM #23
    no the fukk you didn't!
  24. Member Mobius1's Avatar
    Dec 18th, 2004
    NH
    98 porcelain jetta
    08-12-2010 03:41 PM #24
    this is like in the army when we would tell the new guys that we inventory our mattresses and that he needed to bring his mattress to the officer in charge to give him his mattress serial number
  25. Member
    May 6th, 2010
    Columbus Ohio
    1995 Jetta ABA
    08-12-2010 03:42 PM #25
    Many times if the blinker fluid isn't what's causing the problem, eventually the fault is traced to shoddy muffler bearings. They almost never get greased when you take your VW to a quick-lube joint. Grease them yourself!
  26. Member
    May 8th, 2010
    Murrieta, CA
    97 GTI VR6
    08-12-2010 03:46 PM #26
    Quote Originally Posted by effdbmx1 View Post
    Thats true, good point. I just didnt want to put him in danger, just in case if one blinker overheated and blew up. Blowing up two blinkers would be a disaster.
  27. Member Roketdriver's Avatar
    Jan 23rd, 2009
    Flint, MI
    2001 Passat Wagon
    08-12-2010 03:46 PM #27
    Good luck finding the fluid... I know it's in artificial short supply right now, meaning they have lots in stock but they don't want you to know that so they can jack up the prices. If you go to your auto parts store and they tell you "there isn't any" or something like that, you must DEMAND to speak with the manager and make sure you get that blinker fluid. About a month ago I was driving all over town trying to find a place that had some... as I was walking into the Autozone I saw one employee pull some off the shelf and hide it in the back. Needless to say, I was furious when they told me they didn't have any RIGHT AFTER I SAW THEM PUT IT AWAY. I would have ordered the Kaleco stuff but I didn't want to wait for shipping.
    You can check for leaks by looking under the car.. there will be wet/damp spots under your blinkers. Feel around for moisture, etc. If you find a leak you might need to replace the seals in the housing, or the housing itself.
    Good luck with the blinks
    GOOGLE IS YOUR FRIEND.
    I like grocery getters.
  28. Banned
    Aug 4th, 2008
    Cumberland, RI
    98 Silver Arrow Jetta Vr, 98 Porcelain Jetta Vr (RIP)
    08-12-2010 04:02 PM #28
    This is the best post ever lmfaoo...
    I might have some blinker fluid laying around if u need it . I take paypal
  29. Member johnbeck4's Avatar
    Nov 17th, 2006
    '99 Daily
    08-12-2010 04:06 PM #29
    or if your in a hurry instead of replacing blinker fluid, you could always do the car to plane swap.
    http://kalecoauto.com/index.php?main...products_id=16
  30. Member filthyillness's Avatar
    Feb 13th, 2010
    North Carolina
    08-12-2010 04:09 PM #30
    while your at it, get an exhaust sample too.
  31. Moderator vanaman's Avatar
    Aug 26th, 2003
    OhiO
    97 Jetta GLX, 99 Cabrio, 03 Sierra SLE, 90 XT600, 84 ATC200X, 78 CB750F, 66 S90
    08-12-2010 04:46 PM #31
    no such thing as blinker fluid.
    steve
Closed Thread
