VWVortex.com - How Hard To Weld Aluminum?
    Results 1 to 16 of 16
    Thread: How Hard To Weld Aluminum?
    1. Member iAco's Avatar
      Aug 2nd, 2004
      New York
      VSR, TDI
      08-12-2010 05:00 PM #1
      How hard is it to weld aluminum? I'm looking to get some drilled holes filled on strut tower caps.
    2. Senior Member PowerDubs's Avatar
      Jul 22nd, 2001
      NWNJ
      08-12-2010 06:36 PM #2
      Show caps? Just use a propane torch and some alumiweld sticks. Cheap, quick & easy.
      -Josh
      1-12-5-8-3-10-6-7-2-11-4-9
    3. 08-13-2010 01:59 AM #3
      Quote Originally Posted by PowerDubs View Post
      Easy - when you know how and have some experience.
    4. Member BoostedDubVR6T420's Avatar
      Dec 4th, 2009
      Detroilet, Michigan
      98' GTI VR6-T 98' GTI VR6
      08-13-2010 10:49 AM #4
      Aluminum can be tricky, but with practice it's all a piece of cake.
      98' GTI VR6-T | Stock Block and head, ARP Hardware, C2 Stg.2 Software, 9:1 Comp., 22 psi high boost, (NEW)Precision HP6765, Schimmel Performance SR, ATP Mani., TIAL WG, 3" SS Turbo Back exhaust and DP, Custom IC Piping, Greddy 3" IC and Type S BOV, MSD Coils, NGK BKR7E-11 (Gap .035), BFI stg.2 mounts, Preloquin LSD, Dual Stg. BC, LM-2 Wideband, FK Coils, Upgraded Suspension
    5. Member RedWabbitVR's Avatar
      Feb 28th, 2006
      Lansdale
      13 Passat TDI SEL, 84 Rabbit Convertible VR6, 81 Rabbit Hatch, 81 Rabbit Diesel Caddy, 01 Jetta 2.0
      08-13-2010 04:11 PM #5
      I haven't welded aluminum in 4 to 5 years. my company wants to get me certified in it for some military contracts we want. this is what my first weld looked like
      its not hard, its all in the heat. if I keep on welding alum I'll get back in the swings of things and it will look like stack of dimes again.
      personally I would not use a torch to weld aluminum it doesn't melt like steel does. use a tig machine with an a/c option
      VRSociety #301
    6. Junior Member krazykarlinthekorner's Avatar
      Aug 10th, 2010
      Nashville Tn
      (2) 1990 Corrados, 2001 Passat, 86 Audi 4KcsQ 20v swap
      09-05-2010 05:36 PM #6
      Not hard at all, clean everything well , and practice
      Practice.... Makes perfect.....
    7. Member MikkiJayne's Avatar
      Jan 1st, 2007
      UK
      D2 S8, B5 A4 V8
      09-06-2010 07:07 AM #7
      I saw a program on Nat Geo last night about building the Audi R8, and the whole aluminium space-frame is Mig welded which surprised me
      What sort of setup could they be using for that, and could I replicate it at home? I can't afford a proper Tig, but I can Mig steel just fine. Would they have special Mig machines (HF maybe?), or just spool guns on standard machines?
      Throw an Audi engineer down a hole with a ladder and he will fashion a shovel from it and tunnel his way out
      Quote Originally Posted by shwak23 View Post
      You could always call your insurance and say that some vandals tried to swap your car to rwd while you weren't looking.
    8. Awaiting Email Confirmation
      Aug 10th, 2005
      09-06-2010 02:36 PM #8
      I have a Millermatic 180 and it does steel and aluminium.... http://www.millerwelds.com/products/...c_180_autoset/ They mention the use of a Spoolmate that plugs into this welder and allows you to easily weld Aluminium. I have a buddy with a Tig that does aluminium so I have never bothered to look into this but it looks like a decent Tig with an add-on will do this easily enough.
    9. Member mk2 16v turbo's Avatar
      Apr 2nd, 2006
      SLC
      06 Dakota. 16 Jetta TSI
      09-07-2010 03:21 PM #9
      The MIG machines that weld AL have a Pull/Push type gun. since the aluminum filler wire is fragile, it needs a gun that allows it to flow through the gun cable. These machines are pretty expensive because you need alot of settings to get the weld correct. One example of such a machine is the Lincoln Electric Power-Mig 350MP. It's a multi-process machine, and costs quite a bit.
      What most people do is buy a spool gun, I've worked in a welding shop where I had to weld 1"thick aluminum for an IBM contract, and I did it with a spool gun. They're somewhat annoying, but for the price, you can't beat it.
      Or just take the caps to a local shop, they probably wouldn't charge you too much.
      Power Mig 350MP: http://www.mylincolnelectric.com/Cat...t.aspx?p=18685
      "Cougar" Push-Pull Gun: http://www.mylincolnelectric.com/Cat....aspx?p=104170
      "Python" push-pull gun (this is one that I've used with the 350mp and it's an awesome unit, but it costs insane amounts of money): http://content.lincolnelectric.com/p...ture/e1213.pdf
      And finally, here's a good old spool-gun: http://content.lincolnelectric.com/p...ture/e1221.pdf
    10. Member rwett131's Avatar
      Mar 20th, 2009
      20v
      09-22-2010 11:06 PM #10
      i thought it was just penetration. its a lot thinner than steel and you can get burn through a lot easier. i think haha
    11. Member Lord_Verminaard's Avatar
      Apr 6th, 2004
      Columbus, OH
      1981 Scirocco S, 2008 Audi A3 2.0T, 2005 New Beetle TDI, 1976 Kawasaki KZ400, 02 Ducati 900 Sport
      09-30-2010 04:57 PM #11
      I looked in to welding alu with my Mig, one of my clients is a welding supply store, the guy said that spool guns work the best, but you can usually get a teflon sleeve gun that is also shorter in overall length and use pure argon gas and you are golden. I don't have the money for the gun but I'm going to try it once I do. Luckily my old Snap-On welder uses standard parts.
      Brendan
      '81 Scirocco 'S ...
      '08 Audi A3 2.0T FWD 6MT
      '05 New Beetle TDI Malone stage 2
      '76 Kawasaki KZ400
      '02 Ducati 900 Sport
    12. Member mechsoldier's Avatar
      Aug 14th, 2004
      Seattle, WA
      Supercharged 6 spd 98GLX, Choptop 66 Beetle with Porsche 944 brakes and 5 Speed, 13 Sportwagen TDI
      10-16-2010 11:05 PM #12
      I have the Miller 180 with the spool gun.
      My 2 cents.
      It works but not as good as the tig. It's a spray transfer, so you have to hold the gun far away and the aluminum comes spraying off of it. Hard to explain, but it's kind of hard to direct the transfer. If you push with the gun you'll melt the tip, if you get to close with the tip it'll melt as well.
      That being said, once you get used to it, it's fine. But I've made a couple 2.9 mod manifolds and they look nowhere as pretty as the one shown up above. For dirty metal it makes it a little tough because you get the contamination rising up out of it (just like with a tig). Anyway, I'd prefer to have a tig welder but the Miller with a spool gun will definitely work, it's just a little bit different of a technique.
      Dub Autowerks VW, Audi, Porsche, and BMW parts and service
      1723 West Valley Hwy E
      Sumner, WA 98390
      http://www.DubAutowerks.com
    13. Junior Member dyn0mite's Avatar
      Jul 12th, 2010
      Cambridge, ON, CA
      b5.5 wagon
      11-07-2010 01:47 AM #13
      ive used a spool gun for years working on highway trailers and aluminum headache racks and the like....it is really all in how you set the machine up our spool gun does actually run more like a standard mig, not really spray transfer so it is fairly simple to operate. but a spool gun is definatley the way to go if you cant afford a tig welder =]
      Sometimes you have to hump a few clunkers before you can fondle a ferrari.
      Nothing is impossible, It Just costs more
    14. 11-07-2010 06:59 PM #14
      Things that are aluminum and robotic welded are fed with CNC spool guns. They work well because they are able to measure arc by voltage and can adjust feed height and rate. A hand spool gun is a little sloppy - you have to move nice, have good height, and the stuff has to be CLEAN.
      Welding aluminum via TIG is a little easier to learn on than on steel personally. I can do both decently, but aluminum seems to allow for more mess ups to be honest.
    15. Member
      Jun 3rd, 2007
      Near Chicago
      '88 ITA Scirocco race car & 2012 TDI Jetta 6 sp. manual
      11-09-2010 06:46 PM #15
      Last weekend on the Spike channel there was a program about off road vehicles. The whole program covered welding aluminum with a spool gun, converting a MIG to weld aluminum, and TIG welding aluminum. Covered surface prep, etc. Bottom line is clean the metal before you weld.
