Results 1 to 14 of 14
Thread: APR Presents: Audi B8 A4/A5 & Q5 S3 K04 Turbocharger System!
  1. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    2010 Audi B8 S4 3.0 TFSI 6MT & 2007 VW MKV GTI 2.0T FSI DSG
    08-13-2010 06:45 PM #1
    PR 2.0 TFSI Valvelift S3 K04 Conversion System
    APR's S3 K04 Turbo Conversion is now available for the Audi B8 A4/A5 & Q5 2.0 TFSI Valvelift engine. APR has developed an excellent entry level turbocharger upgrade for the 2.0 TFSI VL engine by incorporating the OEM turbocharger assembly from the Audi S3 and coupling it with APR's expertly recalibrated engine management upgrade. APR's Engineering Team has developed a powerful and reliable turbocharger upgrade that maintains OEM engine bay appearance and offers up to 116 hp and 113 lb ft of torque over the OEM power output of the 2.0 TFSI.
    Reliability, drivability, stealth and enhanced performance that cannot be bested are the highlights of APR's newest OEM-component based conversion package.
    APR's engineers have expertly recalibrated the engine management system to allow for nearly flat torque delivery from 2800 RPM to 5000 RPM which results in a smooth linear pull throughout the power band. Keeping the track enthusiast in mind, this conversion package will not result in overpowering of the driveline but will allow for smooth acceleration to easily maintain control while cornering.
    The Borg Warner K04 turbocharger selected by VAG engineers is perfectly sized for the 2.0 liters of displacement to allow for stout horsepower numbers as the RPMs increase with no dramatic fall off as redline approaches. This ensures plenty of power in the high RPMs for continued acceleration in the straights and positioning at the healthiest portion of the power band after corner exit.
    S3 K04 Conversion Package
    Optional OEM Exhaust Compatibility
    While a full exhaust is recommended for maximum power, If you're in a situation where running a high flow exhaust is not permissable, APR has also developed software specificly to use with your OEM Exhaust system. You may switch between high flow exhaust software or OEM exhaust software free of charge any time you alter your exhaust system.
    APR's Patented EMCS Technology
    Featuring APR's Patented EMCS program switching functionality and DirectPort Programming, APR's Engine Management Calibration for this conversion package allows for a range of Octane and situation specific calibrations to be installed simultaneously on your vehicle's ECU. These programs and features are able to be cycled through via your existing factory cruise control and activated in less than 20 seconds. You will be able to choose 1 to 4 Programs listed below. You will also be able to add APR Security Lockout, APR Fault Code Erase and APR Anti-Theft features.
    Programs*
    Stock - OEM Operation
    212 HP
    267 LB-FT
    APR 91 Octane (R+M)/2 or 95 RON
    Power Figures TBA
    APR 93 Octane (R+M)/2 or 98 RON¹
    313 HP
    367 LB-FT
    +116 HP @ 5550 RPM
    +113 LB-FT @ 4950 RPM
    APR 100 Octane (R+M)/2 or 104 RON
    Power Figures TBA
    APR Valet
    *It is essential to ensure your vehicle is filled with at least the minimum octane rating for each Performance Calibration when activating the program.
    ¹Figures measured using Stock Intercoolers, Stock intake and APR RSC Turboback Single Exit Exhaust System.
    Power Figures
    NOTE Do not be fooled by claims from lesser tuners, a transmission reflash IS NOT Required to achieve the advertised power claims with an APR ECU Upgrade.
    Components
    APR includes all hardware and software needed for a painless install.
    - APR DPP ECU Upgrade Specific to the S3 K04 Turbo Conversion
    - APR Audi S3 K04 Turbocharger Assembly
    - OEM Manifold Gasket & Nuts (5x)
    - OEM Exhaust Gasket, Bolts (3x), Washers (3x) & Nuts (3x)
    - OEM Downpipe Gasket, Studs (4x) & Nuts (4x)
    - OEM Turbo Oil Gasket
    - OEM Turbo PCV Flange Gasket
    - OEM Engine Oil Gasket
    - OEM Vacuum Line Crimp Clamp
    - OEM PCV Crimp Clamp
    - OEM Crush washers for Turbo Oil and Coolant Connections (10x)
    Stealthy OEM Appearance
    APR's S3 K04 Turbocharger Conversion System is constructed from OEM parts and appears OEM. It's easy to install and 100% reversable. Every OEM part is fully Plug and Play:
    - Intercooler (Upgrade Recommended)
    - Exhaust (Upgrade Recommended)
    - Intake (Upgrade Recommended)
    - Diverter Valve
    - Positive Crankcase Ventilation Lines
    - EVAP Lines
    - Coolant Lines
    - Oil Lines
    - Turbo Support Brace
    Installation can be performed at APR Dealers and all parts necessary for the installation except for fluids are included. For best results APR highly recommends the APR RSC Turboback Exhaust System.
    Application Guide
    North America:
    B8 A4 Sedan & Avant - 2.0 Valvelift TFSI - 6MT & Tiptronic - Quattro
    B8 A5 Coupé & Cabriolet - 2.0 Valvelift TFSI - 6MT & Tiptronic - Quattro
    Part Number - T2100009
    Price - $3,499.00
    Buy One Now!
    Rest of World:
    B8 A4 Sedan, Avant & Allroad - 2.0 Valvelift TFSI - 6MT & S Tronic - FrontTrak & Quattro
    B8 A5 Coupé, Sportback & Cabriolet - 2.0 Valvelift TFSI - 6MT & S Tronic - FrontTrak & Quattro
    Audi Q5 - 2.0 Valvelift TFSI - 6MT & S Tronic - Quattro
    Part number - T2100009
    Price - Please Contact Your Local APR Importer for Pricing
    Because of high horsepower and torque ratings, APR cannot recomment use with Audi Multitronic CVT transmissions.
    GoAPR.com | Facebook | YouTube | Twitter
    Phone: (800) 680-7921 Local Phone: +1 (334) 502-5181 Fax: +1 (334) 502-5180
    Address: APR LLC, 4800 US HWY 280 West, Opelika, AL 36801
    The bitterness of poor quality is remembered long after the sweetness of low price is forgotten.
    Mar 10th, 2009
    2006 Passat 2.0t 6mt
    08-13-2010 10:01 PM #2
    Not to much difference in performance then a FSI or TSI K04 setup for having such an expensive head design.
    for building the kit though.
  3. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    08-13-2010 10:17 PM #3
    Quote Originally Posted by Boosted2003! View Post
    I don't know if I would necessarily say that primarily because each system was compared on different drivetrain's and transmissions. Estimating crank figures between 6MT, Tiptronic, Quattro and FrontTrack is a bit difficult. Some may say we are selling ourself short as we have chosen to report crank figures on the B8 with a rather low drivetrain loss but I personally feel more comfortable erring on the side of underestimation rather than overestimation.
    Once we start seeing more of these in the field on multiple dynos and such I'm sure you'll find the new VL head is producing slightly higher figures than it's non valvelift cousin.
  4. Member
    Mar 10th, 2009
    08-13-2010 10:33 PM #4
    Quote Originally Posted by Arin@APR View Post
    Understandable..
    Does the VL head flow less then a non-VL head?
  5. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    08-13-2010 10:39 PM #5
    Understandable..
    I don't think so. I'll check with engineering on monday for some numbers.
  6. Member
    Mar 10th, 2009
    08-13-2010 11:01 PM #6
    Just noticed this motor makes more torque then non-VL head but less HP. I know through cam timing that can be changed and valve lift in the case too but I am sure you all maximize everything to a safe limit as always. So I was thinking maybe there is a limiting factor in the system somewhere.
  7. Junior Member Atl337's Avatar
    Jun 24th, 2002
    Marietta, GA
    2010 Audi A4 Avant S-Line
    08-16-2010 05:56 PM #7
    Arin,
    You mentioned intercooler, exhaust and intake are all recommended. However, I can't find pricing or descriptions of any of that stuff.....either on here or on APR's website. All the tests include the exhaust, but if you don't actually SELL the exhaust how would one go about achieving those numbers?
    Quartz Metallic Gray
  8. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    08-16-2010 06:00 PM #8
    Quote Originally Posted by Atl337 View Post
    Arin,
    The exhaust system will be on sale pretty soon.
    We do not have an intercooler system yet but we do have an intake on the way. When I say I recommend them it's because I do. A properly designed intercooler system will absolutely lower charge air temp and increase HP or keep it longer. The same goes for a properly designed intake system as it will increase mass air and allow for better results.
  9. Member dnaks's Avatar
    Apr 3rd, 2005
    The heart of Oahu(Honolulu)
    VW GTI 1.8T '04 /VW R32 '04 /Audi A3 2.0T '08.5 TSI /Subaru STI'11/ VW GolfR '13
    08-22-2010 09:55 AM #9
    What about this TSI KO4 kit from you APR for the A3's?
  10. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    08-23-2010 04:04 PM #10
    Not ready yet!
  11. Member Ricky Bobby's Avatar
    Sep 29th, 2005
    Martinsville, NJ
    2003 X5 3.0i 5SPD, 07 SV1Ks
    08-23-2010 05:16 PM #11
    Not ready yet!
    I'm assuming when the kit is ready it will be utilizing stock intake (and/or aftermarket) like this setup for the B8 audi does? if so thats friggin sweet, since i could upgrade to k04 and not have to buy new hardware (already have s3 intercooler and 3" TBE)
  12. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    08-23-2010 05:43 PM #12
    Quote Originally Posted by Ricky Bobby View Post
    Yup, we are looking to make it compatible with everything as if it was still the OEM unit.
  13. Member Zwei Bora Tdi's Avatar
    Apr 23rd, 2004
    Colorado Springs Colorado
    2012 Audi A4 Avant Prestige with Titanium Package
    04-27-2012 11:02 PM #13
    Arin,
    Any issue with the B8 Tiptronic models?
    I have an 8 speed Tip and understand this similar ZF Transmission is in the Jaguar and Maserati and Porsche?
    Will pull the trigger when given the
  14. Forum Sponsor Arin@APR's Avatar
    Jul 29th, 2008
    Auburn, Al
    04-28-2012 12:48 PM #14
    Quote Originally Posted by Zwei Bora Tdi View Post
    Arin,
    We've installed this on a couple in house tiptronic cars w/o any issues.
