Results 1 to 27 of 27
Thread: Why bypass the N249?
  1. Member mk2michal's Avatar
    Sep 25th, 2009
    Montreal, Qc
    MK2 Jetta / GTI 1.8t
    08-14-2010 08:20 AM #1
    I heard people bypass the n249 but I dont understand why. Could you guys please give me a little briefing and also is it recommended if you want to chip your car with unitronic (or any other company)
  2. Member alextjoe's Avatar
    Aug 7th, 2008
    Montreal,Quebec
    MK2 Golf 20vT
    08-14-2010 09:19 AM #2
    most people do this to clean up the engine bay and mostly the top of the engine...i removes most of the vacuum line clutter and the big vacuum reservoir on the of the valve cover..
    people also say that the DV response is much quicker and stronger as after removing all this junk it is hooked up to a direct vacuum source...
    i wouldnt know if there was a difference i removed the n246/SAI/Combi valve/All the EVAP lines and the vacuum hard lines before putting the motor in my mk2..
    but its is much cleaner looking!
  3. Banned dubinsincuwereindiapers's Avatar
    Jan 16th, 2008
    InYourMom
    Bugatti Veyron
    08-14-2010 09:22 AM #3
    DO IT.. no negative effects to be had.. From experience, im positive that mine reacts faster..
  4. 08-14-2010 09:55 AM #4
    Quote Originally Posted by dubinsincuwereindiapers View Post
    sooo happy i did mine... it also makes it a ton easier trying to find boost leaks when you just have a couple hoses compared to 30 billion that come stock
  5. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    01 Jetta Wolfsburg Ed, 92 Honda Prelude Si JDM H22 Swapped
    08-14-2010 09:59 AM #5
    i took all that ish out my engine bay and its so much easier to work on and you can see whats really going on under the hood without all the extra clutter
    My Thread Fk AK Coilovers, Full 3" Exhaust, Custom FMIC, Forge Evo14 BOV, Forge Unos MBC, Forge Throttle Body Hose, GodSpeed Aluminum Radiator, Prothane Dog Bone Mount, BFI STG 1 Eng/Trans Mounts, Sachs VR6 Clutch Kit, TT Short Shifter, Siemens 630s, Walbro 255, DBB Garrett 50 Trim Turbo Kit, Eurodyne 630cc MAFLESS PAGPARTS FTW -- STEVEBILT.COM -- Integrated Engineering -- FourSeasonTuning.com Don't Buy Anything From *ChunkyPeanuts*
  6. Member mk2michal's Avatar
    Sep 25th, 2009
    Montreal, Qc
    08-15-2010 10:45 AM #6
    you guys have a good like with picture how to bypass the n249?
  7. Member alextjoe's Avatar
    Aug 7th, 2008
    Montreal,Quebec
    MK2 Golf 20vT
    08-15-2010 10:52 AM #7
    i dont have pics of how to bypass it....im really not sure what you mean by bypass it..do you mean just unplug and route a direct vacuum line from intake manifold to to DV or do you want to physically remove the entire n249 system???
    anyways here is the link to do all of this
    http://forums.vwvortex.com/zerothread?id=3111538
  8. 08-15-2010 11:01 AM #8
    The N249 is used by the ECU to dump boost through your DV when it senses an overboost situation coming or is in effect.
    The main reason in bypassing the N249 is to prevent this from happening, Since most the people in this forum are running elevated boost levels and want more boost/power taking this control away from the computer is a good thing.
    In order to accomplish this task your DV is hooked up to a vacuum reservoir along with the N249(this is because you need vacuum to open a DV and if your engine is in boost your obviously not producing vacuum) This reservoir is just another space that has to fill up before the vacuum source actually gets to your DV to open under normal conditions.
    So a secondary benefit to bypassing the N249 and this reservoir is a quicker response time(were talking milliseconds here) in the valve opening. not only that but since there is a direct line of boost going to the top without the reservoir the valve is also shut faster when you get back on the throttle between shifts. It gives a more direct feel to the car between shifts and when you get on it from a constant roll(I.E passing someone on the freeway)
  9. Member sounrealx's Avatar
    Apr 3rd, 2007
    Brandon, Florida
    01 AWD Turbo Jetta
    08-15-2010 11:04 AM #9
    it's basically a solenoid that the ecu uses to decided whether or not the dv has vac pressure, and therefore can hold boost. If you take it out, the dv will function off of true vacuum pressure in the manifold. The n249 bracket also holds the n112, which controls the SAI pump. If you don't plan on removing the SAI, you should leave the n112 in there.
    http://uk-mkivs.net/forums/t/265883.aspx <-- here's a guide to bypass the n249 and leave in the n112
  10. Member WOB.018t's Avatar
    May 29th, 2007
    MEDFORD LAKES NJ
    08-15-2010 12:32 PM #10
    Quote Originally Posted by Big_Tom View Post
    the ultimate VTA set-up
  11. 08-15-2010 12:41 PM #11
    Quote Originally Posted by WOB.018t View Post
    how mines runnin too
  12. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    08-15-2010 02:44 PM #12
    LOL VTA? vent to atmosphere im guessing?
  13. Member WOB.018t's Avatar
    May 29th, 2007
    MEDFORD LAKES NJ
    08-15-2010 04:49 PM #13
    thats exactly right.
    what do you have on the breather port on top of the filter housing?
  14. Member
    Apr 19th, 2005
    Vancouver, BC
    00 GTI 1.8T
    08-15-2010 05:25 PM #14
    Quote Originally Posted by sounrealx View Post
    Thanks for sharing this link! I've been meaning to delete some vacuum accessories but I wanted to retain the SAI to prevent any fault codes.
    Is there a better location to tap into for the DV's vacuum line? I already tapped into the FPR's vacuum line for my boost gauge and thought it would be ideal to use another source for the DV.
    projectsatin: malone tuned K04 1.8T with methanol injection
  15. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    08-15-2010 11:00 PM #15
    ^^^ just tee off one of the other 2 or three lines coming off the manifold. my car didnt like sharing a boost gauge, dv, and the fpr on one line. now my dv has its own line str8 off the intake manifold
    i just have a 90 degree bend down and a hose that runs str8 down to the ground. looks much cleaner
  16. Member
    Apr 19th, 2005
    Vancouver, BC
    00 GTI 1.8T
    08-17-2010 08:00 PM #16
    What a clusterf*ck of vacuum lines. I bypassed the N249 and kept the N112 for the SAI. Managed to ditch all the hardlines as well by running the DV off the intake manifold and combi-valve directly to the N112.
  17. Member mk2michal's Avatar
    Sep 25th, 2009
    Montreal, Qc
    08-18-2010 08:42 PM #17
    Quote Originally Posted by bootymac View Post
    That all you got rid off when you took off the n249?
  18. 08-18-2010 08:54 PM #18
    Quote Originally Posted by mk2michal View Post
    you should see what he took out when he removed the motor
    When i did my turbo install and removed all the crap under there I ended up with bout 6 plastic bags of crap that i took out
  19. Member Big_Tom's Avatar
    Aug 19th, 2007
    Orlando, FL
    08-18-2010 11:32 PM #19
    i had 2 walmart bags full of stuff!
  20. Member
    Apr 19th, 2005
    Vancouver, BC
    00 GTI 1.8T
    08-18-2010 11:41 PM #20
    Yup, most of them were vacuum lines going to the N249 valve. The hardlines were removed because I ran new vacuum lines for the DV and combi-valve. It's much cleaner and much more simpler now
  21. Member sounrealx's Avatar
    Apr 3rd, 2007
    Brandon, Florida
    01 AWD Turbo Jetta
    08-19-2010 10:52 PM #21
    I had mine t'd off the fpr for a while and it messed up my fuel trims, so i bought a vacuum manifold which worked fine. i Then deleted the rest of the stuff under there so i got a free port on the intake manifold. If you want to go the vacuum manifold route, I can sell you mine.
  22. Junior Member Marcio's Avatar
    Sep 4th, 2009
    São Paulo - Brazil
    B4 Passat VR6 - B6 WAGON TSI
    08-20-2010 11:54 AM #22
    what if i just put a T line on a vacuum line, maybe the FPR direct to the DV, and than close somehow the original hose that goes do the DV?
    isnt it going to be bypassing the n249 same way?
    thanks.
  23. Member steve05ram360's Avatar
    Aug 14th, 2006
    Elk Grove CA
    2000 Audi TTQ
    08-20-2010 04:55 PM #23
    Yes, plug the disconnected hose. This is what I did and it works great
  24. Member ornithology's Avatar
    May 6th, 2009
    Vancouver, BC
    2004.5 MKIV GLI O2M
    03-01-2011 02:57 AM #24
    what a clusterf*ck of vacuum lines. I bypassed the n249 and kept the n112 for the sai. Managed to ditch all the hardlines as well by running the dv off the intake manifold and combi-valve directly to the n112.
    yo! Diy plz bootay
  25. 12-30-2011 02:21 AM #25
    nvm
  26. Member Slimjimmn's Avatar
    Apr 8th, 2006
    Rosemount, MN
    02 GTI 1.8t
    03-13-2012 12:33 AM #26
    there is a reason vw went to electrical diverter valve...
    the car is on an inclined driveway and up on jack stands in the front only
    VW's don't leak oil, they just mark their territory!
    Master L1 ASE certified
  27. Member rains's Avatar
    May 30th, 2008
    Sherwood Park
    2000 GTI [1.8t], 1993 Jetta [ABA-T]
    03-13-2012 01:57 AM #27
    My car is quite a bit happier sans N249. My diverter valve is quite a bit more responsive, holds boost properly (as opposed to when-it-felt-like before), and it makes a 'better' noise now.
    Now, mind you, half the hoses to my N249 were cracked, so it's not like it was 100% when I pulled it out.
    Here's all I pulled out (not just the N249, the SAI, and emissions too)
    This thread is now about car cakes.
