VWVortex.com - DTC: P2181 - Cooling System Fault
    Results 1 to 4 of 4
    Thread: DTC: P2181 - Cooling System Fault
    1. Junior Member
      Jun 23rd, 2009
      Central Massachusetts
      02 Mazda PR5, 03 VW Jetta 2.0L, 69 Ford Bronco, 94 Saturn SC-1, 1993 Subaru Loyale 1.8L
      08-16-2010 07:27 AM #1
      I have a 2003 Jetta with 100, 247 miles on it.
      Just the other day, the MIL came on. I plugged in the Scan-Tool and retrieved the codes:
      P2181-Cooling System Fault.
      I have heard that usually this code can be set because of a thermostat that isn't working properly. For instance, the engine is taking to long to warm up.
      Could this could also be set if the Cooling Fans aren't operating properly?
      What I noticed yesterday was that the Large Fan on the drivers side was not turning on...at all.
      However, the smaller fan was turning on at 206 degrees F & when the A/C is commanded on.
      I checked fuse # S180 (green one on top of battery) and the fuse is intact.
      Is the Cooling Fan a common failure? Or...should I be investigating the Climate Control Module?
      Thank You for any Insight.
    2. Junior Member chrisf608's Avatar
      Jun 28th, 2010
      WI
      2001 Wolfsburg
      08-16-2010 02:31 PM #2
      I bet the waterpump is getting ready to go. possible its the thermostat.
    3. Junior Member
      Jun 23rd, 2009
      08-16-2010 06:47 PM #3
      I am days away from doing the T-Belt/Water Pump. Just waiting for parts.
    4. Junior Member
      Jun 23rd, 2009
      08-16-2010 07:51 PM #4
      Drivers side cooling fan is not operating.
      Could that set DTC - P2181?
