Results 1 to 14 of 14
Thread: forge DV spacer leaking oil?
  1. Member demolition86T1's Avatar
    Jul 5th, 2004
    New Jersey
    2010 GTI, 01 VR6 GTI, 92 cabrio
    08-20-2010 05:22 PM #1
    looked under my car today and found oil all under every thing surrounding the DV... does any one know if its because i have the DV spacer? sorry for the crappy pics
    IMG_20100820_170313
    IMG_20100820_170238
    Apr 14th, 2010
    LI
    03' Grand Cherokee, 11' B8 S4
    08-20-2010 06:31 PM #2
    I just dont get why people put these spacers in there car. They mechanically make absolutely zero sense !
    sorry for the lack of input on the actual topic at hand.
    It wouldnt surprise me considering the spacer is a HOLE in a system that is designed to be closed.
  3. Member demolition86T1's Avatar
    Jul 5th, 2004
    New Jersey
    08-20-2010 06:42 PM #3
    i couldn't agree with you any more, when i change my oil tomorrow il take it out and clean up the mess then take a look a week later to see if the oil comes back, just wanted to know if anyone else had this issue...
  4. Member
    Apr 14th, 2010
    LI
    08-20-2010 08:02 PM #4
    Quote Originally Posted by demolition86T1 View Post
    good call. that would be the easy way to tell. just spray some all purpose cleaner on there, hit it with a wheel well brush, than rinse it off. (i detail cars on the side .
    just be sure to use some mild APC. stay away from that power purple stuff seen in pep boys. that stuff removes paint. simple green should do the trick.
  5. Member demolition86T1's Avatar
    Jul 5th, 2004
    New Jersey
    08-21-2010 07:33 AM #5
    Quote Originally Posted by mikeg6045 View Post
    thank you for the cleaning tips!
  6. Member
    Mar 26th, 2008
    Fredericksburg, VA
    '12 R; Built GTI TSI 3+
    08-22-2010 02:02 PM #6
    Mine leaked oil just not as much as yours. Car ran much better without the spacer too.
    11.53@121.18
  7. Member Brett_CC's Avatar
    Feb 23rd, 2010
    Virginia Beach, VA
    2010 VW CC
    08-22-2010 03:53 PM #7
    yeah i took mine off too and noticed the engine ran smoother. it sounded obnoxious and eventually led to a check engine light. i cleaned it up and returned it after 5 days. couldn't take that fake bov sound anymore
    APR Stage II, ATP Down Pipe, Magnaflow Catback Exhaust, K&N Typhoon Intake, A.W.E. Turbo Outlet Pipe, Steering Column mounted boost gage, Standard Suspension 32 way Coilovers, 19X8.5 Avante Guard Wheels, Clear Turns, R Line Tails, Euroswitch, Custom Shifter Stalk, Forge Short Shift Linkage, GC Body Kit, 35% Tint, beltronics hardwired radar detector.
    Mar 26th, 2008
    Fredericksburg, VA
    08-22-2010 05:30 PM #8
    Quote Originally Posted by Brett_CC View Post
    LOL Yea it's gay.
    11.53@121.18
  9. Member hazy450's Avatar
    Jul 22nd, 2010
    Panama City, Fl
    2013 RB Golf R, 2010 Bagged Tiguan (sold)
    08-23-2010 09:27 PM #9
    yup add me to the list of install for 3 days and remove after horrible gas mileage, horrible throttle responce, and 11 second long blow off sound randomly. Sounded like i had big rig brakes... stupidest thing ever made....
    "The thing is it's a gearbox. OK, it has one job to do, one job. Pull the lever: 'Am I a pencil? Am I a cauliflower? Am I a nuclear power sta-I'm a gearbox! Oh, heavens I'll swap some cogs around!" -Jeremy Clarkson
  10. Member Krieger's Avatar
    May 5th, 2009
    Orlando, FL
    Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
    08-23-2010 10:42 PM #10
    our FSI engine has the same problem. its from the PCV system dumping into the intake pre-turbo, thus pooling in the DV area.
    get a good block off plate or catch can setup and your golden.
    2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
  11. Member demolition86T1's Avatar
    Jul 5th, 2004
    New Jersey
    08-24-2010 02:23 AM #11
    its only been 2 days since i removed the spacer and my car feels so much smoother to drive, kinda like the feeling you get after changing your oil!
  12. Member butternuts6mt's Avatar
    Feb 29th, 2012
    LINY
    2007 B6 Passat 2.0T
    08-06-2012 03:59 PM #12
    i just took that thing off today. there was oil everywhere. changed to rev d and boy does it sound and feel better. i can actually hear a better spool with the aftermarket intake and the dv sounds better than the spacer and not as loud but still very noticable im happy
  13. Junior Member
    Aug 30th, 2012
    toronto
    2007 gti,2002 jetta 1.8T
    03-01-2013 03:23 PM #13
    Trust me its not the spacer and when u upgrade to the spacer u should upgrade to the new dv.the old ones where rubber and caused boost leaks from cracking. Also the oil issue i have also with my 07 mkv gti and i dont have the spacer on as of yet. i did research and i came to find that vw made a faulty oil filter seal and will leak all the time change all ur seals for ur oil pan and get a different filter and u should be ready to go.
  14. Member
    Jul 27th, 2007
    Ottawa, Canada
    07 Rabbit, 10 Tiguan, 1928 Chev, 02 Dakota
    03-01-2013 03:44 PM #14
    Sorry, no trust for the misinformed. The spacer is the problem as outlined in earlier posts. It is allowing the blow-by oil to escape. If after removal and a cleanup the OP sees more oil, then he can consider your comments about the oil filter and pan gasket.
