VWVortex.com - replacing fuel injectors 2006 passat 2.0
    Results 1 to 10 of 10
    Thread: replacing fuel injectors 2006 passat 2.0
    1. n00b
      Aug 22nd, 2010
      2006 vw passat 2.0
      08-22-2010 02:50 PM #1
      Hey guys, im a noob to the site. i was told by the dealer i need to replace the injectors b/c the car runs rough on cold start up. i have already replaced the spark plugs and coils. i have no idea how to replace the injectors. any help would be appreciated.
    2. Member hoffmaw1's Avatar
      Oct 4th, 2009
      Holland Patent
      2012 Focus
      08-22-2010 04:45 PM #2
    3. Member Krieger's Avatar
      May 5th, 2009
      Orlando, FL
      Turbocharged 2004 Civic SI with K20/K24 engine swap, 2006 Audi A3
      08-22-2010 04:56 PM #3
      why would your injectors affect your cold starts?
      id think your intake flaps would be more of a possible culprit.
      btw, what kind of cold are we talking about? our engines do hate being COLD, but ive never had much of an issue, even when it was like 15 degrees.
      2006 Audi A3 | 2.0T | 6MT | APR Stage 2+ | Fully loaded ECU | FK grill | EJ CAI | BSH TBP |EJ DV Reloc. | Eurojet TBE | EuroJet Catch Tank | Cross drilled and Slotted Rotors | EBC "Redstuff" Kevlar | Raceland Coilovers | Forge Side to Side Short Shifter | Forge Front to Back Short Shifter | Devil's Own DVC-30 Methanol injection | BSH RSB | BSH Motor mount Kit | 42 DD Shifter Bushings | HPFP Stage 1 upgrade |
    4. n00b
      Aug 22nd, 2010
      2006 vw passat 2.0
      08-22-2010 06:49 PM #4
      i had the flaps replaced also. the dealer replaced the flaps at a cost of $600. i replaced the spark plugs and coil packs. it runs rough at the first start of the day. here in SC that can be 90 degrees at 8:00 am.
      thanks for the responses.
    5. Member Krieger's Avatar
      May 5th, 2009
      Orlando, FL
      08-22-2010 08:23 PM #5
      Quote Originally Posted by reeves190 View Post
      im in FL, trust me, I know how hot it can get.
      im still not sure how your injectors can be bad for the first start, but never again, until the next day. you ever run any logs yourself? check your TB, fuel, etc.
      btw, describe "running rough". Does it just feel like the engine is running sloppy and loud? because thats normal until the oil pressure rises and everything warms up a bit.
      better to actually test stuff before you keep dumping money into it.
    6. Member Krieger's Avatar
      May 5th, 2009
      Orlando, FL
      08-22-2010 10:58 PM #6
      oh, btw, you ever pull your intake manifold and clean your intake valves? I was getting rough idles, especially when my engine was cold after like 50,000 miles or so.
      I am now running a vent to atmosphere catch can, scrubbed my valves, and running WM and all is well in Audi land... well, as well as a car produced by VAG van really be. lmao
    7. n00b
      Aug 22nd, 2010
      2006 vw passat 2.0
      08-23-2010 08:03 AM #7
      it runs rough enough to make the engine light come on. when i check the code it is a cylinder one misfire. i have not run any logs. i will check the intake manifold as you recomended. dealer said injector was "slowly going bad". Thanks for all the help.
    8. 08-23-2010 08:33 AM #8
      Injectors slowly going bad? Injectors work or they don't. Sure you might get a bad spray pattern as the tip gets gunked up after a while but if it is causing a misfire at start then it will cause misfire all the time. If it just misfiring on number one cylinder then have them replace that injector only. When it does not take care of the problem then ask your service advisor, "Now what?" Personally I will get a second opinion and pay the cost for that opinion. It sure beats shelling out cash for 4 injectors that are "going bad slowly" that will more than likely not take care of the problem.
    9. 01-13-2013 12:49 PM #9
      Hello,
      I have the same problem i replaced the coils and the sparkplugs and it still idles rough on cold starts. I live in Charotte NC. Did you ever get your problem fixed? Your help is greatly appreciated.
    10. 04-19-2013 07:42 PM #10
      Intake flaps and injectors are not the likely cause of bad running cold.
      First suspect is the head temperature sensor.
      Second is low fuel pressure from something like a clogged filter, bad pressure regulator bypass, or bad vent purge valve.
      Easy to diagnose with a fuel pressure gauge.
      Second suspect is a mass air sensor dirty with insulating PCV foam, and the solution is to just remove, clean, and replace it.
      Third would be weak spark from large gap, oily wires, or not using dielectric paste on both ends of plug wires, since air is no longer sufficient insulator at high voltages.
      Any intake or vacuum leak is suspect.
      Try plugging hoses one at a time to see if any have effect.
      Purge valve, EGR, and PCV are common culprits.
      Could even be brake booster.
    « Back
