VWVortex.com - A legend is re-born: 27 years later.
    Page 10 of 14 FirstFirst ... 67891011121314 LastLast
    Results 226 to 250 of 326
    Thread: A legend is re-born: 27 years later.
    1. Member -RalleyTuned-'s Avatar
      Nov 17th, 2008
      East of the Mountains, WA
      77' Rabbit 16v, '98 A4 Avant, '07 A3 S-Line
      04-29-2011 01:16 PM #226
      Yeah I am having trouble finding a manufacturer that sells true performance dual rate springs. Progressives are a dime a dozen of course...
      I would really like to give it a try, I have been doing a ton of reading on these old school road race cars and am thinking of giving a few different setups a try at some point when i can assemble all the equipment for testing. Good luck at your event, can't wait to see that thing riping again!
    2. 04-29-2011 02:51 PM #227
      i swear i've seen dual rate springs somewhere. must. search. this is bugging me.
      I'm a giant.. My name is Matias
      Quote Originally Posted by WackyWabbitRacer View Post
      Yes...but let's pretend there is no internet and you have to fix the problem by thinking through a solution.
      Tell me your solution, and then I will give you my idea to fix the problem.
      Cheers, WWR.
    3. Member GTLITE72's Avatar
      Apr 16th, 2007
      No. Virginia
      GTLite 75 Rabbit, 1959 Austin Healey Speedwell Sprite, 2011 Jaguar S/C XJL, 2010 LR4, 2008 HD Ultra
      04-29-2011 03:06 PM #228
      If anyone knows where to get that type of spring it would be Bob @ Pegasus.
    4. Member GTLITE72's Avatar
      Apr 16th, 2007
      No. Virginia
      05-02-2011 08:07 AM #229
      Hopefully I will get more good news today about the Dyno numbers. All the new jets and peices parts should be arriving at the machine shop and they can get back on it. I really want to see 200hp. If it in fact does hit that number I don't think I will have any problems making a podium finish.
      So far the schedule looks like we are going to run Summit Point on May 21/22, then to New Jersey Motorsports Park for the Devil National the weekend of June 4th, then if the money works out right we will be going to the June Sprints at Road America.
    5. Member sarcastro's Avatar
      Jun 3rd, 2010
      Klamath Falls, Oregon
      1985 cabriolet 1999 passat GLX 30v
      05-02-2011 03:53 PM #230
      awesome!
    6. 05-02-2011 04:11 PM #231
      itis' 4:10 on the east coast. where are the updates?
      Cheers, WWR.
    7. Member GTLITE72's Avatar
      Apr 16th, 2007
      No. Virginia
      05-02-2011 04:22 PM #232
      lol, they are still on the UPS truck with the jets and emulsion tubes. Parts did not arrive today. Also Franz is not at the shop today. Hopefully tomorrow.
      Another peice of news: We sent out the display panel for our scales so I will be able Weight Jack and Balance the car. Minimum weight with driver needs to be 2040lbs.
      Dec 14th, 2001
      Greensburg, PA
      05-02-2011 04:31 PM #233
      Minimum weight is higher than I expected. Is there a limit to how much you are allowed to ballast?
      Life begins at 101 kpa ...and so does poverty--Lugnuts Calhoun
    9. Member GTLITE72's Avatar
      Apr 16th, 2007
      No. Virginia
      05-02-2011 04:48 PM #234
      Balast is unlimited, whatever I need to do to make minimum weight.
      They keep upping our minimum weight so the smaller engine cars can keep up with us. For instance they reduced the inlet restrictor on my 1.8 motor from 25mm to 24.5mm and took minimum weight from 1980 to 2040. The Nissans running 16v motors were knocked down to a 22.5mm restrictor and minimum weight of 2080.
    10. Member
      Dec 14th, 2001
      Greensburg, PA
      05-02-2011 05:14 PM #235
      Just wondering if you could at least put a lot of the weight where you wanted it. I know in some classes SCCA limits how much ballast can be used.
    11. Member GTLITE72's Avatar
      Apr 16th, 2007
      No. Virginia
      05-03-2011 01:21 PM #236
      In GT ballast is unlimited as long as it is safely secured. I was actually thinking about going inside the bumper tubes / frame rails.
      Unfortunately no updates today from the Dyno shop. Apparently UPS uses Nissan, Honda and Toyota delivery vehicles because if they had used a VW my fricking parts would be there by now!!!
    12. Member GTLITE72's Avatar
      Apr 16th, 2007
      No. Virginia
      05-04-2011 09:21 AM #237
      Hopefully today will be the day I find out if my investment of time and money will be worth the effort. With any luck and some damn good tuning I should see the magic 200hp number. I will not be totally crushed if I don't see it but it will make me happy as a clam. (btw can someone explain that expression to me?)
      Anyway ....... I will post as soon as I hear from Franz and Jim with the dyno numbers.
    13. Member fthaimike's Avatar
      Jun 29th, 2009
      S.Wales UK
      Mk1 Kamei Golf Race Replica
      05-04-2011 09:26 AM #238
      Good stuff, will you have any pics of it on the rolling road?
    14. 05-04-2011 09:30 AM #239
      Quote Originally Posted by GTLITE72 View Post
      It's in good hands, Franz is one of the best. Even if you don't see the 200whp mark, it will be infinitely drivable, and reliable.
      R | GTI | Type 1 | PVW 02/09
    15. Member GTLITE72's Avatar
      Apr 16th, 2007
      No. Virginia
      05-04-2011 09:52 AM #240
      Quote Originally Posted by fthaimike View Post
      Sorry Mike, I doubt you will ever see "road" pictures but usually a few weeks after each race weekend I get lots of professional proofs sent to me in the mail.
    16. Member fthaimike's Avatar
      Jun 29th, 2009
      S.Wales UK
      05-04-2011 09:55 AM #241
      Sorry i meant the tuning rollers, we call them rolling roads in the UK sometimes.
    17. Member
      Dec 14th, 2001
      Greensburg, PA
      05-04-2011 09:57 AM #242
      Mike is referring to the dyno-- they call them rolling roads in the UK. Iirc, Franz has a Dyno Dynamics unit.
    18. Member fthaimike's Avatar
      Jun 29th, 2009
      S.Wales UK
      05-04-2011 10:01 AM #243
      cheers mark
      yes, it would be nice to see a pic of it running on the dyno
    19. Member GTLITE72's Avatar
      Apr 16th, 2007
      No. Virginia
      05-04-2011 10:12 AM #244
      I don't think I will get any video or pictures on the dyno because I'm not going to be there while they tune. I still have a job that I have to spend 11 hours a day at, I would love to take the day off and hang out with them.
      I feel like an expectant father waiting in the lobby of the delivery room.
    20. Member GTLITE72's Avatar
      Apr 16th, 2007
      No. Virginia
      05-04-2011 03:47 PM #245
      Well, I heard back from Franz!!!!!! I'm stoked the final number came to 191.4. I know its not the 200 I was hoping for but I still have between 20 and 30 more at the wheel then the Nissans.
      Actual wheel number was 168 where I was told by a friend that the Nissan's were in the mid 140's.
      Still need to work on the Idle a little bit but as far as I'm concerned the Sun just came out and its a beautiful day!!
    21. 05-04-2011 03:53 PM #246
      take. restrictor. off. now.
      and 191 out of a 1.8 counterflow is pretty
      Cheers, WWR.
    22. Member GTLITE72's Avatar
      Apr 16th, 2007
      No. Virginia
      05-04-2011 04:44 PM #247
      Unfortunately did not get an unrestricted pull on the motor due to the massive jetting change. In talking to Jim he beleives that with a little more head work and a new cam 205 is not out of the question. Now I need to make a couple calls to aquire a clean 1.8 head. (now accepting donations)
      Currently I am running a web 206 grind, gonna need to do some homework to find something that might work better.
      I would expect that with the numbers that I have I would not be suprised to see in the neighborhood of 235+ unrestricted but that is only an estimate.
    23. Member
      Dec 14th, 2001
      Greensburg, PA
      05-04-2011 04:52 PM #248
      Congrats.
    24. 05-04-2011 04:54 PM #249
      Cheers, WWR.
    25. Member 2mAn's Avatar
      Oct 15th, 2006
      Culver City
      changes daily...
      05-04-2011 04:56 PM #250
      awesome!
