Page 1 of 2 1 2 LastLast
Results 1 to 35 of 50
Thread: changing wheel offset by shaving/milling material
  1. Member taifighter's Avatar
    Dec 20th, 2007
    NorthWest Indiana
    C4 A6 Avant, B6 A4, and a NA MX5 waiting for boost
    08-25-2010 05:40 PM #1
    Is it possible to pull a wheel in toward the car by having some aluminum shaved off the hub of the wheel? It seems this would effectively change the offset, as long as it clears suspension components when the barrel is brought closer to them.
    What are your opinions on what is an acceptable amount of material, if any, that can be removed without destroying integrity/strength of the wheel?
  2. Member Surf Green's Avatar
    Feb 16th, 1999
    Silver Spring, GerryMarylandering
    2002 Golf Wagon TDI. 1996 Surf Green GTI VR6. 2005 Chrysler T&C.
    08-25-2010 05:44 PM #2
    I don't know how much bolt seat thickness you have to work with, so I'm just going to say that this is a terrible idea.
    I'm just here for the sanctimonious circle jerk.
    2002 Golf Wagon TDI - 1996 GTI VR6 - Bendpack HD9-STX - flickr
  3. Member ABAcabby's Avatar
    Jul 28th, 2003
    Brisbane, QLD, Australia
    '81 Rabbit 1.6l diesel
    08-25-2010 05:47 PM #3
    Well, wheels come in varying offsets, so i don't see why this would be a problem provided that the wheel has enough material leftover.
    It's just something that would need to be done very carefully. I have been thinking about doing this to my wheels as well. Let us know what you find out.
  4. Member sbvwfanatic's Avatar
    Aug 24th, 2004
    Santa Barbara
    09CW VW Rabbit w/19"BBS CKs, JOM blue line coil-overs
    08-25-2010 05:50 PM #4
    All depends on the wheel manufacturer. A while back I was interested in a set of MOMO wheels that came in my bolt pattern but incorrect offset. The distributor had been dealing w/Momo for years an called his contact @ MOMO NA and was told that 5MM could be shaved w/out any loss in wheel strength. Nowadays though, due to legal liabilities, I doubt many Wheel manufacturers that would admit to any kind of wheel alterations even if there were tolerances.
  5. Member AtlasD3Miami's Avatar
    Dec 16th, 2004
    '11 Range Rooney - '11 BMW 550i - '10 BMW 650i Conv
    08-25-2010 05:51 PM #5
    Not the brightest idea. It can seriously degrade the bolt seat, hub seat as well as tortional load rigidity.
  6. Member taifighter's Avatar
    Dec 20th, 2007
    NorthWest Indiana
    08-25-2010 05:59 PM #6
    see, here's the thing... it's split in opinions either way
    I'll ask the few machining shops around here, but they may or may not have as much info collectively as TCL.
    I would think that a machinist with experience would be able to eyeball it and judge how much material is left, if the material will be degraded by the process, etc
  7. Member AtlasD3Miami's Avatar
    Dec 16th, 2004
    08-25-2010 06:12 PM #7
    Quote Originally Posted by taifighter View Post
    From experience this is what I can tell you.
    We did this wheel a few years ago.
    The rear is 20 x 11.5 ET46. At the same time we also had another Gallardo wheel coming online and it was spec'd at 20 x 11.5 ET48. I wanted to keep the specs the same so we changed the offset from ET46 to ET48. That 2mm reduction in offset totally killed the integrity of the wheel and it failed to meet load requirements in testing. I don't know what type of wheel you're working with (cast, forged, one piece, multi-piece, etc etc), but it can be a really bad idea. Is that the case every time? No, but I wouldn't take the risk.
  8. Member taifighter's Avatar
    Dec 20th, 2007
    NorthWest Indiana
    08-25-2010 07:20 PM #8
    Just a cast 1 piece impossible to replace FK wheel
    Sent from my DROID2 using Tapatalk
  9. Member Live-Wire's Avatar
    Jun 9th, 2005
    Guelph Ontario
    2008 BMW 335i
    08-25-2010 07:40 PM #9
    The offset is probably ground down at the wheel factory anyway, if you needed another few mm it might not be a problem.
    Finding a shop that would do it without screwing up your wheels is another story. Also a wheel would be very difficult to put in a conventional milling machine, lathe or grinder... They probably use a rather custom piece of cutting equipment at a wheel manufacturer.
    Leave it alone, or buy wheels that fit FTW.
  10. Member Das Borgen's Avatar
    Sep 10th, 2008
    Columbus, OH
    1995 M3, 1999 740i "Short" Sport, 2000 Ducati 748
    08-25-2010 07:45 PM #10
    I say this is a terrible idea... I know there is a safety factor built into every design but I wouldn t try to push it on a chassis part such as a wheel center
    it surely can and has been done by as much as a quarter inch (no joke) by some some autocrossers I know in Stock Class solo events but those guys have tons of money and probably don t DD those rollers
    your mileage WILL vary
    Quote Originally Posted by Das Borgen
    VR6s should sound like Chewbacca getting raped
    Dazzle Surprise - Team My Little Pony
  11. Member TwoLitreVW's Avatar
    Mar 16th, 2000
    mud
    i've a horse outside.
    08-25-2010 07:47 PM #11
    did this to an old set of enkeis to bring the offset to where we needed it.
    there was tons of material left with the wheel we had to work with, and we never had an issue otherwise.
    it all depends on the material and how much you've got to work with.
    it's not advisable for every wheel out there.
    shut your mouth. sh sh shut your mouth.
  12. Geriatric Member BRealistic's Avatar
    Dec 16th, 2005
    Tennessee
    88 F150, 04 RX8
    08-25-2010 08:04 PM #12
    I say do it- but only if you are going to drive at very high speeds.
  13. Member
    Dec 31st, 2005
    SoCal
    Corvette & SV650
    08-25-2010 08:07 PM #13
    Yes, although this may cause other problems.
    It depends. Need more information.
  14. Member taifighter's Avatar
    Dec 20th, 2007
    NorthWest Indiana
    08-25-2010 08:29 PM #14
    Pulling the fenders seems a better alternative
  15. Member randyvr6's Avatar
    Aug 17th, 1999
    Michigan
    2012 CC R Line, 2007 Passat Wagon, 2001 Jetta VR6, 1993 Corrado SLC, 1973 Ford Capri
    08-25-2010 08:29 PM #15
    What makes you think that someone who has knowledge about machining makes them qualified to determine the dynamic forces acting on a modified wheel it and if it will withstand them by "eyeballing" it?
  16. Member sbghms's Avatar
    Aug 19th, 2008
    Washington
    '09 VW Rabbit
    08-25-2010 09:03 PM #16
    Quote Originally Posted by AtlasD3Miami View Post
    Wait, you're telling me this pic isn't computer generated??
  17. Member AtlasD3Miami's Avatar
    Dec 16th, 2004
    08-25-2010 09:17 PM #17
    Quote Originally Posted by sbghms View Post
    No I took it myself.
  18. Member sunofernest's Avatar
    Nov 2nd, 2009
    Philly
    '06 WRX, naked '97 GSXR 600, '79 DT250
    08-25-2010 09:23 PM #18
    I thought the same
  19. Member Triumph's Avatar
    Nov 27th, 2000
    Northern VA
    '09 GTI
    08-25-2010 09:26 PM #19
    It's pretty stupid for anyone to say either, "Sure go ahead" or "Don't do it you'll die!" because it depends completely on the wheel. I would feel comfortable saying yay or nay if I saw the wheel in question (and no a machinist wouldn't "judge how much material is left", they have ways to measure things to less than 1/1000ths of an inch). Without knowing the wheel or the car, it's pointless for anyone to give you any answer.
    -Triumph, the Insult Comic Dog
    I saw this in a movie about a bus that had to speed around the city, keeping its speed over fifty, and if its speed dropped, the bus would explode! I think it was called, "The Bus That Couldn't Slow Down."
  20. 08-25-2010 10:21 PM #20
    I took this one of my GF. Rawhide.
  21. Member taifighter's Avatar
    Dec 20th, 2007
    NorthWest Indiana
    08-25-2010 10:40 PM #21
    Quote Originally Posted by randyvr6 View Post
    I'm not up on the processes or I'd be a machinist myself, pardon my ignorance
  22. Member Surf Green's Avatar
    Feb 16th, 1999
    08-26-2010 06:24 AM #22
    Your average machinist is capable of shaving material off the wheel to whatever tolerance you ask for...
    but they are far from qualified to do the engineering work required to tell you just how much integrity you have left... or just how big of a bump you can hit mid-corner before your lugs tear through your thinned wheel.
    You'd need a full FEA (with very accurate inputs, which the wheel manufacturer probably will not provide) before you could have any confidence in the result.
  23. 08-26-2010 06:41 AM #23
    Agreed; however, I think buying wheels that actually fit would be the best alternative.
  24. Senior Member Son's Avatar
    Aug 10th, 2000
    Finland, The EU
    08-26-2010 07:15 AM #24
    Quote Originally Posted by ABAcabby View Post
    However, different offsets of the same wheel model don't use different length bolts. Sure, if a lower offset wheel used a longer bolt, i.e. there was more metal behind the bolt seat, then there'd be room for milling some off, but that's not the case ever, I'm afraid. Offset variation is done by changing the barrel's distance compared to the hub, while the "outer" part of the center of the wheel remains at the same distance from the hub. This results to different look on different offset wheels. Here's a prime example. Replica RS4 wheels are made for cars that aren't as wide as the RS4 with its wider-than-A4 fenders. Thus the wheels are "flatter" than the deep-center genuine RS4 wheels.
  25. Member taifighter's Avatar
    Dec 20th, 2007
    NorthWest Indiana
    08-26-2010 08:42 AM #25
    Quote Originally Posted by JimmyD View Post
    I really love these wheels and got them on the cheap. They're just a tiny bit too wide.
  26. Member MatchStick's Avatar
    Nov 16th, 2000
    CT
    2013 WRX 2012 Mazda5
    08-26-2010 08:50 AM #26
    I loved that peg... one of a kind...
  27. Geriatric Member AKADriver's Avatar
    Nov 20th, 2001
    Unreal VA
    NB Miata
    08-26-2010 08:53 AM #27
    I've seen this done on very old wheels which were made with lots of extra material and looser tolerances.
    Modern wheels are generally made to waste as little material as possible and weigh as little as possible and they don't leave enough room for this.
    I don't practice llanteria
  28. 08-26-2010 09:17 AM #28
    I'm not sure if you intended your post to come across as sarcastic and doubting AtlasD3Miami, but I've known him for years and can assure you that not only did he take that image, it was his car and his own brand of wheels on the car. He absolutely knows what he's doing with respect to the technical knowledge offered and his photography skills. He's taken many images that have been posted on this board without accreditation which people have 'oohed' and 'aahed' over.
  29. Member Surf Green's Avatar
    Feb 16th, 1999
    08-26-2010 09:31 AM #29
    Quote Originally Posted by Smindustries View Post
    I'm not sure if you intended your post to come across as sarcastic and doubting ...
    I think the point was that the photo looks a bit like a high quality rendering.
    I don't know much about photography compared to all the experts here, but I can usually tell what flavor of post processing was applied compared to a "Straight from the Camera" shot. And to me, that photo looks like it was either smoothed after downsizing, or it was run through a noise reduction filter... something I wouldn't think would be required with a 5D.
  30. 08-26-2010 10:05 AM #30
    I'm not sure if you intended your post to come across as sarcastic and doubting AtlasD3Miami, but I've known him for years .
    But that is my GF. Are you doubting my ability to masterbate?
    No, I was just thinking that, like the post above this one, the picture looked more rendered than real. I don't really care if the car was his or about his techinical ability. Thats none of my concern.
  31. Senior Member justanotherusername's Avatar
    May 26th, 2007
    Palm Beach, FL
    '08 135i, '85 Huntsman (Toyota) RV
    08-26-2010 10:13 AM #31
    You have to consider the wheel, and the offsets it was originally available with.
    The manufacturers will take a casting and use it for a range of offsets. If the casting you have was available in the offset you want, then it's probably Ok, but it would probably be simpler to just buy it that way instead of having it milled.
    The 135i uses very high offsets in the rear, to the point where it limits wheel selection to just a few that actually fit. There have been vendors offering to mill wheels to make them work, but honestly I'm leary of it. The last thing I want is to have the center of the wheel bust apart while I'm loading it up.
  32. Member AtlasD3Miami's Avatar
    Dec 16th, 2004
    08-26-2010 10:13 AM #32
    Ahhh TCL how you never change. Smitty you're making me blush
  33. Member
    May 27th, 2008
    Malvern, PA
    5.7L WK2 | 2.5L TJ
    08-26-2010 10:17 AM #33
    Offset is built into the wheel though, not just the center mounting section:
    BBS RC for example:
    (now, some of this difference, is due to the width of the wheel, but just bear with me)
    Jetta GLI, what are they, ET38?
    BMW 5 Series, maybe ET20 or somewhere around there?
    98 wrangler build
    (•_•)
    ( •_•)>⌐■-■
    (⌐■_■)
  34. Senior Member ClockworkChad's Avatar
    Mar 21st, 2003
    CT
    Is300
    08-26-2010 10:31 AM #34
    the image just REALLY looks like its computer generated, from the gallardo to the hotel behind it. it must be the effects he used when editing it. There are alot of kids pretending to own alot of things here, so its rare when a poster owns a gallardo and has his own wheel company, it causes some doubt. good for him though
    also, i wouldnt mill a wheel. Ive seen wheels that have shattered on their own after passing their companies quality tests, id rather have it stick out an extra 2mm and be safe.
    Ferrari Scuderia 2012 - "The people who speak badly about me then tremble and cry when they want to have their picture taken with me” - F. Alonso
    Now recruiting for IT/financial/accounting/creative services in fairfield county and metro nyc, pm if interested
  35. Member AtlasD3Miami's Avatar
    Dec 16th, 2004
    08-26-2010 10:51 AM #35
    Quote Originally Posted by ClockworkChad View Post
    It's just over processed. I was in a rush and using a Sony laptop with that TruBrite or whatever crap they market the horrible screen coating as.
