VWVortex.com - DIY: Installing Höen Xenonmatch bulbs in foglights on a Golf
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 30
    Thread: DIY: Installing Höen Xenonmatch bulbs in foglights on a Golf
    1. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      1971 Super Beetle, 2014 Golf TDI Manual, 2015 Silverado 1500 LT 4x4 Crew Cab
      08-25-2010 10:44 PM #1
      After reading this thread I decided to order a set of 9006 Höen xenonmatch bulbs to fit in my foglights.
      The match is pretty close, but they are just a tad bit bluer than the stock HIDs, maybe a better match to 5000k HID capsules. Install was a breeze, account about 5 minutes for both sides. The only tool needed is a Torx 25 driver.
      You can buy the bulbs here.
      Here are the bulbs you will receive (9006 for the Golf):
      To give you an idea, here are some pictures with the stock fog light bulbs, as you can tell they are yellower than the stock 4300k HID lights:
      Here is the fog light assembly and the fog light grille. To remove the grille, I just pulled it from the center, the slats near the actual fog light lens. It pulled right out (I had taken them off before to put the Lamin-X on too). You can see the clips on the back side of the grille to give you an idea of how it's held in. The outer part of the grille also has a tab that fits in a hole in the bumper (re-install that part first when you put the grille back on):
      Now take your Torx 25 driver and remove the single screw that holds the assembly in (the other side has 2 tabs):
      Pull the light assembly out:
      Remove the bulb from the fog light assembly (I left it connected to the harness to make it easier to handle):
      Now disconnect it from the harness, there is a little tab locking it in, just push the tab and pull the bulb out, remember not to touch the surface of the bulb as the oil on your hands can shorten teh life of the bulb. Now install the Hoen bulb on the harness:
      Put the bulb back into the fog light assembly, and put the fog light back into the bumper, re-attach the Torx 25 screw:
      Put the fog light grille back on (remember to put the tab on the outer part first, the rest will just clip right in):
      Repeat for the other side and you're done !
      Here are some pictures with only the driver's side (left side of the car) fitted with the Höen Xenon match bulb to show the comparison with the stock bulb:
      Night time pics:
      Fogs only:
      Fogs and headlights:
      Headlights only:
      More new pics:
      Remember, I am not responsible for anything that happens to your car, you are responsible for your own car.
    2. Junior Member
      May 1st, 2010
      1987 944S
      08-25-2010 10:49 PM #2
      Any night shots yet?
    3. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      08-25-2010 10:53 PM #3
      Quote Originally Posted by bpowellAU View Post
      no but I can get some
    4. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      08-25-2010 11:37 PM #4
      added night shots
    5. Member crunchytheory's Avatar
      Feb 11th, 2009
      Orange County, CA
      2010 VW GTI, 2000 VW Golf 2.0
      08-26-2010 06:23 PM #5
      Thanks for the DIY! Mine just came in a couple days ago... was gonna wait till the weekend to get them on. Hopefully it's the same process on the GTI.
    6. Geriatric Member absoluteczech's Avatar
      Sep 12th, 2006
      The BRO C
      2016 VW GTI 4DR CSG
      08-26-2010 06:24 PM #6
      you love making DIY's... you need a new screen name. Mr. DIY
    7. Member Moltenburn's Avatar
      Jun 29th, 2010
      Denver
      2013 Platinum Grey Passat TDI SE 6-spd, 2013 Denim Blue Beetle, 1991 Inka Blue Cabriolet
      08-27-2010 12:15 AM #7
      Tru that. this guy is making modding cake for the rest of us. good work.
    8. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      09-02-2010 12:00 AM #8
      Haha thanks
      Added 3 new pics to the first post too
    9. Member crunchytheory's Avatar
      Feb 11th, 2009
      Orange County, CA
      09-04-2010 07:24 PM #9
      I was about to get started with this today, but couldn't figure out how to get the plastic honeycomb panel out. It's a bit different than the Golf since it has the thin parts toward the middle. Anyone try this yet that has some advice? Thanks!
    10. Member TWinbrook46636's Avatar
      Apr 18th, 2003
      2010 Golf TDI
      09-04-2010 07:33 PM #10
      Does anyone know how the Sylvania SilverStar Ultra compares in terms of brightness and color temperature?
    11. Moderator 71sbeetle's Avatar
      Apr 12th, 2002
      Las Vegas, Nevada
      09-04-2010 07:48 PM #11
      Quote Originally Posted by crunchytheory View Post
      Don't the GTIs have the access panel in the fender liner ?
    12. Member crunchytheory's Avatar
      Feb 11th, 2009
      Orange County, CA
      09-04-2010 09:03 PM #12
      Quote Originally Posted by 71sbeetle View Post
      It does, you're right. Now there's a plastic assembly that is on there pretty good. Wondering if it needs to slide off or just be pulled straight off
    13. Junior Member
      May 29th, 2008
      Copenhagen, Denmark
      2008 Golf VI, 1,4 TSI DSG-7 Highline
      02-16-2011 09:39 AM #13
      I know this thread is old, but thanks for the guide, easy peasy to do.. I've made somewhat the same as you, I just used Mtec Superwhite 9005 HB3 65w modified in the connector to fit the standard bulb connector, as well as rubber sealing moved over from the standard 9006.
      Before and after:
    14. Geriatric Member Aonarch's Avatar
      Dec 4th, 2006
      Atlanta, GA
      A mullet, a cracked piston, and an Espresso.
      02-16-2011 11:56 AM #14
      Awesome!
    15. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      2016 MkVII e-Golf, 2010 MkVI MT TDI Golf, 2000 B5 4M Passat Wagon
      02-17-2011 07:21 AM #15
      Is there a visible difference in light output? Hard to tell from the pics.
      I know, for the same wattage, manufacturers can't do much - but I find the light output of the fogs a bit on the weak side, and would like to maximize it (less interested in going bluish).
    16. Junior Member
      May 29th, 2008
      Copenhagen, Denmark
      02-17-2011 04:16 PM #16
      If you see my pic 1 and 3 and compare you will see the difference on the asphalt.
      Around 10 watts more than standard.
      2009 Tornado Red euro Golf VI 1,4 TSI TwinCharger 160 DSG-7 - Bi-xenons - 2010 BT Premium - Eibach 45/35 - 19" AEZ Valencia w/CSC5 - RNS510 - ParkAssist - Highline - DK/Technique/Winter add-ons. VCDS
    17. Member golf-zilla's Avatar
      Sep 5th, 2004
      S.E. Wisconsin, USA
      '11 Golf 2dr TDI 6-speed, '09 Challenger R/T 6-speed, '07 Jeep GCL CRD, '96 Corvette Grand Sport Cp
      02-17-2011 09:01 PM #17
      Quote Originally Posted by TWinbrook46636 View Post
      Sylvania says that Silverstar Ultras have a 4100K color temp. The stock HIDs are said to be about 4300K, so they should be a pretty good match. I just bought a pair of the Sylvanias and will install them this evening...
      OK, just finished. Less than 20 minutes, in the dark, taking it easy. The above-mentioned Sylvania SilverStar Ultras are rated at 51W @ 12V. While I was taking out the original bulbs, I checked to see what they were...and guess what: they're 51W @ 12V Sylvanias! Except for the color of the glass (purple vs clear), they even look identical. The SilverStar Ultras are noticeably whiter (the whole point, really) than the standard Sylvanias, but still look a bit yellow-ish compared to the just-turned-on, blue-ish HIDs. After the HIDs are good and warmed up, they seem to get a touch "warmer" (lower color temperature), so a good comparison between the fogs and the HIDs will have to wait for another evening when it's been out running for a while. Has anyone else noticed that the fog light lenses on the '11 Golf appear to be slightly smoked...just a bit "brown-ish"? They're not clear, and that makes matching the HID color using halogen bulbs just that much harder...
      ____
      Bob
    18. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      02-18-2011 04:01 AM #18
      Anyone find good LEDs that fit (and that have a resistor, so they don't trigger the bulb-out warning)? At least in principle, there should be some that are brighter...
    19. Member phatz314's Avatar
      Jan 13th, 2011
      SF bay area
      2011 Golf TDI
      02-22-2011 09:29 PM #19
      The trouble with any high color temperature halogen is poor filament life. Sylvania Silverstar Ultras have notoriously poor life (some report as little as 300 hrs). The same is fundamentally true of any "white" bulb -- there is a tradeoff between filament brightness and life. At constant power/resistance, if you simultaneously thin and shorten the filament, it burns hotter & whiter but the thinner filament fails sooner. Who wants to be replacing bulbs every 3-6 months?
      For brightness, I'm not interested in retrofitting higher wattage bulbs -- even if it doesn't instantly burst into flames, doesn't mean it's good for the housing. And for color matching, blue coatings just dim the light output.
      Has anyone tried HIR bulbs in the mk6 fog housing? This magical-sounding technology uses a coating on the inside of the bulb to reflect IR radiation back to the filament, making it burn hotter without using extra power or thinning the filament. HIR never took off, as it was introduced right as HIDs were supplanting halogens in higher-end vehicles. I ordered a pair of 9012s for kicks off Max Lumens. They should burn a little whiter, but be way brighter.
      here is a good thread with more background
    20. Member Feyd's Avatar
      Apr 1st, 2002
      Chicago
      2011 Golf TDI, 2012 Touareg TDI
      02-22-2011 10:01 PM #20
      I put in some yellow PIAAs over the weekend... Don't know about you folks, but my grills were a major PITA to get out.
      All is well though and I love the contrast with the HIDs.
    21. Member jr05gti's Avatar
      Aug 19th, 2006
      GA
      2012 GTI
      02-27-2011 03:07 PM #21
      If anyone was wondering, the 9006's do not fit the GTI. Höen's fitment guide says they are for 2006+ GTI, but I went to install mine today and the stock bulb is an H8.
    22. Member golf-zilla's Avatar
      Sep 5th, 2004
      S.E. Wisconsin, USA
      03-02-2011 01:10 AM #22
      9006s are the correct bulbs for the MK6 Golf fogs...
      As an update to my installed Sylvania SilverStar Ultras, I have to say that they're not as white as I had hoped. While they're definitely whiter than the stock bulbs, they still look noticeably yellow when compared to the stock HIDs. I've found in the past that Philips CrystalVision Ultra bulbs tend to run a bit whiter than the Sylvania SilverStar Ultras, even though Sylvania claims 4100K for their bulbs while Philips only claims 4000K. I've also found that the Philips bulbs last longer and are a bit cheaper as well.
      I'd gladly trade a little of the output of these Sylvanias for whiter light, as long as they still lasted a reasonable amount of time. I'd consider an HID conversion if any of the available HID bulbs had shadow masks on their tips like the 9006s do, but so far none do. If you put a bulb with no shadow mask on its tip into one of these fog light housings, you end up with an obnoxious flood light instead. That's definitely not fair to oncoming traffic. No, the Hoens shown in the OP may just be the hot ticket. I just wish I hadn't spent $50 on these stupid Sylvanias...
      ____
      Bob
    23. Member phatz314's Avatar
      Jan 13th, 2011
      SF bay area
      2011 Golf TDI
      03-02-2011 03:28 AM #23
      Quote Originally Posted by golf-zilla View Post
      Yup. The HIRs I just put in this week (Philips 9012, trimmed down to fit the 9006 housing) are substantially brighter than stock, but without the shadow mask the filament is directly exposed. They're only a little whiter than stock -- which is to say, noticeably whiter in a side by side comparison, but still yellow.
      Unlike many of you, I don't run fogs as DRLs or anything other than cornering lights, but nevertheless I feel a little guilty running the HIRs, and might switch them out. Maybe the presumably crappy lifetime of the Hoens/Silverstars won't matter in my case, since I put so few Amp-hours on my bulbs.
      I want BRIGHT bulbs gotdammit (white would be pretty too)
    24. 05-05-2011 07:50 PM #24
      Does anybody have pics with yellow fogs?
    25. Geriatric Member absoluteczech's Avatar
      Sep 12th, 2006
      The BRO C
      2016 VW GTI 4DR CSG
      05-05-2011 09:41 PM #25
      Quote Originally Posted by Madtytetdi View Post
      search?
