VWVortex.com - Adding MFSW Buttons to Base 2011 GTI
    Results 1 to 18 of 18
    Thread: Adding MFSW Buttons to Base 2011 GTI
    1. Member H20 Cooled's Avatar
      Jun 28th, 2010
      2011 Golf 2.5 2dr
      08-28-2010 02:43 PM #1
      I was looking at getting a 2011 Base GTI, and I was wondering if it is possible to add MFSW buttons to the steering wheel after I upgrade the radio to a RCD510? I know it should be fairly simple to swap out the trim pieces on the steering wheel and add the buttons, but I was wondering how you would wire them into the head unit. Is it possible, or should I just forget about it?
      And yes I know that I can get a better stereo, MFSW buttons and a sunroof for $1,700 more. If I had the money, I would. But I'm a young guy, already paying out the a$$ for insurance and I can't swing the extra $1,700.
    2. Banned BarryT82's Avatar
      Nov 12th, 2005
      Charleston, WV
      '12 F-150 FX4 Super Crew, '11 JSW TDI
      08-28-2010 02:48 PM #2
      Does your 2011 GTI have a light that comes on for the bluetooth connection next to the sunglasses holder?
    3. Member reelknead1's Avatar
      Oct 7th, 2007
      Charlotte, NC
      CSG GTI 2010
      08-28-2010 03:18 PM #3
      I would recommend a trying to find one of the last few 2010s or saving some more money before buying a car that doesn't have what you want.
      I don't see adding the buttons as an easy thing.
    4. Junior Member spalanca's Avatar
      Feb 22nd, 2011
      turin
      Golf GTI mkVI my2011
      04-08-2011 11:52 PM #4
      i try to do the same thing, my gti late 2010 (already my11) came out without the MFSW so i need to install the button after.
      i already found the button mask (22), the little control module inside the steering wheel behind the airbag(19), and the cable connecting buttons, horn, and airbag to the steering wheel electronics. (which is the module n°16 on vcds)
      this is the problem: apparently, my2011 GTIs should have different components and assembly compared to my2010 GTIs, so the normal CD module that you would buy for an ordinary gti V and maybe gti VI 2010 retrofitting could not fit with our steering assembly.
      i tried to figure out what steering control module i needed and nobody can tell me for sure what part number I need.
      this is the new assembly (after may 2011)
      it's italian etka, basically if you have a normal steering wheel, you should have 5K0 953 549 C but this doesn't support button functions. THEY have replaced it with the B version (sold as spare part) and on the ross tech website they say it can work with MF buttons, so i think this is the module to look for 5K0 953 549 B, but i'd like to get a positive answer from who is more confident with such theese problems.
      check with vag com cable and post an autoscan!
      this is the old (2010) assembly for gti VI (prior to may 2010) the control module n°6 should be now integrated in the n°2 of the other table.
    5. Member .KIX.'s Avatar
      Sep 7th, 2008
      Navel city
      Beetle RSI Golf VI Sportwagen
      04-09-2011 11:29 PM #5
      IF the cables are there (harness)
      You need:
      1K0 953 549 CD
      My Beetle is a chick car and my wagon is a mom´s car. But I really don´t care about stereotypes.
      "Your Golf Sportwagen is not a true MK VI, its only a Mk V with a bolted on Golf front and MK VI electronics"
      At least I got IRS, proper gauges and interior and a decent Hood lift strut"
    6. Junior Member spalanca's Avatar
      Feb 22nd, 2011
      turin
      04-27-2011 05:29 AM #6
      yesterday i've asked to my friend to scan another gti My2011 with MFSW installed, to see what module they install in the VW factory.
      It's a 5k0 953 569 K (which has been now replaced with 5k0 953 569 G).
      the module 1K0 953 549 CD should be ok for cars up to my2010.
      can anybody tell me if this module 5k0 953 569 G fits with my base my2011 gti?
    7. Junior Member spalanca's Avatar
      Feb 22nd, 2011
      turin
      05-04-2011 04:35 AM #7
      update:
      With this setup you can add MFbuttons to the base version on GOLF gti steering wheel, without changing the airbag, wiper lever, and the steering wheel itself.
      you need theese parts:
      5K0 953 549 B (electronic control module on steering column for my2011 models. The std. 5K0 953 549 C is not enough)
      5K0 998 537 B (MF buttons plate)
      5K0 971 584 A (airbag cable)
      5K0 959 542 (control module INSIDE the steering wheel)
      After mounting thees parts you will need to recode with vag com cable.
      You have to disable the MFD commands via wiper lever to avoid conflicts with the new buttons and to enable the new parts.
      If you do not change the levers and stay with 5K0 953 513 S you will get a "bad coding warning" but everything is fine. If you want to eliminate this warning you have to swap also the 5K0 953 513 S with the version without the MFD buttons on wiper lever.
    8. Member blackdiamond's Avatar
      Jun 23rd, 2011
      San Francisco East Bay
      2011 GTI, 2008 Rabbit
      07-06-2011 11:47 PM #8
      Is this something a service department would want to take on, or is more of a "hack"?
    9. Junior Member spalanca's Avatar
      Feb 22nd, 2011
      turin
      08-11-2011 06:39 PM #9
      after long time i have found the right long coding string to get rid of all the errors in the ECU.
      first of all, you need all theese parts, as I said before.
      5K0 953 549 B
      5K0 998 537 B
      5K0 971 584 A
      5K0 959 542
      5K0 953 513 M (with cruise control)
      then start VCDS and put this code in module 16 (steering wheel) 108A140000
      it does work for gti / gtd with manual gearbox and cruise control. Zero errors in ecu
      @blackdiamond: if you go to a service with the part numbers above and the coding they should fix everything for you, but this mod is a matter of 1 hour even if you are not an expert. In my opinion this is such an easy job that a service dept, would cost too much!
    10. Member
      Dec 19th, 2010
      201 - Jersey
      Shadow Blue GTI
      08-11-2011 06:59 PM #10
      save a little money and look for a 2010 version
      thats what i did
    11. Member blackdiamond's Avatar
      Jun 23rd, 2011
      08-12-2011 01:39 AM #11
      Quote Originally Posted by spalanca View Post
      Thanks! It's on my short list and my local mechanic has agreed to give it a shot. I haven't seen anyone price these parts out. What's the ballpark?
    12. 08-12-2011 02:21 AM #12
      Are you sure about that last part number? The closest I can find at Keffer VW is part number 5K0-953-513-M-9B9 The description sounds right though and I found all of the other parts.
    13. Junior Member spalanca's Avatar
      Feb 22nd, 2011
      turin
      08-12-2011 05:57 AM #13
      9b9 should refer only to the color of the wiper lever (black). anyway, your part number is right.
      remember that the important thing is to order the part WITH cruise control, but WiTHOUT the multfunction display buttons on wipers lever.
      you can also try thecode i posted without changing the original levers on gti/gtd, it works, but there is a conflict on the cruise control button. If you dont mind you can save some money. I didn't like to have issue on the ecu so in the end i changed also the wiper lever.
    14. n00b
      Oct 14th, 2013
      Jakimovski
      2011/Golf 6 TSI
      10-14-2013 09:33 AM #14
      Hi to everyone
      I have Golf 6 and on my old steering wheel don't have controls,now I putted steering wheel with controls from golf 6 R...what I need to do to work the controls on RNS310.
      To work only the controls for radio!
      Thanks have a nice day
    15. Member
      Jul 27th, 2012
      greenbelt md.
      2012/GTI 1989/cabriolet
      01-11-2014 07:41 PM #15
      save
      Have 1989 cabriolet vr6
      Had mk6 GTI
    16. n00b
      Jun 20th, 2014
      Ukraine, Kharkiv
      Volkswagen CC, 2015, 2.0 TDI, 6MT
      06-24-2014 04:52 AM #16
      Guys, It seems that I have similar problem with my base Passat B7. Can you help me?
      http://forums.vwvortex.com/showthrea...W-installation
    17. Member
      Jan 20th, 2014
      Boston ma
      mk6 R
      11-15-2014 07:45 AM #17
      I have read that that if you have the mf wiper stalk these buttons are direct plug in along with some coding. But according to this thread that appears not to be the case?
    18. Member
      Feb 16th, 2008
      Tucson
      2012 GTI
      04-03-2016 07:04 PM #18
      update:
      While I have a GTI with a flat bottom, control-less wheel, I can confirm that buying these parts and a little vagcom works.
      EDIT: super mega necropost, sorry!
