VWVortex.com - Riddle me this (screaming auxillary water pump) ...
    Results 1 to 5 of 5
    Thread: Riddle me this (screaming auxillary water pump) ...
    1. Member thevisualedge's Avatar
      Dec 31st, 2003
      Texas
      1993 Corrado VR6, 2004.5 Jetta GLI, 2004 Ford F150 :)
      08-29-2010 07:23 PM #1
      Below is a link to a video I shot of my auxillary water pump, screaming like an effing banshee. And it's definitely the auxillary pump--when I pull the electrical connector, the sound stops instantly.
      Note--this was happening with an old water pump, so I bought a new one, installed it, and am getting the EXACT same noise. That's what the video is of. Ugh.
      I've heard a rumor that if there are any air pockets flowing through the pump, it could make this kind of noise, but if that's true, how the heck are you supposed to install it? I thought it was just pull-out-the-old-one-and-put-in-the-new-one?
      Thoughts?
      http://www.youtube.com/watch?v=h4sAz3qM5fE
    2. Member Wirbelsturm.VW's Avatar
      Sep 23rd, 2007
      The Street of the Willows, PA
      2010 Audi A3 TDI 1992 Corrado SLC
      08-29-2010 07:39 PM #2
      My aux water pump makes the same exact noise, but not very often. On rare occasion after running the car for a long time it will make that sound for 20 seconds max then stop. Can't really help you on the take out/install issue. i would assume the same as you.
      HIBERNATION
      PA/DE
    3. Member DUBZAK's Avatar
      Oct 26th, 2009
      Doin' W3rk at the Shop or my House
      Corrado SLC, Audi A8 QUATTRO, B6 ULTRASPORT MT6
      08-29-2010 07:50 PM #3
      Air in the system is the culprit. Burp the system to ensure coolant running through the pump as that also cools it and keeps it from blowing up.
      |Corrado SLC 2.9LVR6|Corrado Keyless Entry | A8 "Grape Ape" | SPOONFEDTUNING |FOURSEASONTUNING|DUBNUTZ|
      Quote Originally Posted by pileofredparts View Post
      Do you guys remember the time that Ryan kid started mixing and matching rods and end caps and then his motor wouldnt turn over? I do
    4. Member thevisualedge's Avatar
      Dec 31st, 2003
      Texas
      08-29-2010 08:32 PM #4
      It was air in the system. I ran the engine with the expansion tank open, adding cooling as necessary. I let it run until both fans were running, then topped it off again, let any remaining air burp itself off, turned off the engine, watched the level, screwed the cap back on.
      No more screaming banshee.
    5. Member Wirbelsturm.VW's Avatar
      Sep 23rd, 2007
      08-30-2010 08:57 PM #5
      Quote Originally Posted by thevisualedge View Post
      I'll have to try this
      HIBERNATION
      PA/DE
