VWVortex.com - MEGASQUIRT IN JAMAICA........my family car turned project
    Page 4 of 8 FirstFirst 12345678 LastLast
    Results 76 to 100 of 186
    Thread: MEGASQUIRT IN JAMAICA........my family car turned project
    1. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      '79 golf 1 (RHD) '92 passat glx (lhd)
      02-14-2011 09:19 PM #76
      Quote Originally Posted by justvwpower View Post
      nope....the water pump is ok .... the crank pulley is mk3 ABA no mods .... the w/p pulley is fabbed ... plz see the thread ....
      to make my self clear .... YESS the water pump turns backwards ... but it does no harm ..... the european 1.6 8v has an all in 1 serpentine system & the belt is routed the same way
    2. Junior Member WOB16V's Avatar
      Feb 9th, 2011
      Virginia
      92 VW Passat 16V.04 Jetta TDI
      02-15-2011 01:17 PM #77
      maybe that european setup has the pallet on the pump diffrent....I don't know....just curios
    3. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      02-16-2011 12:12 PM #78
      Quote Originally Posted by WOB16V View Post
      nope its the same water pump .... same repalcement pump as the "regular pump" ...NO DIFFERENCE IN THE DESIGN WHAT SO EVER ......
    4. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      02-17-2011 10:03 PM #79
      !!!!to hell wid FORD edis .... GOT MY 4G63 CAM ANGLE SENSOR 2 DAY .... gonna be fitting it into the 16v distributor hole soon ...
      no crank wheel to weld & sensor to position .....its compact & reliable .....btw i realize that the Mitsubishi.... Mazda... Nissan... cas are all the same ..... jus how they m8 to the cams is the difference ... but the insides are very much identical so much so u can swap them around ....
    5. Member MOTA BOY's Avatar
      Aug 21st, 2007
      Daruvar, Croatia
      VW Golf MK2 1990 16V KR and GTD.
      02-19-2011 02:40 PM #80
      Damn nice!
      Keep on going!
    6. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      02-23-2011 11:11 PM #81
      2day i found out i have the 1g cas actually ... the differenve ... the base that goes in2 the cylinder head is smaller ....but i'm not phased .... wud like to machine the 16v distributor housing & put the mitsu cas housing on the 16v waist & weld ....
    7. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      03-05-2011 11:45 PM #82
      sorry bout takin long to post stuff ...but i have been working ...so i'll be starting again soon ....
    8. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      03-15-2011 01:20 AM #83
      2DAY I FABBED UP A HEAT SHIELD .4 MY 16V ENGINE ...BECAUSE WITH THE NEW tps ON THE THROTTLE BODY I CANNOT USE Back THE ORIGINAL TPS HEAT SHIELD ..PLUS I INSTALLED THE iat IN2 THE BACK OF THE INTAKE MANIFOLD ....so fearing that the exhaust manifold might damage them i did the precautionary measures ....build a heat shield....
      using asbestos as insulation ....
      all put together ....
    9. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      03-21-2011 10:51 AM #84
      putting it all back together yesterday ...i realize that the nipples on the brake master check valve dryrot & broke off ...now while it wud be nice to get a vaccuum manifold (love the 1 4m 42 DRAFT DESIGNS) this is JAMAICA so we do most things on a budget ....so i'm gonna try & repair it ...... worse i dont c it on the net 4 sale .....
    10. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      03-23-2011 12:45 AM #85
      vw check valve repaired ....
      i just used some epoxy around the gaps just to make sure it wont leak ...
      next stop fitting up the rest of my fuel rail ....
    11. Member 16v_HOR's Avatar
      Jul 21st, 2005
      Grabber Blue and German rust
      03-23-2011 01:04 AM #86
      I haven't been in this thread in a bit, glad to see you still plugging away at it. Good idea ditching the edis, those things suck
      Quote Originally Posted by SGLoki View Post
      Mk1people > Mkrestofpeople.
      Quote Originally Posted by unleashedd View Post
      wow this has escalatored quickly. dude now has vr6 up front, w8 out back, he's crying metal tears, and people are demanding consumption of feces... i dont know whats real anymore!
    12. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      03-24-2011 01:08 AM #87
      my fuel rail is finished & installed ...still need a 02a starter ....these things hard to get here ....
      pix to follow tomorow ....
      also made a battery charger out of an old transformer i found ...not working ...after all that effort ... not giving up ...sort it 2 morrow ...
    13. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      03-25-2011 12:22 AM #88
      By darks_aint at 2011-03-24
      wish if i cud start driving ...
    14. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      03-31-2011 02:28 AM #89
      shud be getting a starter 2morrow trading a new 4 wire oxygen sensor for it .... i hope ....
    15. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      04-01-2011 10:57 AM #90
      nobody never told me that a vr6 starter was different to a passat starter in the manual transmission
      so its back to the drawing board .....
      gonna start working on the shifter .....(i actually 4got about it )
      A/T out ......
    16. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      04-11-2011 11:27 AM #91
      i finished rebuilding the manual gearbox & am about to put it in ......but i have to rebuild the throw out bearing 1st as i cannot get any to purchase in JA ...so pix are to follow
    17. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      04-14-2011 01:37 AM #92
      used this tool to help pull it up
      i then degreased it & fit it back again
    18. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      04-14-2011 02:10 AM #93
      i'm not going to use the front coolant pipe on the 16v head ...as i think its a nuisance & the x-flow & the 20v dont use one .....so i decide to put my CTS there so the side of the head can look clean .........so after cutting out a chunk of aluminum & boring the 3 holes its time to shape it .....
      boring the 1st hole ....
      boring the 2nd & bigger hole to house the body of the CTS w/ the O- ring ..
      finished ..... nice whn ur work place has its own machine shop
      getting ready to fit it .....
      need to do some porting here ...realize the the shape otf the pipe doesn't correspond with the shape on the head ....
      my weapon of choice
      finished
      making the bracket to hold down the CTS ..... sorry for the blur ...had the wrong zoom selected on the camera ..it was farsighted ....
      completed ...
      this is how it shud look ...
      with the bracket on ....
      trial fit ...
      installed....
    19. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      04-14-2011 10:35 PM #94
      i cant seem to find a pedal box either ...for the passat ..so i've decided to make 1 by m8ing a pass auto pedal box with a mk3 golf manual pedal box .....
      this was decided after i found that the mk3 pedal box doesnt fit so well w/o mods ///better to mod the box ....
    20. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      04-19-2011 11:02 PM #95
      i got a polo starter housing 2day ....so idecided to change it over ...on pulling off the motor housing i decided to overall it ....
      looks cruddy
      after further pulling ...i put the parts in the parts washer 2 soak overnite ...
    21. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      04-22-2011 04:53 PM #96
      got the parts cleaned in a mild caustic solution ...... now in assembly i realized that the bushings need changing in the back of the starter ...... i decided to check the 1 in the bellhousing also ...yep its worn also ...so now i have to go get 2 ..... i h8 holidays ...
      !!!!!!!!!HAPPY EASTER!!!!!!!
    22. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      04-22-2011 09:52 PM #97
      remember the Mitsubishi C am A ngle S ensor..... i have begun to TRY & m8 it to the 16v distributor housing
      By darks_aint at 2011-04-22
      yanking the bearing & seal out of the Mitsubishi CAS
      shown is the seal still in the housing & the bearing
    23. Member Bozwell's Avatar
      Aug 25th, 2003
      your mom's
      hoverboard
      04-27-2011 12:11 AM #98
      lookin good!
    24. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      05-03-2011 10:50 PM #99
      been away from the project for a while ....been doing O.P.P. (other ppl's projects ) ...right now i'm converting a mk2 golf 4m the dreaded CIS-E to Digifant 2 ..... soon be back here
    25. Member justvwpower's Avatar
      Jul 7th, 2007
      Jamaica
      05-30-2011 08:50 AM #100
      not abandoning the project @2 all ...circumstances came up i had to relocate ma garage b4 time .....wish i had finished it b4 ...but hey its a pioneering adventure
      By darks_aint at 2011-05-30
