while waiting to buy the software 4m TUNERSTUDIO ..... i have been busy ....ported a g60 throttle body ...modyfird my front engine mount bracket .....& the likes ...photos coming soon ....
#141
nylon lines & fittings to finish up
homade adapter
line from lift (intank) pump to filter
making the hard lines (dont like the look of rubber hoses & clamps)
completed line from pump to engine
#142
#143
original mount ...saw my friend broke 1 of these ...so decided to look a stronger 1 if not make it stronger .....planned to use the 1 in the upper left ...it comes off a automatic transmission ...need to c if it can work ....
showing the weakness ....
being boxed ...it was much stronger .....& only 1 hole was out of alignment ...just had to slot it .....
the little hole to the right of the long 1
ground off the weld that holds the nut on the inside ....
measured the diameter of the original hole ...center punched the space besidre the hole & started boring with a small bit 1st then went to a bigger 1 as i progressed
looks better ,stronger ...now i know i can go faster ....lol 4got to take pic of the other 1 mounted ..but it wasn,nt stronger ....
#144
saw this on TM Tuning ..thought i cud do it ....
this is my attempt ....
G60 TB for when i have unnatural aspirations .....!!!PORTED!!!!
with the bypass port off
the plenum side ...
ported the bypass assy. also
another shot of beauty ....lol
another 1 2 b done ....
the original look
#145
Crazy!
#146
#147
Keep on, i belive you will succeed!
#148
Tunerstudio & Megalog viewer paid for & registered now awaiting my bluetooth interface![]()
#149
bought this 2day ......
the picasso of all manifolds ....
another step in my Unnatural Aspirations .....
#151
my megasquirt interface arrived this evening ....gonna pick it up in the morning![]()
#152
bluetooth interface ......all configured & ready
with modes of power supply
#153
sorry to not have been here ....work in the garage ...gotta pay the bills .....right now am busy converting a diesel to gas ....& its not pretty ....
rechecking the wiring in my car b4 i fire up the megasquirt .....then its programming time ....
o by the way ....some 1 in the st8s love me ....
this is what i got![]()
its a wastegate controller ...by vw ...next step in achieving boost nirvana
#154
have patience ...have alot of work in the garage..especially 1 where i am converting a van 4m diesel to gas .....PITA....2 months & counting ....evn have to be building whole circuits...now have to be facing a tropical storm/hurricane
http://icons-ak.wunderground.com/dat...201218_sat.jpg
so ....
I'LL BE BACK .....
like the terminator![]()
#156
Fixing up the grage after the hurricane more like expansion ....even building a powder coating oven ,still have the infernal van conversion ....electrical wont work properly ....soon sort it ....& i'll be back on my project ....![]()
#157
1J0407613G
wud like to know if this is the same part as this :
1H0407613B
i think so ..... A PAIR OF THESE IN JA COST 20K$ja ....
NEED THEM TO RUM MY 11.3 big rotors ....
IF THEY ARE THE SAME (& I think so 200%) thn the parts retailers making big bucks off us hiding behind a serial # change .....go figure
#158
I'm not sure about the hubs but I think it's pretty F'n cool that the power of the internet and globalization has enabled islanders like you to share your automotive creations.I'm building a megasquirted 16V but I think I might beat you.
#159
#160
!!!! HAPPY HOLIDAYS TO U'ALL !!!!!! & please take care of yourselves so we can meet again next year .......
merry x mas & happy new year .....
to tease u alll i.m writing this in my shorts & T-shirt in the lovely warm sunshine
so untill next year
#161
xmas came l8 4 me but its here .....look wht i got in my hands 2 day ....
genuine turbonetics deltagate wastegate ....another step accomplished .......cost ...$50US
need turbo manifold now .....
working on getting the wheel hubs still![]()
#162
next time u see this waste gate it will be polished ......stick around![]()
#163
#164
#165
still here .....just a bit depressed .....bought the mk4 hub to fit ma big brakes on ma b3 ....only to find out that it cannot fit the spindles ....it binds against the edge ....it cost me 10000$ ....thats alot of moolah 100$US ....so i'm a bit depressed ...& scared to spend to try another 1 ..but i was told that i need the 94 vr6 corrado hub ....but scared to try ..as tht is 13000$/ $130US ....!!!!DAMN!!!!
!!!!!!!!ANY BODY CAN HELP!!!!
#166
A good machine shop might be able to help you there.
#167
I now know that i need the corrado vr6 hubs ...so i am gonna get them .....FYI ...no "good" machine shop here in JA.....in the mean time i decided i needed a fuel pressure tester .....but cannot afford the 100$US for it ...so i decided to make 1 ....
here is the gauge off a old air compressor .....
mated to a "T" fitting ....
braided hose to be attached
check (schrader) valve to make tha adapter .......
this will be trans formend in2 to parts ....
parts to make 1 of the adapters
parts to make an adapter
the union crimped to the hose that goes to the gauge
part for adapter taken
the other end of the hose that goes to the adaptor .....
adapter
the adapter that goes in the fuel line
the bleed valve
gauge onto hose
schrader attachment ....
fuel line adapter assembled ...schrader valve to prevent fuel spillage ....
schrader valve
adapter attached to gauge assembly
bleed valve
another vu
fitting it in2 a old case
the case ...
the full assembly cost $3000JA $30US .....& it works more adapters to come
my inspiration
#168
I'M PROUD TO BE JAMAICAN ...![]()
#170
#171
getting over the frustration of wasting so much $$$$ on the wrong part .....& also concentrating on building the garage & doing the work to fund it ......in the meantime my friend made something for me for me .....
thanx H. Ledge. will make it worth ur while
will post soon ....
