Results 36 to 70 of 86
Thread: Change comfort turn signals count in MKVI
  1. Member Code3VW's Avatar
    May 5th, 2004
    Gilbert, AZ
    '10 CW JSW TDI 6MT
    02-16-2011 12:06 PM #36
    There still isn't a fix for this?
    I used my vagcom to enable this on rockstar's 2011 GTI and after a bunch of turning the car on and off, and enabling and disabling the comfort turn signal, it worked.
    My girlfriend just bought a 2011 Golf TDI and I can't get this to stick at 5, it keeps it at 3.
    OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
    Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
  2. Member quailallstar's Avatar
    Dec 2nd, 2001
    Aus Liebe zum Automobil
    @LuvGermanCars
    02-16-2011 12:08 PM #37
    Quote Originally Posted by Code3VW View Post
    Same here with my 2011 TDI No luck so far.
    2Ø11 Candy-Weiß Golf 6 2,0 6-Gang DPF TDI BLUEMOTION Technologies™ Highline 4-Türen ▀ 2Ø11 Tornadorot Jetta 6 2,5 Highline 4-TürenØ8 Deep Blau Perleffekt Golf 5 .:R32 3,2 DSG 4-MOTION™ 3-Türen ▀ Ø8 Tornadorot Passat 3C Variant Highline 2,0 TFSIØ6 Tornadorot Golf 5 GTI 2,0 DSG TFSI 3-TürenØ2 Indigo Blau Perleffekt Passat 3BG Trendline 1,8T 4-Türen
  3. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    02-16-2011 09:58 PM #38
    Yes, I'm bummed there's no solution for 2011's yet. One of the major reasons I bought a VCDS cable from Rosstech was for this feature
    Can you elaborate on this? Like others on this board, I tried on my 11 TDI and found that even though I can enter a "5" and it keeps the value stored on the ECU, the actual number of flashes is always 3. When you had success with the 11 GTI, did you mean to say that the number wasn't stored after several unsuccessful attempts, and only when it was stored in memory did it work? Or did you mean that you entered say "5", it stored the value, but still only flashed 3 times, but after re-entering 5 a few more times, it worked?
  4. Member Theresias's Avatar
    Feb 11th, 2004
    Magdeburg, Germany
    '10 Skoda Octavia vRS Combi / '67 Ford Mustang Conv.
    02-17-2011 05:10 AM #39
    As mentioned in other places, we are looking into it but so far it appears that this is indeed an issue with the control module firmware and not VCDS. Once we have a solution you can be certain that we will keep you informed.
  5. n00b
    Feb 17th, 2011
    Spain
    2011 Golf 1.6 TDI Sport (Highline) DSG7 MKVI MY11 >WK45 EU
    02-17-2011 07:56 AM #40
    I have successfully encoded the flashing of comfort turn signal.
    I have a MY11 Golf MKVI purchased in February 2011, made after week 45, with European specifications, and through the VCDS (first with the 10.63 and after with the 11 beta) adapted the channel for 4 flashes and recorded (without errors) and did not change (although the scan appeared to the value 4 instead of 3).
    Yesterday, through the FIS (I have factory-installed premium FIS), turn off the flashing of comfort turn signal and I went to turn on ..... and finally it works!
    Now I have 4 intermittent flashes.
    I hope that helps
  6. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    02-17-2011 08:30 PM #41
    Quote Originally Posted by joserogo View Post
    I hope that helps
    Well, you inspired me to try again on my MY11 NA Golf TDI, but no luck.
    What is FIS? Is that the same as the MFI?
    Can you post an autoscan?
    What happens if you try to change the number of flashes to another value -- does it take it immediately, or do you have to cycle the engine multiple times?
  7. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    02-17-2011 08:47 PM #42
    HOLY CRAP I GOT IT TO WORK
    1. Change the number of flashes to the desired number. Close out VCDS.
    2. On the MFI, Navigate to Settings --> Light & Vision --> Factory Setting
    3. At the prompt "Set to factory settings for lights & vision?", select OK.
    4. Marvel in amazement as the turn signal magically flashes 1, 2, 4, or 5 (yes 5) times.
    No more, uh, tired left index finger for me!
    I have a 2011 Golf TDI, North American, build date 7/2010.
    Here's my autoscan, not that it's likely that relevant:
    Code:
    VCDS Version: Release 10.6.3 (x64)
    Data version: 20101206
    Thursday,17,February,2011,17:44:06:55943
    Chassis Type: 7N0
    Scan: 01 03 08 09 15 16 17 19 1C 25 2E 42 44 46 47 52 55 56 62 72
              77
    VIN: WVWNM7AJ5BW041198
    01-Engine -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: OK 0000
    09-Cent. Elect. -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    19-CAN Gateway -- Status: OK 0000
    1C-Position Sensing -- Status: OK 0000
    2E-Media Player 3 -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    55-Xenon Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
       Part No SW: 03L 906 019 DA    HW: 03L 906 019 DA
       Component: R4 2,0L EDC G000SG  7271
       Revision: 12H08---    Serial number:
       Coding: 0050072
       Shop #: WSC 01357 011 00200
       VCID: 6DFF1E2D0D17
    No fault code found.
    Readiness: 0 0 0 0 0
    Address 03: ABS Brakes (J104)       Labels: 1K0-907-379-60EC1F.clb
       Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
       Component: ESP MK60EC1   H30 0106
       Revision: 00H30001
       Coding: 114B400C492600FB880C02ED92210042B70000
       VCID: 74C90B496E3D
    Address 08: Auto HVAC (J301)       Labels: 3C8-907-336.clb
       Part No SW: 3C8 907 336 AJ    HW: 3C8 907 336 AJ
       Component: Climatic      H14 0305
       Revision: 00009001
       Coding: 0000001002
       ASAM Dataset: EV_Climatic A01005
       ROD: EV_Climatic_VW36.rod
       VCID: 75CF364D6547
    Address 09: Cent. Elect. (J519)       Labels: 1K0-937-08x-09.clb
       Part No SW: 1K0 937 087 L    HW: 1K0 937 087 L
       Component: BCM PQ35  H   104 0615
       Revision: 00104 AE
       Coding: 6D180A3A80252AC40088008574008D04402D1F86534D8560648020200040
       VCID: 3A55E5710CD9
       Part No: 1K1 955 119 F
       Component: Wischer 23061  21  0512
       Coding: 009795
    Address 15: Airbags (J234)       Labels: 5K0-959-655.clb
       Part No SW: 5K0 959 655 B    HW: 5K0 959 655 B
       Component: AirbagVW10G   021 0706
       Serial number: 003C4R00JPHL
       Coding: 00003031
       ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
       ROD: EV_AirbaVW10SMEVW360_VW36.rod
       VCID: 3957FA7D09DF
       Seat occupied recognition:
       Part No SW: 5K0 959 339     HW: 5K0 959 339
       Component: BF-Gewichtss.  007 0002
       Serial number: ---0000R--00058E2J00
       Driver's Airbag Crash Sensor:
       Part No SW: 5K0 959 354     HW: 5K0 959 354
       Component: S.Sens.Fahr.V  H01 ----
       Serial number: 3572MSME11213354ZZZD
       Passenger Side Airbag Crash Sensor:
       Component: S.Sens.Beif.V  H01 ----
       Serial number: 3582MSME542B2154ZZZS
       Driver's Rear Airbag Crash Sensor:
       Component: S.Sens.Fahr.H  --- ----
       Serial number: 3512QSME12036526ZZZG
       Passenger's Rear Airbag Crash Sensor:
       Component: S.Sens.Beif.H  --- ----
       Serial number: 3522QSME26046467ZZZR
       Driver's Front Airbag Crash Sensor:
       Component: F.Sens.Fahr  --- ----
       Serial number: 35527SME06070323ZZZ/
       Passenger's Front Airbag Crash Sensor:
       Component: F.Sens.Beif  --- ----
       Serial number: 35627SME2E0E5022ZZZG
    Address 16: Steering wheel
    Cannot be reached
    Address 17: Instruments (J285)       Labels: 5K0-920-xxx-17.clb
       Part No SW: 5K0 920 971 C    HW: 5K0 920 971 C
       Component: KOMBI         H03 0406
       Serial number: 00000000000000
       Coding: 270F01
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
       ROD: EV_Kombi_UDS_VDD_RM09_VW36.rod
       VCID: 2F43C425C79B
    Address 19: CAN Gateway        Labels: 7N0-907-530-V1.clb
       Part No SW: 7N0 907 530     HW: 1K0 907 951
       Component: J533  Gateway   H27 0602
       Revision:   H27       Serial number: 260610F2001345
       Coding: E9817F0610161200000002
       VCID: EDFF9E2D8D17
    Address 1C: Position Sensing        Labels: 1Kx-919-xxx-1C.lbl
       Part No SW: 5N0 919 879     HW: 5N0 919 879
       Component: Kompass         001 0001
       Revision: 00001000    Serial number: 1225223R9BHR06
       Coding: 0000002
       VCID: FEDDA961D071
    Address 25: Immobilizer (J334)       Labels: 5K0-920-xxx-25.clb
       Part No SW: 5K0 953 234     HW: 5K0 953 234
       Component: IMMO          H03 0406
       Coding: 000000
       Shop #: WSC 00000 000 00000
       ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
       ROD: EV_Immo_UDS_VDD_RM09_VW36.rod
       VCID: EAF59531BCF9
    Address 2E: Media Player 3 (J650)       Labels: 5N0-035-342.lbl
       Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
       Component: SG EXT.PLAYER H13 0111
       Revision: A1001003    Serial number: 7668227646
       Coding: 010000
       VCID: 27732C05EF6B
    Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
       Part No SW: 5K0 959 701 B    HW: 5K0 959 701 B
       Component: Tuer-SG         009 2113
       Coding: 0001204
       VCID: 3147C25DD1AF
    Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
       Part No: 1K0 909 144 J
       Component: EPS_ZFLS Kl. 70     3001
       Revision: 00H17000
       VCID: 3147C25DD1AF
    Address 47: Sound System (R12)       Labels: 5K0-035-456.clb
       Part No SW: 5K0 035 456     HW: 5K0 035 456
       Component: KonzernAmp 8K H06
       Revision: --------    Serial number: BP218109093456
       ASAM Dataset: EV_AudioVerst8KanalBNO1 A01003
       ROD: EV_AudioVerst8KanalBNO1_VW36.rod
       VCID: E7F3EC05AFEB
    Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
       Part No SW: 5K0 959 702 D    HW: 5K0 959 702 D
       Component: Tuer-SG         009 2139
       Coding: 0001204
       VCID: 3449CB492EBD
    Address 55: Xenon Range        Labels: 5M0-907-357-A.lbl
       Part No SW: 5M0 907 357 C    HW: 5M0 907 357 C
       Component: AFS-Steuergeraet    0142
       Revision: 00H04000    Serial number:
       Coding: 1446940
       VCID: 3449CB492EBD
       Part No: 7L6 941 329 B
       Component: AFS-Lst.-Modul l    0004
       Coding: 00000022
       Component: AFS-Lst.-Modul r    0004
       Coding: 00000022
    Address 56: Radio (J503)       Labels: 5M0-035-1xx-56.clb
       Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
       Component: Radio Prem-8  H13 0043
       Revision: -----26S    Serial number: VWZ4Z7K1147551
       Coding: 0101000001
       VCID: 61E7721DC1CF
    Address 62: Door, Rear Left        Labels: 1K0-959-703-GEN3.lbl
       Part No SW: 5K0 959 703 C    HW: 5K0 959 703 C
       Component: Tuer-SG         007 2101
       Coding: 0001168
       Shop #: WSC 01357 011 1012552
       VCID: 3449CB492EBD
    Address 72: Door, Rear Right        Labels: 1K0-959-704-GEN3.lbl
       Part No SW: 5K0 959 704 C    HW: 5K0 959 704 C
       Coding: 0001168
       VCID: 354FF64D25C7
    Address 77: Telephone (J412)       Labels: 7P6-035-730.clb
       Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
       Component: TELEFON       H05 0440
       Revision: 1B001001    Serial number: 00007668223608
       Coding: 0A00000000010100
       ASAM Dataset: UHVNA A01007
       ROD: UHVNA_VW36.rod
       VCID: 3245CD51D4A9
    End   ---------------------------------------------------------------------
  8. Member quailallstar's Avatar
    Dec 2nd, 2001
    @LuvGermanCars
    02-17-2011 09:15 PM #43
    Quote Originally Posted by phatz314 View Post
    Code:
    Chassis Type: 7N0
              77
       Coding: 0050072
       VCID: 6DFF1E2D0D17
       Revision: 00H30001
       VCID: 74C90B496E3D
       Revision: 00009001
       Coding: 0000001002
       VCID: 75CF364D6547
       Revision: 00104 AE
       VCID: 3A55E5710CD9
       Coding: 009795
       Coding: 00003031
       VCID: 3957FA7D09DF
    Cannot be reached
       Coding: 270F01
       VCID: 2F43C425C79B
       VCID: EDFF9E2D8D17
       Coding: 0000002
       VCID: FEDDA961D071
       Coding: 000000
       VCID: EAF59531BCF9
       Coding: 010000
       VCID: 27732C05EF6B
       Coding: 0001204
       VCID: 3147C25DD1AF
       Revision: 00H17000
       VCID: 3147C25DD1AF
       VCID: E7F3EC05AFEB
       Coding: 0001204
       VCID: 3449CB492EBD
       Coding: 1446940
       VCID: 3449CB492EBD
       Coding: 00000022
       Coding: 00000022
       Coding: 0101000001
       VCID: 61E7721DC1CF
       Coding: 0001168
       VCID: 3449CB492EBD
       Coding: 0001168
       VCID: 354FF64D25C7
       ROD: UHVNA_VW36.rod
       VCID: 3245CD51D4A9
    Oh snap! Im going to go out and try this ASAP.
  9. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02 Gti, 12 Tiggy SEL
    02-18-2011 08:54 AM #44
    Hi! This sounds like good news. Do the 2011 clusters have the menu like this "Comfort light"?
    http://i778.photobucket.com/albums/y...e/DSC02322.jpg
    http://i778.photobucket.com/albums/y...e/DSC02301.jpg
    If the setup is different and this is the fix, please post a picture and I'll link it from the sticky.
    Dana Marie
    P.S. No Scan = No Soup
  10. Member quailallstar's Avatar
    Dec 2nd, 2001
    @LuvGermanCars
    02-18-2011 10:01 AM #45
    Quote Originally Posted by Dana @ Ross-Tech View Post
    Dana yes they do. Mine does have this menu.
  11. Member
    Jul 16th, 2010
    Sacramento, CA
    2010 A3 TDI
    02-18-2011 11:58 AM #46
    Does this apply to the A3?
  12. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    02-18-2011 12:58 PM #47
    Quote Originally Posted by bmw511 View Post
    Dunno, try it! I suspect yes.
  13. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    02-18-2011 01:24 PM #48
    Yes, I can confirm that my car looks similar to that.
    Here is a more detailed version of the procedure that I followed, with pictures from my MFI:
    AFTER changing the desired # of flashes using VCDS, disconnect the cable and cycle the ignition for good measure. (I did not start the engine, as others have reported.) Re-insert the key to the ACC position if you haven't already.
    Then, on the dashboard MFI, navigate to "Settings":
    photo 1
    Click "Lights & Vision" (highlighted above). This takes you to the following submenu (your options may be different; e.g., "Coming home" is not enabled by default):
    photo 2
    Click "Factory setting" (highlighted above). This takes you to this submenu:
    photo 3
    Click "OK" (highlighted). This seemingly does nothing, and takes you back up to the parent menu.
    Once you have done this, the # of flashes you set in VCDS will work correctly. From what I could tell, nothing else is changed -- I had guessed that I would have to re-enable "Coming home", for example, but it left all that stuff alone.
    Obviously, this additional step is only required for some 2011s.
    Just my observations:
    I've noticed sporadic reports of people having had success by flashing it multiple times, turning the engine off and on, etc. In my experience with embedded controllers and the like, sometimes they can be a little "squirrelly", and the VAG ECU seems to be no different. With VAGCOM, I've found you have to very deliberate/slow, changing one thing at a time, disconnect and power cycle between each change, and so forth. If you go too fast, you can get unpredictable results, and simply cycling the ignition or re-flashing a code fixes it. I bet the folks who have had success by flashing multiple times, etc. basically took advantage of a bit of instability in the PIC and effected a reset without knowing it, perhaps.
    Here's what really intrigues me though. I wonder what other settings can be enabled on the mk6 using this general procedure (VCDS + MFI reset). There are many interesting-looking settings I have found in VCDS that don't seem to do anything when I toggle them, so I switched them back -- but I wonder if I should try these settings in combination with the MFI reset as well.....
  14. Member GenDV138's Avatar
    Jul 16th, 2010
    Falls Church, VA
    2011 CSG GTI 6MT
    02-18-2011 01:25 PM #49
    I'll have to see if this works on my 2011 GTI tonight or tomorrow, thanks for the info phatz! I'll report back whether it works or not.
  15. Junior Member
    Jul 21st, 2010
    MA
    2011 GTI, Autobahn, 6MT, Tornado Red
    02-18-2011 03:30 PM #50
    phatz314, U da Man!
    Thank you, thank you, thank you!!!
    This has been a source of frustration for while now.
    All I had to do to get this to work was reset lights to factory settings since I had already coded VCDS to a value of 5, many months ago.
    This is on a 2011 GTI.
  16. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    02-18-2011 04:18 PM #51
    Quote Originally Posted by dmichael48 View Post
    phatz314, U da Man!
    Awesome, this is the first confirmation I've gotten that this works on another vehicle!
    Still thinking it's a bug with the rev 0615 BCM, but it sounds like this is a workaround for at least some vehicles.
  17. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    02-18-2011 07:10 PM #52
    I agree, that factory default cluster options seem to resolve buggy problems after coding on the 2010 cars too.
    i.e. If you change cluster coding and the units (speed/time/temp) don't display properly until the car is put to sleep or the defaults are selected.
    I changed the link to that post, thanks for the pictures and detailed explanation!
    • Comfort Turn signals
      Found in Adaptation. From the drop down list, choose the number of flashes and Save.
    Note: 2011 owners may want to see: This thread
    On another note, and possibly another thread, do your fogs as cornering lights work as I described here?:
    • Cornering Lights via Front Fog Lights active
      Found in Coding, Long Coding helper
    Notes: The lights may work under the following conditions:
    1. The headlights must be turned on and the steering wheel must be in the turning direction.
    2. Headlights on, fogs off, turn signal on in the turning direction. Also see Byte 17, Adaptive Light/Cornering Light Variant. This seems to control the fogs as cornering lights with turn signal.
    Some owners have reported that the mentioned Byte 17 coding doesn't alter the turn signal operation, but I don't recall if this is with Halogen and Xenon cars or not?
    Dana Marie
  18. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    02-18-2011 08:21 PM #53
    Yes, I just checked, and my fogs-as-cornering-lights work as you described. And, I can confirm that they work the same as they did before this "mod".
    My vehicle has xenons + the stock North American headlight switch.
    So, explicitly speaking, if and only if the headlights are ON and the fogs are OFF, one single fog light will illuminate if I (1) engage the turn signal in that direction, or (2) turn the wheel in that direction. FWIW, the cornering light doesn't work if you just tap the turn signal stalk (i.e., comfort turn signals).
  19. Member GenDV138's Avatar
    Jul 16th, 2010
    Falls Church, VA
    2011 CSG GTI 6MT
    02-18-2011 10:26 PM #54
    Thanks again phatz, I got the comfort turn signals to work with 5 blinks on my 2011 GTI using your method. Like dmichael, I already had it coded to 5 so all I had to do was reset to factory in the MFI. Using Xenons + Euro switch.
    When I get home, I'm going to see if I can get the fogs as cornering lights to not come on with turn signals using the same method.
  20. Member
    Jul 16th, 2010
    Sacramento, CA
    2010 A3 TDI
    02-19-2011 07:48 PM #55
    I attempted this on a my 2010 A3, if I set it and don't turn the car off, the setting sticks. I had set it to 5 blinks, now if I shut the car off and restart then it only flashes 3 times, even with the adaptation set for 5. I'm not seeing any way to do a Factory Reset from the menu. :-(
  21. Member lolo's Avatar
    Feb 21st, 1999
    6th and 7th VWs
    02-28-2011 10:08 AM #56
    I did this on my 2011 JSW aka Golf Variant. It's manufactured 11/2010 and has the same Lights/Vision MFD as pictured above (but without the Coming Home option).
    I did NOT have to reset the factory settings. I set it to 5, saved and it stayed, even after a few power cycles.
  22. Member phatz314's Avatar
    Jan 13th, 2011
    SF bay area
    2011 Golf TDI
    03-01-2011 03:05 AM #57
    Quote Originally Posted by lolo View Post
    Interesting, maybe there was a bug and they cut in a fix. Mine was built 7/2010.
    Just out of curiosity, what BCM version do you have, later than 0615?
    Edit: oh I see you have a Jetta, that could be the difference
  23. Member quailallstar's Avatar
    Dec 2nd, 2001
    @LuvGermanCars
    03-08-2011 10:35 AM #58
    With the car ignition in ACCESSORY mode I made the change from 3 to 5 signals and it worked. I didn't have to cycle the key or anything.
    All I did was reprogram via vag-com, reset to factory defaults the lighting options and bam it was done.
    5 is perfect
  24. Member toasters's Avatar
    Sep 17th, 2001
    Livermore, CA
    2011 VW Golf TDI
    03-10-2011 02:48 AM #59
    Factory Settings for lights and vision worked for my 2011 Golf TDI. Thanks so much! I was so disappointed when I first VAG-COM'ed my car and it didn't work.
  25. Member lolo's Avatar
    Feb 21st, 1999
    6th and 7th VWs
    03-11-2011 10:57 AM #60
    JSW = Golf.
    I'd note that I had previously set my cluster to UK to turn off those annoying seat belt and door open chimes. I'm not sure if this had anything to do without having to do factory default, or if later manufacturing date has this bug fixed.
    EDIT:
    HTML Code:
       Part No SW: 5K0 937 084 E    HW: 5K0 937 084 E
       Component: BCM PQ35 B    011 0035
       Revision: BG011001
       Coding: 2D380E3F902F3EC4008800816000000401000086535D8560648020000040
       Component: KOMBI         H23 0204
       Revision: X0023007    Serial number:
       Coding: 270F01
  26. Forum Sponsor Dana @ Ross-Tech's Avatar
    Sep 15th, 2009
    Apollo, PA
    03-11-2011 11:38 PM #61
    JSW = Golf.
    Revision: BG011001
    Coding: 2D380E3F902F3EC4008800816000000401000086535D856064 8020000040
    Actually the 2010 JSW, Jetta, Tiguan and Eos all use the same style of 5K0 BCM from Continental.
    The Golf uses the 1K0 (Hella) and the comfort turn problem seems to be 1K0 (SWL 0615) specific.
    Dana Marie
  27. Member golf-zilla's Avatar
    Sep 5th, 2004
    S.E. Wisconsin, USA
    '11 Golf 2dr TDI 6-speed, '09 Challenger R/T 6-speed, '07 Jeep GCL CRD, '96 Corvette Grand Sport Cp
    03-24-2011 04:08 PM #62
    This fix worked perfectly on my '11 U.S. Golf TDI! WooHoo...
    ____
    Bob
  28. Semi-n00b
    Jan 19th, 2011
    so cal
    2011 GTI, old British cars
    03-26-2011 11:35 PM #63
    Yeah stumbled on to this the other day when I hitched up my courage and pushed "Return to Factory Settings" to see what would happen. All of a sudden I had 4 blinks like I asked for a couple of months ago.
    2011 GTI 11/2010 build date.
  29. 03-31-2011 05:28 PM #64
    I started this thread exactly 6 months ago and I was very frustrated because it didn't worked at that time, now I just looked at the thread, went down to the parking lot, did the "factory setting" (with no cable or laptop or anything.....) and YES!!! Finally 5 flashes instead of 3!!!
    THANKS!!
  30. Member
    Jul 16th, 2010
    Sacramento, CA
    2010 A3 TDI
    03-31-2011 05:50 PM #65
    Has anyone figured out how to do a Factory Reset on an A3? I don't have an option in the menu.
  31. n00b
    May 26th, 2011
    NH
    05-28-2011 10:08 AM #66
    I know most of these tweaks are only working ion the H cluster. How do I tell which cluster is installed?
    2011 GTI MK6 DBPM
  32. Member
    Apr 21st, 2011
    Hudson Valley
    2007 jetta wolfsburg / honda V65
    05-28-2011 08:10 PM #67
    chiming in. i did my buddys mkv 2010 tdi cup with mkvi electronics. changed his to 4 flashes no issues.
    Vag-Com Red Hook NY
    I lift things up & put them down
    Drty Euro / MKV Jetta parts For Sale!!!
    Quote Originally Posted by thygreyt View Post
    trannies are like girls... you cant force things into em...
    if you do, bad things happen!
  33. n00b
    May 26th, 2011
    NH
    05-28-2011 09:45 PM #68
    Quote Originally Posted by raeuber View Post
    Never mind
    2011 GTI MK6 DBPM
  34. Member toasters's Avatar
    Sep 17th, 2001
    Livermore, CA
    2011 VW Golf TDI
    05-28-2011 11:33 PM #69
    Quote Originally Posted by Wolfsburg007 View Post
    See Dana's post:
  35. Member quailallstar's Avatar
    Dec 2nd, 2001
    @LuvGermanCars
    08-02-2011 06:29 PM #70
    Grrrr I had the 4 flashes but now they mysteriously went bye bye. I can't get this to stick on my TDI Golf now for the life of me; although having successfully done this a few months back.
    Did the following:
    Adaptation from 3 to 4 or 5 (while engine on and off)
    Test and Save
    Turned off car & then pulled key and vag-com cable out
    Turned on car and still @ 3 flashes
