Selling a pair of grey Recaros out of a mkII. Bolsters are in decent shape. No back seat. IM me for pics. 300 bones.
#386
Autotech tri-y header for a MK1 $90 obo text or call 360.980.2954
#387
#388
Located in Bellingham WA
For sale
H&R/Koni cup kit with H&R race springs front and rear and front and rear Koni yellow sport adjustable shocks. Probably the best handling suspension i have used they ride great on the street and when used with a sway bar and drop spindles the car will handle even better
Fits the 1.8T applications they have been on the car for about 4,000 miles
Front Adjustment knob for the shocks is included
Roughly a little more than a 2inch drop but they have settled a bit since i first installed them
400$ plus shipping or 400 picked up
pics
pics on car right after install
#389
FS - MK1 16v header Brand new raceland $150
FS - Brand new 16v CAT CAMs 299/298's .570 lift $500
FS - MK2 16v header used supersprint $120
#390
For sale
Grey mk5 leather jetta seats. Great shape. Modified to fit in mk1. Heated too! 175$
Digi 1 setup engine harness ecu ready to wire into mk1 $100
AME old school wheels look like corvette sawblades 15x6.5 et 30 something two piece welded construction. One wheel lip is curbed and bent but otherwise the rest are perty good shape. $100 obo
14" snowflakes in silver $100 good shape little curbed not bad
G60 intercooler $50 obo
1.8t longblock bottom end is good shape head has three bent valves from an 01 passat $75 steal!
All parts are obo please call or text as i dont use IM! 509-683-2277. Dustin thanks
#391
I have a Nikon D60 for sale. It is in great condition. Comes with the everything needed to start shooting. I have all original boxes, paperwork and accessories. This camera is in nearly flawless condition. Only problem is that the flash currently does not work. I never use the flash so it hasn't been an inconvenience for me. I have priced this camera below almost anything I've seen. You are welcome to check it out and snap some pictures before buying. Asking $450 which I believe is very fair compared to some prices I've seen.
#395
1992 Passat VR6-5spd ... ~82k miles I ave been parting out this car for a little while but not touching the motor swap because Iwanted to use it for myself. its obviously obd1, dizzy, old-man owned until it got hit in the front. He bought it back, swapped the leather into his OTHER passat, and sold me the car. The interior is a mess, there are no locks, and lots of other missing pieces. but the motor swap is still there. along with the dash and original cluster, etc.
$600 for the whole thing. make some money back in scrap with the chassis, I don't care, I need it gone soon. That doesn't mean I will take less... if you message me with the words, "will you take..." the next words you type better be "...a bat to my face". Thats how firm the price is.
1988 Scirocco 16v, white, straight, bad clearcoat, complete car. cranks but wont start. bad headliner. some other little stuff. well worth $400 though. Price is firm, see above.
heres my old thread... I will update later with pics for yous guyyys
http://forums.vwvortex.com/showthrea...Scirocco-FS-1k
Grey power Recaros from a Jetta, Front and Rear. The bolsters have been swapped around so all good material and foam is on the drivers seat. not perfect but worth $250. Price policy is as noted above.
mk1 caddy Factory-option bedrails, the aluminum ones, the nearly unobtainable ones, all brackets and torx-head bolts included. $200 this one is also firm
mk1 caddy chrome gutter trim $30 not as firm
#396
'91 Land Cruiser
http://seattle.craigslist.org/est/cto/1967952520.html
part trades for mk2s considered.
#397
FS/Feeler - Time for my wife's cabby to go. 1988 convertible.
The good
Newer black cloth top
Newer headliner black, perforated material
Black mk3 gti leather front seats 9 outta 10 no tears
Momo shift knob
Momo steering wheels
TSW trophy wheels 8 outta 10 16in
Neuspeed rear sway bar
Front lower tie bar
New windshield and seal installed a few years ago
No leaks inside car
Car has full mk3 aba swap, fuse box, cluster, wiring, engine
Fully rebuilt transmission with bolt kit, mk3 tall stack Built for my wife when she was commuting.
279 webcamshaft
TT big cam chip
Bellevue Motorsports tri-y header
TT exhaust
Rear disk brake conversion, car stops amazing
Front and rear brakes 65-75+% on brakes all around
Newer clutch
Newer timing belt
Newer serp belt and v-belt for power steering
TT adjustable cam gear
Autotech plug wires
Textured smoked e-codes
New strut bearing/mounts
Raceland coilovers
I'm sure there is more but drawing a blank.
The Bad
Paint was resprayed before we got the car
Car was hit and ran and scrapped paint off rear bumper
Needs tires in the next 6 months
Needs a few things before sale that I will be putting on just need the motivation of someone willing to buy the carto make me do it haha
Water pump leaks have one ready to go on it.
Needs carpet installed, previous owner installed super cheap aftermarket kit. I have oem ready to go in.
Miscellaneous odds and ends little thing that need to be bottomed up but car is mechanically solid
$3500
#398
Dual 4x6 H4 headlights (yes H4)
These were on my MKII scirocco, but will fit a MKI jetta as well.
"Denji" brand 4x6 H4's
55/60 low beams
80/100 high beams
$100
Also this massively overbuilt relayed/fused harness for uber bright plug and play headlights!
(wired to keep all four beams on, on highbeam)
$50
#399
Motor is still in the car if you would like to come listen to it and i can take you for a drive. I built a 93 jetta with a syncro system and put this engine setup in it. Sadly i'll be parting the car out. The engine literally has no more then 5,000 original miles, i got it from an 05 GLI that was totaled a month after purchase. I got the motor and it is perfect, i'm including the Megasquirt standalone engine management which is already tuned and is a plug 'n play. It comes with a Spearco air to water intercooler and everything you will need to make it work, this literally is a bolt in package.
Also comes with Greddy Pro-fec type S electronic boost controller, Brand new kevlar Southbend clutch and lightened G60 flywheel, and BMC carbon fiber intake, Forge DVR diverter valve and other misc... mods.
Like i say will come with everything needed, from the water pump for the intercooler and the custom aluminum water tank. Runs perfect and is running Amsoil synthetic oil. With this motor my car can run 12 second quarter mile times all day, and thats only running 16 lbs of boost, and it can handle alot more then that. $3500.
If interested call me at 425 319 1297.
#400
located north of spokane wa
wheels
enkie areonaudic 14x6 tires are done
$100 or offer they look cool have All center caps
15x8 enkie 92 et0! ford pattern
$100
steelies
12 holes
$60
mk3
$20
early mk1 strut bearings asy $50
mk1 hood nice shape
$20
mk2 cabby black counsel with shift boot
$15
black 2 door rear door card $20
tail lights mk1 early 2-3 sets
$15 each set
mk1 plaid rough but useable
$50
mk2 coupe interior rough
free
mk2 recaro trophys
$150 firm pending sale
mk1 early black rear seat, $30
digi head, with need guides and seals to be installed $20 big valve
regrind cam, tt268 copy $20 used
sell them together for $30
rear disk brake swap
new mibex red box pads
new ultra 8 rotors
new wheel bearings
fairly fresh calipers
mk2 e-brake cables
$125
without pads and rotors, comes with used rotors $85
good used rear rotors $15
new front 10.1 rotors plus new brake pads paid $100 sell for $60
need something just ask, more to come
all must go we are moving
#403
CL links posted for more pics. Willing to trade for Mark 1 Rabbit steelies or Mark 1 Jetta Bumpers. PM if you're interested....
http://portland.craigslist.org/wsc/pts/1975467682.html
$100OBO
http://portland.craigslist.org/wsc/pts/1975469467.html
$50OBO
#404
Brand new mk1-mk2-mk3 steel windage tray from TT 20 bucks
Brand new in package short shift kit 20 bucks
Still has sweet TT stickers in the package!
Maybe trade for something i can use on my rabbit?
Black pleather rear seat?
#405
I have a set of 12" 2 piece rotors and Dynapro Wilwood 4 piston calipers and everything to mount it up to your VR6 mkIII or your 1.8/2.8 MKIV, might work on mkIV 2.0 but I am not sure. These DO FIT under 16" rims, I had them under beetle 16" alloys.
Comes with everything you need including SS brake lines. They are used, but in great condition. I am even willing to help you mount them up. Here is a link to Wilwoods site, it is this kit:
http://www.wilwood.com/BrakeKits/Bra...olf%20IV%20VR6
For those mkiii's out there, I had these fit up to my mkIII VR6 with not fitament issue, no cutting, no grinding, just a clean fit. for mkiii to fit behind beetle 16" I needed 5 mm spacers. I think I still have some if you want them.
Pics to come
#406
Pics available, parts located in vancouver, wa
rare rocco1 kamei hoood scoop. good condition no hardware. wont fit rabbit or rocco2 $50
all black mk2 sunvisors, no clips - $20
cabriolet mk1 quad grill w/ inner lights. no cracks or breaks -sold!
toyo observe garit studless snow tires 215/55/17. some camber/uneven wear but plenty of tread to get you through a season or 2-$140
MK3 oem clarion cd changer cable & mounting cage obo
#407
Sadly i'm parting out the Syncro car I built, I installed this system in my MK3, I wrote a complete article on how to do the swap using this system exactly, here is the link to the article I wrote....
http://forums.vwvortex.com/showthrea...yncro-to-a-MK3.
I'm including everything needed to do the swap, the complete syncro system which is already working under my MK3, I can take you for a ride in it if you would like to test the system out beforehand. It has already been modified to work, things like the passenger side Axle and Driveshaft have already been shortened so it is basically a bolt in, you just need to weld in the rear mount and tunnel mounts, which I wont be needing so I will even cut those out of my car so all you have to do is weld them in.
Syncro system comes totally complete,
Transmission
All shafts and Axles, nuts and bolts
KW variant 3 coilovers, rear brakes (and everything is basically brand new I might add)
Stainless brake lines ETC.....
Like I said i'll include everything you will need to do this swap.
All parts are in GREAT condition and have been cleaned and painted or polished and are using Amsoil synthetic fluids, in Tranny and diff's.
$4000
#408
Mk2 golf heckblende - $50 picked up (borrowed pic can take actual pic if needed)
#410
For sale:
Mercedes Benz S550 Wheels
-Front: 19x8.5 ET43
-Rear: 19x9.5 ET43
-5x112
-BRAND NEW Chrome Finish
-Matching Chrome MB center caps
-Near Flawless Condition
-No scratches/chips/rashes on face and spokes
-Tested for no bends or cracks
$950 PICKED UP
They have never been mounted after the chrome treatment, so pretty much brand new wheels.
PM Me if you are interested, thanks!
#411
Obd 2 vr6 chains and guides, brand new from TT
and a brand new sachs clutch kit for the vr6
and a rear main seal
250 for all
#412
Located in Hillsboro, OR
I have two last model versions of the Yakima highroller (http://www.yakima.com/shop/bike/top/highroller). New, these were $130 a piece (not counting locks or lock cyls). Now asking $100 total.
These were used about six times each and have sat in my garage for about two years. They both come with locks and keys (which is usually extra).
I need money for projects.
#413
Selling the Gti, someone make an offer!!
$2000 obo
link to the non-regional for sale post
Just waiting for the b5 s4 avant...
#416
$25 - Grey Corrado dash w/rebar, glovebox, knee bars...(complete minus switches/cluster/wiring)
(borrowed pic)
#417
PIAA Plasma Ion Yellow H3 fog bulbs. Pretty much brand new, barly used them.
25 picked up.
503-260-0771
#418
mk4 m3 sideskirts freshly painted baltic green, have not been mounted since painting. $100 Shipped
mk4 Jetta votex replica rear bumper, has never been on a car, or painted. Ive had this in storage since I got it and decided to go a different direction. $140
mk4 GTI OEM grill, silverstone $30
mk4 Jetta OEM center bumper grill $10
4 15" tires off my steelies, were only on for a few months. Can get exact brand/size if your interested, make offer
All prices are OBO. Seriously I'm flexible, just want to free some space in my spare parts room
Meet Crayola | Tuesday Night Beaverton GTG | IG: @mindy13vw | 8v Society #1
Previous cars: 2013 TBM Jetta TDI, 2012 CW Beetle 2.0T, 2012 CW Jetta SE, 1989 Cabriolet
#420
2006 Jetta/GLI rear bumper cover. Has some scratches and a small crease. Looks descent. Fixable. Need this out of my garage. $130 obo. Make an offer!
I also have a brand new upgraded piston diverter valve for FSI. $60
