Results 1 to 3 of 3
Thread: My XS650.
  1. Member Plan.B's Avatar
    Aug 22nd, 2002
    Renton, Wa.
    09-03-2010 05:46 PM #1
    Selling my 83 XS650. Runs, rides and stops.
    Pamco ignition upgrade. High performance ignition coil. Upgraded plug wires. Performance oil filter/cooler kit from Mikes XS. Upgraded sump oil filter. Upgraded needle bearing thrust washer for clutch. High performance clutch springs. New clutch cable. TX750 19" and 18" aluminum rims. Brand new front brake caliper. Steel braided brake line. New brake master cylinder. Clip-ons. White grips. New wheel bearings front and rear. New handlebar switches, right and left. New front fork seals. Progressive front fork springs. Front fork damper valve set. Fresh fork oil. 19" and 18" vintage Firestone tires. Gas tank has been " Kreemed ". New fuel petcock. New headlight. Installed newer rotor for charging system. Led turn signal and relay. New battery. Rebuilt carbs and re-jetted. Mikes XS steering damper.
    comes with a secound tank. It has been painted and pinstriped. It's the white, green and gold one.
    I'm asking $2,000 or trade for a car. Call or text me at 206-313-0165, my name is Jason.
  2. Member EuroTrashin's Avatar
    Jan 22nd, 2008
    Tigard, OR
    62 VW Bug
    09-07-2010 02:06 AM #2
    I want it, just can't afford it. Bump for a nice bike.
  3. 09-16-2010 12:36 AM #3
    noticed the ad was gone from the seattle craigslist. is it still for sale?
