#141
#142
#144
Anyone gotten the Coming / Leaving home lights to work on the Jettas?
New guys: READ THIS FIRST. | 8V Society: #369 | VW / Audi & BMW Indy Technician (PM for VCDS / GT1 Coding) | Help find Grant's pictures.
#145
#146
#147
#148
#149
#150
#151
#152
Anyone know if the problematic TPMS light in the 2010s can be fixed via VAGCOM?
My 5 tires are all at pressure, but my light has been blinking after ignition, then staying solid for two weeks now. I've posted in 3 different forums looking for help, and hate the though of having to see the dealer every time this happens...
Thanks for any info!
#153
#154
Yes, it can be fixed via VAGCOM...
http://forums.vwvortex.com/showthrea...1#post72131053
#155
#156
Thanks so much for the help guys - I'll report back in on the TPMS issue...
#157
#158
#159
csbabouthteheatedseatmemoryiwasonlyabletoactivatet hedriversideinmycarsowhenididittomybuddiesiassumed itwouldworkthesamebutheendeduphavingheatedseatmemo ryonbothseats
#161
Ok was trying to get it so that after some one opens the door with the key out of the ignition I can still roll the windows up. Its really annoying when I am in the middle of rolling them up and my passanger opens the door and it kills the power windows. I unchecked BYTE 4 BIT 4 where it says
power windows/sunroof disabled after door opening, but it did not work. Everything else I wanted has worked. Windows up/down with key fob. DRL option in MFI. 2011 JSW TDI.
#162
This doesn't make sense. Have you checked the MFI for any Window options? Mine is set to All under Convenience and Window Op. The choices are Off, All, and Auto. If that doesn't make a difference, do the following.
Check BYTE 4 BIT 4
Exit and Do it!
Open and close the doors and then lock with the remote.
Unlock with the remote
Fire up VCDS and uncheck BYTE 4 BIT 4
Exit and Do it!
Check to see if it now works.
I have read, and experienced, that locking and unlocking the doors after a change (before trying the feature) makes the change stick for some reason.
gap
#164
#166
#168
How do you get all 4 doors to unlock from the driver's door sensor on 2011 Jettas with KESSY?
#169
#170
#171
You don't have a rectangular screen between the speedo and tach?
Check this out.
If this link doesn't work, search for "Access settings menu" or "Episode 50".
gap
#172
DRL toggle via MFI works on my 2011 Golf TDI (US). Once it worked, with my e-brake released I can literally turn the light on and off by mashing "OK" on the right side of my steering wheel. Cent Elect info for what its worth:
Code:Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb Part No SW: 1K0 937 086 L HW: 1K0 937 086 L Component: BCM PQ35 M 104 0615 Revision: 00104 AE
#173
There is no MFI in 2011 Jettas. Well it's very basic and there is no setup menu. I am looking for long coding stuff. Anyone?
#174
#175
Ahem... http://forums.vwvortex.com/showthrea...1#post67368973
Just replace "Byte 3" in instruction 5 with "Byte 5" and you will see that screen. Follow all of the other instructions though.
OEM+ Bi-Xenon HIDs | Front & Rear Fogs | Highline CECM | Euroswitch | RNS-510 HW:08 SW:1140 w/ Software VIM | Backup Camera | 9W7 | Dash Cubby | Aspherical Mirrors | GTI Steering Wheel w/ .:R Badge | GTI 6MT Shift Knob | GTI E-Brake Boot | GTI Pedals | GTI 18" Detroits
Not so OEM+ Koni Coilovers | Gentex Homelink Mirror | Yaesu FTM-350AR
