OMG!!!!! Don't ever drive it......You need to keep the writing on the tire tread nice and clean.
Sick car man and congrats on the project. I'm about 10years behind you.
#36
When I saw carbon in the title I was thinking Turbo Diesel...I guess it's still cool.![]()
#37
#38
Know what you mean... this has ultimately been ongoing for 6 years, as I never really 'finished' even when I had the blue Mk1.
The last couple of cars I've done have always lacked 'something', so I wanted this one to be complete.
Only problem is that I do intend to drive it hard, so I'll need a second set of wheels with R-spec tyres - the 16s will be rubbish for anything but shows, and this isn't really my scene - I just like clean cars
Appreciate everyones' comments - I'm all amped up to work on it this weeked![]()
#40
A Rabbit is not to be wasted on the tentative or weak. Only the worthy are invited, and then only at your own risk. If you have even a modicum of hesitation, DO NOT buy one of these cars. Instead, leave it for a worthy soul who has already matriculated to the sublime ecstasy of what those in the know refer to as a "MK1"
OLDSKOOLVW.COM Custom MK1 parts.
#41
fukeng gorgeous sir!! def one of my fav cars!!
:HOMEGROWN MOTORSPORTS:1:4.9 VulcanWorks SuaSponte #13Dead Rabbits 1.8l20vAEB3651GonzoFerrera1000cc1552.billet3071rSE M80mmAWIC.H&R.PagParts.Snow034clutchmasters.IE.198 4JettaGLi
#42
did u buy your cae used?new? 02M I assume?? where did u buy from?
I want to put one in my car... their so nice and don't have to reach below my bolster to switch gears.
again.. your car is!!!!!!!!!!!
#45
I bought it new, direct from CAE - very nice to deal with and arrived to Australia really quickly! I actually still have an 02A/02J hybrid using an SQS 6spd gearset. My shifter is 02A, but I had to modify the linkages on the box as these are 02J spec
They're expensive, but worth the money, as the quality is top notch![]()
#46
yeah noticed they have an 02J kit but no cables... does the 02J use the stock cables? I would love to do the SQS 6 02J
#47
Yep, it doesOne of the main differences between the 02A and late model (Euro/Aussie) 02A and 02J that affects the CAE install is the cable bracket on the gearbox. The traditional 02A has the cables mounted beside eachother on the bracket, but the 02J style bracket puts the cables on top of eachother. If you try to combine this late style bracket with the 02A CAE kit, it won't select any of the gears at all. I had to track down an early 02A bracket and modify the leverage ratio on the gearbox linkage tower to get mine to work. The shift is within a 50mm sqaure, though. Tight
#49
got a partnumber for the bracket?? 50mm is def nice. right now i have a very disciplined shift everytime since my shifter knob is below my side bolster..makes 2nd and reverse very crappy and well...alot of extra motion that requires time and precision at speed ya know?
#50
First up, p/n of proper bracket is 357 711 789 B.
Here is some handy info compiled by a VWMS nut on ClubGTI covering the different shifter tower parts:
left to right, top row: OE Corrado bracket, then same with 13mm ball, then later style 02A/J bracket. Ignore one on right.
Middle row, left to right: VWM washer/needle bearing/washer then VWM brass bush which replaces OE plastic item, then washer/needle bearing/washer. These basically stop slack in the pivot. Brass bush dimensions are 33mm long, 8mm ID, 12.5mm OD, steps on ends are 9.85mm OD, thicker body is 25.75mm long, leaving smaller dia ends at about 3.63 mm each end.
Lower row is OE early 02A, with VWM shortened version below, and then later 02A/J version to the right which works with the other bracket above it.
Edit: it's the early Corrado stuff that was used on the VW Motorsport cars (ie stuff on left) - the ones on the RHS weren't used.
In other news, didn't really get anything 'photo worthy' done on the car this weekend. Spent some hours tuning in the shifter (difficult to do properly with stone cold gearbox oil, though, as you never know how positive the shift will really feel!). Still yet to get it back on the ground, but this will happen next weekend. Can't wait to get it back out into the Aussie sun![]()
#52
Ok, I'm behind schedule with updates again, but I think this is life with building a car!
I've mocked up some trim and suspension to get some shots of the car, so rest assured, the fit and finish of the final product will obviously be at another level.
Plus I'm still waiting on loads more carbon trim and engine parts from Germany - customs is being a bitch to me lately and they're never any help over the phone!! Really starting to **** me!...
But anyway... Here are some pics
#54
the pure white looks amazing in the sun
though im not really fancy on the other improvements
i do like your tail lights
I could live without them either way
great job you are doing for your rabbit
#58
#62
Probably should put these in for perspective...
Just a couple of pics of what the poor thing used to look like, prior to my several years of extensive restoration work!
Covered in rust, bird sh*t, bog, dents, and bad repair work
#65
I'm keen for some feedback on the red centres:or
? I don't mind honesty, so if you hate them, feel free to say so
It was just a random thing I thought I'd try. They were gloss black, but I felt this 'hid' them away too much...
I've also tried white centres, but with the untinted white on the rest of the car, it looked a bit too overboard
#66
I dig the red centers.![]()
My Build Thread ● Dobbin's shoot #1 ● Dobbin's shoot #2 ● Parting out salvaged BMP 2004 R32
>>>DO NOT deal with veedubtek!<<<
Understatement of the century!
#67
#69
i can only hope mine looks half as good when i'm done![]()
replica wheels are for wankers
