VWVortex.com - tail light out.. what light bulb?
    Results 1 to 10 of 10
    Thread: tail light out.. what light bulb?
    1. Member romanl's Avatar
      Apr 2nd, 2010
      Denver, CO
      '97 MB E320 --'07 VW Rabbit 2.5 --'10 VW GOLF TDI --'17 Subaru Outback 2.5i
      09-10-2010 03:11 AM #1
      i tried looking but not much luck
      left tail light on my girlfriends RABBIT *(i have MKVI GOLF TDI) went out. well just the right side of the round tail light, can someone tell me which light bulb i need? and how do i change it?
      thanks
    2. Member po7g's Avatar
      May 5th, 2006
      Merrillville
      1969 Volkswagen Karmann Ghia, 2006 VW Jetta 2.5
      09-10-2010 05:00 AM #2
      its really simple its a single filament bulb I dont know the number but if you go to your local parts store they will be able to tell you when you open the back hatch you will see a cut out in the carpet kind of behind the tail light and open that up and there will be a plug and a couple nuts, unplug the plug it is a little hard but a screw driver will do the trick then you will remove the nuts they are ethier 10mm or 13mm you will be able to see the difference and after that remove the tail light lens and you will have to remove the bulb holder from the tail light and replace both bulbs cause once one goes out the other follows. reassemble cycle key and warning light should be out.
      Boo-Ya
      Dec 13th, 2009
      06 VW GLI
      09-11-2010 04:00 PM #3
      You actually don't even need to unbolt the taillight. You just disconect the wires then push in a couple tabs and the bulb holder comes right out. Also, the brake light is gonna be a dual filament- all this information and the exact bulb number will be I the owners manual.
    4. Member
      May 10th, 2010
      North Jersey
      2016 Tiguan SE 4Motion
      09-11-2010 04:50 PM #4
      P21W (aka Sylvania 7506).
      APR Stage 1/Morimoto 5500K D3S bulbs/Hella XY 9006 bulbs... keeping the mods light on this one...
    5. Member romanl's Avatar
      Apr 2nd, 2010
      Denver, CO
      09-11-2010 06:26 PM #5
      thanks i did it last night,
      it was size 10MM wrench,
      CNDNMAX i just saw your post that i didnt have to unscrew? but being its my first time and its my girlfriends car, i didnt want to risk breaking one of the little tabs, its a tight spot to try and push them open, so i just unscrewed,
      total 5 min job,
      thanks
    6. 09-20-2010 02:57 PM #6
      I've had both my brake light bulbs go out and one has done it twice. I took it to the dealer and they said it was from corrosion. I asked them why they're corroded and they couldn't give me an answer but it isn't covered under warranty.
      Has anyone else had this problem?
    7. Member Seanele's Avatar
      Aug 24th, 2002
      SoCal
      04-12-2011 06:39 PM #7
      Quote Originally Posted by BADANTH View Post
      mine....and just about to start fixing it now..
      current: 2016GTi, 2007c230
      ex: 2003GTi24v - 2009Jetta - 2007Beetle - 2005GLi - 2003GTi - 2001Golf - 1988GTi - 1986GTi - 1982Rabbit
    8. Member CorradoG602's Avatar
      Jan 22nd, 2007
      Framingham, Ma
      '66 Impala '07 Silverado Crew Cab '09.5 G8 GT
      04-12-2011 09:04 PM #8
      Quote Originally Posted by Cndnmax View Post
      WRONG
      The other guy above is right. the nuts are 10mm. The bulbs are single filament non offset prong brake bulbs. Do both when you are in there. Its like a 95% chance as soon as you replace the one that is out the other one will go out when you put back the tail light assy back in. Just better off doing both of them.
      NEK '07 Chevy Crew Cab. Formerly CorradoG60
      '66 Impala 3 on the tree (sold)
      '09.5 G8 GT
      '74 F250 High Boy
    9. Member japoipnoi's Avatar
      Oct 31st, 2005
      Houston, TX
      08 VW Rabbit
      04-12-2011 09:24 PM #9
      Use a glove when handling bulbs.
      Touch the bulbs may cause burn out.
    10. Member
      May 10th, 2010
      North Jersey
      04-12-2011 09:32 PM #10
      Quote Originally Posted by japoipnoi View Post
      not required for an incadescent bulb
