VWVortex.com - coolant reservoir bubbling
    Page 1 of 2 12 LastLast
    Results 1 to 25 of 28
    Thread: coolant reservoir bubbling
    1. 09-12-2010 02:01 PM #1
      pulled up to a red light yesterday evening and saw some smoke near the right side of the hood. I immediately checked out the temperature gauge and it was fine. Car didn't appear to be overheating. I make it home--2 more blocks--pull into the garage, leave the engine running and pop open the hood.
      THE COOLANT IN THE RESERVOIR TANK IS BUBBLING LIKE HOT SOUP AND A NICE PUDDLE HAS ACCUMULATED NEAR MY FRONT RIGHT TIRE--NOT TO MENTION THE TRAIL OF COOLANT LEFT DOWN THE STREET AND UP MY DRIVEWAY.
      After some minor research it appears that it can be a few factors (ie, thermostat, fans????) Need some help here guys. I assumed it was a cracked reservoir (which would explain the leak) but the bubbling it the real issue.
      Thanks in advance for any input.
      R32D2
    2. Former Advertiser
      Jun 29th, 2009
      Summit, NJ
      09-12-2010 02:16 PM #2
      check if your coolant fans work first.
      The gauge in the cluster really isn't all that accurate...its made it sit in the middle until there is major overheating. So say your around 103 celcius..it will still stay in the center while you might have slight overheating.
      Bubbling is start of overheating and that is why you are overflowing coolant also.
      If you have access to vag-com you can read your coolant temp more accurately then the gauge in the cluster.
    3. Member The Sage's Avatar
      Jul 30th, 2004
      Mobile, AL
      16 LR DiscoSport 97 BMW M3 06 Land Rover LR3 06 330 Vert ZHP
      09-12-2010 08:31 PM #3
      this can also happen if you have exhaust running into you coolant.
    4. Member graeme86's Avatar
      Jun 27th, 2003
      Brisbane Qld
      2004 DBP R32; 1971 Superbug
      09-12-2010 09:30 PM #4
      It would start boiling at a lower temp too if the system was not pressurised, such as a faulty cap on coolant tank.
      PM if you are looking for: Euro Headlight switches; RHD folding Stubbies.
      OEM+ freaks click here: Graeme's Webspace - Latest Updates: TPMS; More cluster programming goodies; Fuel & Brake Line Protection; Audi Rear Wiper; Passenger Footlight Mounting Bracket.
    5. Member huichox4's Avatar
      Nov 8th, 2004
      83 Rabbit - 02/04 .:R32 Jetta wagon - 04 .:R32 - E30 325i & Alfa GTV6 Chumpcar Racecars
      09-13-2010 01:14 AM #5
      did you get your coolant flushed recently? air in the system will be super hot in there and make your car do crazy things
    6. Member vwgeorge2's Avatar
      Mar 23rd, 2008
      Cumberland Md (Ridgeley WV)
      MK4 S/C R32, MK1 Phaeton V8, MK6 TDI Jetta...Totaled
      09-13-2010 08:15 AM #6
      Quote Originally Posted by graeme86 View Post
      X2
      Make sure your system is 100% sealed with no leaks.
      http://forums.vwvortex.com/showthrea...-final-fantasy....
      Stage 7= VF, HPA= V7-ysi, A/W Intake, Dual Jet Water/Meth, UM E-85 Flex 870cc, ProMAF, 268 Cams, SS Header, SS Mid pipe, Custom intake, Brisk plugs, Lambo flapper
    7. Semi-n00b mkIIIgls's Avatar
      Sep 14th, 2010
      Greenville, SC
      96 Jetta GLS, 98 Jeep Wrangler aka "el stinko jeepo"
      09-14-2010 05:43 PM #7
      sounds like a bad head gasket.. exhaust flows in to the coolant. im havin the same problem now.. fans wont come on either gauge stays in the middle, but its def overheating.. i even pulled the thermostat
      plz lemme kno if u found the fix to ure problem
    8. Former Advertiser
      Jun 29th, 2009
      Summit, NJ
      09-14-2010 07:42 PM #8
      Quote Originally Posted by mkIIIgls View Post
      If your fans aren't coming on then check the system.
      You guys do realize that our head gaskets are metal and have a very very very low failure rate.
      Start with the basics, when your car overheats it will BOIL...thats where you are seeing the bubbles.
      If your fans aren't turning on then start diagnosing why... don't just assume its the head gasket because its bubbling
      So your fans aren't kicking on...so you pulled the thermostat???? What does the thermostat have to do with your fans kicking on?
    9. 09-14-2010 08:58 PM #9
      Quote Originally Posted by Patryk@DouglasVW View Post
      If he drives the car on the highway and it prevents the car from overheating, does that also say that the fans ARE the problem as well? I'm not sure if my logic is right....
    10. Member schmuck's Avatar
      Jun 21st, 2002
      naptown
      04 dbp r32, 04 dbp r32 ft450, 98 gti vr6
      09-14-2010 09:07 PM #10
      as well as looking at the cap to the coolant reservoir to see if it might have a faulty seal, also check the nipples on it where the coolant line comes in on the top (I believe from the throttle body?). Mine developed cracks on that nipple and it broke in a few spots forcing replacement. I don't remember much bubbling, but a little bit of steam and a big surprise to me when I wiggled the line and had a steam sprayer try to get me.
    11. Member
      Oct 28th, 2004
      Wstchstr Cnty, NY
      2012 Golf R DBM
      09-15-2010 07:50 AM #11
      Quote Originally Posted by The Sage
      sounds like a bad head gasket...
      Lets not jump to conclusions.
      Start with the simple diagnostics.
      1. Vag-Com!!!!!
      2. check fans
      3. pressure test coolant tank cap
      4. pressure test cooling system
      5. check thermostat
      6. check temp sensor
      Those simple, cheap, diagnostics will help you pinpoint the problem.
      Report back when you find the problem.
      --Chuck--
    12. Member AaronD's Avatar
      May 5th, 2002
      NJ
      '04 R32 DBP
      09-15-2010 08:36 AM #12
      had this with my old 2.8 gti and it turned out to be the thermostat. we did pressure tests, changed the cap and tank etc etc...the tstat was gunked up causing the coolant to get too hot and boil over basically. theres a blowout on the tank so itll shoot out if its too high in pressure.
    13. Member vwtechr32's Avatar
      Apr 8th, 2006
      On Track
      The one you envy
      09-15-2010 08:43 AM #13
      Quote Originally Posted by VWaddikt View Post
      Absolutely, generally your coolant system stays cool enough while at a constant roll and you do not use your fans at all.
      CHECK YOUR FANS GUYS THEY ARE A KNOWN BAD DESIGN AND FAIL OFTEN !!!
    14. 09-15-2010 09:08 AM #14
      Quote Originally Posted by vwtechr32 View Post
      That's what I thought. I had this issue recently where at a dead stop the AC would turn hot and the car would start to heat up a bit. But rolling or highway everything is fine from the car getting cooling air as I was driving.
      I replaced the front fans (about $200 bucks) and it fixed the problem. Never had coolant boiling though...
    15. Member
      Oct 28th, 2004
      Wstchstr Cnty, NY
      2012 Golf R DBM
      09-15-2010 10:42 AM #15
      ...I replaced the front fans (about $200 bucks)...
      You need top post where you sourced those fans for ~$200.
      That's a great price!
      --Chuck--
    16. 09-15-2010 10:50 AM #16
      Quote Originally Posted by speedbump2 View Post
      --Chuck--
      Let me be more specific...
      My larger fan was out, and that was about 200 bucks. The smaller one was not replaced, and I'm not sure how much the total would cost for replacing both. Does that sound more believable? lol
    17. Junior Member farooked r32's Avatar
      Feb 27th, 2010
      '97JettaVR6, '99Jetta1.8T, '01Passat4M-V6, '04 BMP R32
      09-15-2010 03:04 PM #17
      Or any type of leak or crack in the coolant system hoses...
    18. Semi-n00b mkIIIgls's Avatar
      Sep 14th, 2010
      Greenville, SC
      09-23-2011 11:53 AM #18
      I fixed this problem a long time ago, it was the fans..
      for some reason i have some kind of "glitch" whatever gives the fans signal to switch on wasnt doing so. I kno youre prollay sayin check the sensors.. that was all changed with new parts and the fans still wouldnt come on.. also my gauge would stay in the middle when the car was overheating..
      basically i ran a hotwire to the fans and hooked it up to a switch, also installed a temp gauge and said the hell with VDUB.
    19. Member DarkSideGTI's Avatar
      Aug 11th, 2001
      SL,UT
      Bagged R32T, 2015 S3, 2001 4Runner
      09-23-2011 12:04 PM #19
      I almost did the same when I couldn't get my fans figured out. If the relay ever flakes out again I will be installing a switch and basically running the fans all the time and also install a real coolant temp gauge.
    20. Member Cortexiphan's Avatar
      Mar 1st, 2010
      South East, Mi
      Golf R
      09-23-2011 12:21 PM #20
      Do our cars have a fan control module you could replace?
      I know the 2.8L GTI's do. not sure about the R
      Also how did you install the external temp gauge?
    21. Member M00NEY's Avatar
      Jul 9th, 2004
      DMV
      2012 A3
      09-23-2011 01:36 PM #21
      signatures do not show up in tapatalk
    22. 09-23-2011 10:57 PM #22
      If your lucky it was just the fans and there is no damage. I had to do fans on both my R32's.
      If you ran it more then you needed to then you may have blown a head gasket as well. Coolant bubbling is usually a drop dead sign of a blown head gasket.
      Hopefully, your lucky!
    23. Member GLI_DRIVER's Avatar
      Mar 26th, 2002
      WA.
      04 R
      09-23-2011 11:36 PM #23
      No its not. Boiling coolant inside the coolant bottle is a sign of no coolant FLOW. If the t-stat is CLOSED where do you thing the boiling coolant is going to? The bottle is the only spot in the system thats high enough for the pressure to release. The bottle is on the BLOCK side for the cooling system BTW.
      Check the fans,they are known to go bad.
      Check the t stat they are known to go bad.
      Check for coolant flow to see if the water pump is working.
      A compression leak into the cooing system is instantaneous the car would not get 10 feet before blowing a coolant leak or smoking out of the exhaust.
      Stop posting misinformation please.
      .:R
      Build your car for yourself, not what an internet forum tells you.
    24. 12-22-2011 11:04 PM #24
      For those who have experienced this first hand, did you hear squelching sounds from the engine bay when it was oveheating? Sounded like a clarinet gone wild.
      I'm experiencing all the listed symptoms right now. 2 days before Xmas, not the best time for this...
    25. Banned ThatVdub's Avatar
      May 28th, 2010
      Jax, FL
      Golf R
      12-22-2011 11:53 PM #25
      waterpump
