VWVortex.com - The tdi hpfp problem. Overstated? Understated?
    Page 1 of 5 12345 LastLast
    Results 1 to 25 of 110
    Thread: The tdi hpfp problem. Overstated? Understated?
      Mar 8th, 2000
      Scottsdale, AZ
      2013 4dr RB .:R
      09-18-2010 12:19 AM #1
      I was really considering also looking at a tdi, but really..there seem to be enough cases of catastrophic failure to the tune of an uncovered $7k repair bill. Clearly these people aren't all guilty of putting gas in their car...and assuming they filled up with commercial diesel, this shouldn't be happening.
      That said it's really put me off even considering a tdi tbh. It's a shame because from what I gather they have been historically quite reliable...my neighbor even has a mk iv jetta which iirc has over 200k miles.
      So all that said, do you think vag will eventually own up to a defective part, batch, etc and sort things for those affected? At least if they did that it would inspire some confidence that the issue is resolved. Denying the issue certainly doesn't imply to me it's been remedied. While it may affect a very low number of cars, it's an awfully expensive repair to gamble on. How many people have had this issue and it isn't reported (not enthusiasts, tech peole, etc). Seems like a big deal to me.
    2. Member Code3VW's Avatar
      May 5th, 2004
      Gilbert, AZ
      '10 CW JSW TDI 6MT
      09-18-2010 02:39 AM #2
      There are different 'grades' of diesel. As it says on the dash, you must fill up with ultra low sulfur diesel (ulsd) so not all diesel stations apply.
      That being said, keep records and you should be fine. There are a relatively low number of these issues versus the thousands of common rail diesels they've sold.
    3. Member MaxHedrm's Avatar
      Jun 28th, 2004
      Dallas, Texas, USA
      2010 Golf TDI / 2001 Audi TT Roadster (225) / 1982 Jetta Diesel
      09-18-2010 04:20 AM #3
      Quote Originally Posted by Code3VW View Post
      ULSD is for emissions reasons, not the fuel pump. Not only that, but it has been required by law for on road vehicles for some time now, so I doubt you would find LSD anywhere in the US anymore.
      DRIVE: 2010 Golf TDI - 5K129L. 5R5R. 3FE, W79, 9W2, P83, 9VE, P71.
      DRIVE (less): 2001 TT Roadster
      PARK: 1982 Jetta Diesel
      maxhedrm.montebellopark.com/blog
    4. Member
      Mar 8th, 2000
      Scottsdale, AZ
      2013 4dr RB .:R
      09-18-2010 10:20 AM #4
      So the answer is to save every gas receipt.. yikes!
    5. 09-18-2010 11:55 AM #5
      Quote Originally Posted by rockstar View Post
      The answer is to not take any BS from the dealership when you bring it in. Don't let them tell you that somebody put petrol in your car when you know damn well that you're the only one who puts fuel in it.
      "You cover this under the warranty like you should, or you even trade this one for a new one and never see me again."
    6. Junior Member CheesyRider's Avatar
      Jul 1st, 2009
      White Bear Lake, mn
      2010 Jetta SportWagen TDI 6MT
      09-18-2010 12:13 PM #6
      No, whatever you do, don't save any gas receipts.
      Apr 15th, 2009
      2010 JSW TDI, 6MT, CW, Panoroof
      09-18-2010 02:18 PM #7
      ultra low sulfur has less lubricity than low sulfar diesel so it does have some to do with the pump. its easily cured though by fueling up with B2-B5 diesel and you can also just add a quart of B100 to each fuel up to get to B2 mixture. B2 is plenty enough to increase lubricity. Also you're going to hear about the failures because thats what people do when they find forums. The failure rate isnt a true representation of whats out there. there have been posts saying that the actual failure rate is somewhere around less than 1% and those are just estimates out there.
      Apr 19th, 2007
      CT
      09-18-2010 03:07 PM #8
      One of my neighbors has a '10 JSW TDI in his garage, with around 4000 miles on it, which is inoperable due to HPFP failure. When the dealer told him it would be $7-8k to fix it because his wife was a moron who filled it with the wrong fuel, he produced fuel receipts from the Shell station 1/2 mile down the street from the dealer for every tank of ulsd ever put in the car. They basically told him he should get a nice album to keep his receipts in, but that repair would not commence until he signed an acceptance of the written estimate. He flat-bedded it home and began legal action and reports to the USDOT and NHSTA.
      Quote Originally Posted by dpg View Post
      I used to believe that but if you go to the DSG forums and look at the threads on DSG/mechatronics/clutch pack failure there are a lot, but only a small fraction of those reported to government auspices.
    9. Member Code3VW's Avatar
      May 5th, 2004
      Gilbert, AZ
      '10 CW JSW TDI 6MT
      09-18-2010 03:22 PM #9
      Quote Originally Posted by brian81 View Post
      Why, on earth, should VW pay for his "moron wife's" error?
    10. Member Code3VW's Avatar
      May 5th, 2004
      Gilbert, AZ
      '10 CW JSW TDI 6MT
      09-18-2010 03:26 PM #10
      Quote Originally Posted by MaxHedrm View Post
      Sorry, but it isn't December 1st yet.
      http://alternativefuels.about.com/od...pes/a/ulsd.htm
      http://www.clean-diesel.org/highway.html
      The pumps that have ULSD must state it on the pump. Be aware people!
    11. Member
      Apr 14th, 1999
      Northeast GA
      2012 manual TDI JSW; 1997 VW Passat sedan VR6 5-speed;
      09-18-2010 03:31 PM #11
      This is the real problem with the HPFP issue, and what gives me pause as well on purchasing a TDI - VW is making it too damn hard on people with real warranty problems. There may be some real cases of water in the fuel or refueling with gasoline instead of diesel, but most of the cases I've read about are real problems by people who have used and refueled their cars in a normal fashion. The way that VW treats most of them is reminiscent of their 1.8T coil pack response - abominable.
      2012 base manual TDI JSW
      Retired: 1997 VR6 Passat 5-speed -- 331k+ miles
      Apr 14th, 1999
      Northeast GA
      09-18-2010 03:32 PM #12
      Your reading comprehension stinks, or I'm missing your sarcasm. The dealer who said that was full of bovine excrement.
    13. Member Code3VW's Avatar
      May 5th, 2004
      Gilbert, AZ
      '10 CW JSW TDI 6MT
      09-18-2010 03:35 PM #13
      Quote Originally Posted by B4A3WhatNext View Post
      His story telling sucks.
      Did his wife fill it up with incorrect fuel?
      If he had been filling up the car with fuel from the same gas station, he should have gone after the station for redress.
      Did the pump state "Ultra Low Sulfur Diesel?"
      I find it hard to believe that the dealership called his wife a moron...
    14. Member RogueTDI's Avatar
      Dec 12th, 2002
      USA
      2010 Golf TDI 4DR MT6 SB 1989 AW11 MR2 4AGE 150whp 2250lbs
      09-18-2010 05:49 PM #14
      1) I'd like to know what legal grounds VW has for trying to stick owners with a 1/3 the new vehicle cost in repair bills on a brand new vehicle. I would assume that Magnuson Moss would require VW to prove that gasoline was run through the fuel system, to deny the owner warranty coverage.
      2) This is a subsystem absolutely critical to the engine, and on that alone I should think it preposterous to deny coverage, especially given the repair bills.
      3) If this is a frequent occurrence (which I dont believe - it's probably far less than 1% of TDIs), and VW had clout in their refusal to honor the warranty, I would think a class action law suit would already be in existence.
      In the rare instance you do end up with a failed pump, you are a fool to just pony up $5000+ for repairs on a brand new car. Go to small claims, do what is necessary, but dont let VW get away with this.
      Additionally, no diesel fuel will cause lubricity failures. ULSD should and I believe does already have lubricity improvers in it, and anything with higher sulfur wont hurt the pump, just emissions equipment. Only gasoline could cause the problem.
    15. Member silverA4quattro's Avatar
      Jun 22nd, 2004
      Conshohocken, PA
      2016 RS GTI autobahn PP/LP/DCC 6MT, 2013 Tiguan SEL 4Mo
      09-18-2010 06:28 PM #15
      I understood him perfectly.
    16. Member
      Mar 10th, 2009
      2006 Passat 2.0t 6mt
      09-18-2010 08:02 PM #16
      If one actually drove the new diesel engine on gas. The HPFP will be least of your concern. The engine detonating is a bigger concern.
      The need TDI has not had all the bugs fixed yet.
    17. Member
      Apr 19th, 2006
      2010 Golf TDI
      09-18-2010 08:38 PM #17
      Quote Originally Posted by Boosted2003! View Post
      lolwut?
      2010 Golf TDI 4 Door Shark Blue. DSG, Sunroof, Dynaudio, Nav, Rear airbags
      Quote Originally Posted by Outie5000 View Post
      And lets be honest, owning a diesel car is nifty.
    18. Member MaxHedrm's Avatar
      Jun 28th, 2004
      Dallas, Texas, USA
      09-18-2010 09:03 PM #18
      As I said, using ULSD as directed by VW should have zero impact on pump performance. And since the pump was (or at least should have been) designed for the lower lubricity of ULSD compared to LSD, LSD should not hurt the pump. What it will hurt is the emissions system.
      True, but looking at the second link, there hasn't been any LSD allowed to be imported/produced for highway use since June and it is mandated to be 100% at the terminals by Oct 1. I think you would have to look pretty hard to find LSD anywhere, since 80% of the diesel produced/imported has been ULSD since June 2006.
      Not only that, but ULSD is for emissions. LSD should have no impact on the fuel pump.
    19. Member G60ING's Avatar
      Jun 27th, 2000
      Panhandle FL
      09-18-2010 11:08 PM #19
      Car payments suck and repair payments to the dealer are even worse. I won't put myself in a position of doing both. Just say no to new TDIs until VW/audi figures this out.
    20. Member
      Mar 8th, 2000
      Scottsdale, AZ
      2013 4dr RB .:R
      09-19-2010 02:31 AM #20
      Quote Originally Posted by CheesyRider View Post
      LOL, you know what I meant.. Fuel!
      Quote Originally Posted by G60ING View Post
      That's basically my thought. Even at
    21. Member
      Mar 10th, 2009
      09-19-2010 03:06 AM #21
      Quote Originally Posted by dhambrick View Post
      lolwut?
      Gasoline will have a good possibility of making a diesel motor detonate causing major internal issues.
      TDI motors have bugs like the FSI engine did. They weren't worked out before production. Only thing is they cost a lot more to fix.
    22. Member toasters's Avatar
      Sep 17th, 2001
      Livermore, CA
      2016 VW e-Golf SE DCFC
      09-19-2010 04:22 AM #22
      I was actually considering starting a thread like this today...glad I found this one.
      I was at the dealer today talking to the service manager about this issue and what I can do to protect myself from it.
      He said that in the past 2 years, they've had 2 cases of HPFP failure...this dealer sells around 20-30 TDI's per month.
      1st case: 2009 Jetta TDI. Had to fight with VW to get it covered under warranty.
      2nd case: 2009 Jetta TDI. VW authorized full fuel system replacement...no questions asked.
      Find a dealer that is willing to fight for you....one that will be on your side if HPFP failure occurs. I feel semi-confident that my dealer is on my side. This makes me slightly more comfortable with my 2011 TDI purchase.
      Has anyone on this forum even had HPFP failure?
    23. Junior Member XaqNautilus's Avatar
      Aug 23rd, 2010
      Alberta
      1998 Acura 1.6 EL
      09-19-2010 04:37 AM #23
      A fellow over on tdiclub has a list of about 30 hpfp failures from their forum members.
      Currently just a GTI/R wannabe.
    24. Senior Member feels_road's Avatar
      Jan 27th, 2005
      East Bay Area
      2016 MkVII e-Golf, 2010 MkVI MT TDI Golf, 2000 B5 4M Passat Wagon
      09-19-2010 08:11 AM #24
      I am not worried.
      1. There seem to be very, very few cases. AFAIK, none have been reported here. Many dealers/service places have never heard about this/ have never seen a case. There are 600 dealers in the US, and about 80,000 CR TDIs have been sold, so far. Say, there were 400 cases (I doubt it) - that would make 0.5%. Compare that to your chance of a Honda V6 transmission failing a few years ago (about 50+%), or your Subaru head gasket blowing at or before 100,000 miles (close to 100%, a few years ago).
      2. Most cases were reported early on - when fuel was still transitioning and may have been bad in some locations. There are very few - if any - recent cases.
      3. The idea that VW would just not cover this or that someone would have to personally pay for this is just ridiculous and IMO typical anti-VW fear-mongering. Of course it can happen if you have huge amount of water or gasoline in the fuel - but if that was not your fault, your insurance will cover it. And they will go after the fueling station.
      People need to gain some perspective, here.
    25. Member Pelican18TQA4's Avatar
      Dec 13th, 2000
      Philadelphia, PA
      2013 Jetta Hybrid SEL Premium | 2010 GTI 6MT | 2002 Golf GL TDI 5MT | Audi R10 ;-)
      09-19-2010 11:35 AM #25
      This problem is way overstated because of the potential costs associated with HPFP failure. Basically, the entire fuel system needs to be replaced because a destroyed HPFP will leave metal shards everywhere in the fuel system, including the injectors. That being said, VW has sold well over 60,000 TDIs since it was re-introduced in late '08 for the '09 model year and there have been literally a small handful of reported problems and out of those reported problems, not all of them have been attributed to actual failure of the HPFP due to mechanical and/or manufacturing defect. In addition, if you mosey on over to tdiclub.com, you'll find out that (to the best of my knowledge) no one has had to pay out of pocket for the associated repairs. I think there is one case where the owner had the insurance company pay, but I believe they are in the process of VW reimbursing them or something similar. The point being, again, this problem has been grossly overstated because of the potential financial impact of failure. Finally, if VW says that bad fuel caused the failure, the burden of proof is on VW, not the owner. VW has to prove that bad fuel caused the failure in order to deny warranty repair. And no need to get a $$$ lawyer involved, just educate yourself about the law if you find yourself in this type of situation and respond to the dealer's allegations accordingly.
