VWVortex.com - po722 speed sensor & po730 gear ratio ?? after i pressure washed my engine,
    Results 1 to 2 of 2
    Thread: po722 speed sensor & po730 gear ratio ?? after i pressure washed my engine,
    1. n00b maya2.0's Avatar
      Sep 18th, 2010
      Boston
      2013 CC Lux
      09-18-2010 06:01 PM #1
      what is the quick fix or the sulution to my problem? i pressure washed my 02 jetta wagon engine yesterday and when i went to drive away the tranny would not shift right, if i kick the throttle after 30 mph it shifts... now today i let the car run for a while with the hope that some thing will dry off and all set , not the case. I have no clue where or what the speed sensor looks like or is located? any pic's? and solutions please???
    2. 09-27-2010 06:16 PM #2
      The sensor is located next to the transmission oil cooler. If you pop the hood you will see it right under the battery tray. easy replacement.
