did you pull up on the little knobs on the top of the left and right sides of the seat? if you broke those then im not sure what to tell you
#1
i tried to pull the tabs and one of them snaped off. how can i unlatch the back seat from its hooks?
#2
THE CBOX KREW
There's always time for a GI Joe orgy
#4
You're ****ed. Pull up on the one and have your friend kick the back as hard as they can. That is my only suggestion.
#5
once you get it down, it and the trunk make the perfect bed
THE CBOX KREW
#6
#7
Don't know what to tell ya buddy. Good luck! At least your car runs, right?
#8
#10
#11
Did you lock the seatback locks?
If you did, that would explain why the seatback would not release when you pulled on the knobs.
The cover for the seatback is held in place by a single long zipper. The zipper is removed at the end of the assembly process. You can pull the zipper apart, to gain access to the seatback release mechanism (make sure you unlock the seatback locks this time), but I don't know how your going to zipper the seatback cover back on when you're done.
#12
#13
and i found a way to open it. i stuck a metal wire coat hanger like a hook and pull up the locks. now they fold again
