Page 1 of 49 1 2 3 4 5 11 ... LastLast
Results 1 to 35 of 1701
Thread: Whats wrong with your VW today?
  1. Member Guitarman355's Avatar
    Apr 3rd, 2009
    Gboro, NC
    2003 Silverstone Slushbox
    09-29-2010 11:44 AM #1
    So mine has been in the shop for almost a week and a half.
    Behold:
    Both door latches
    Broken Lock Cylinder (keyless and the radio didnt turn off when the car did)
    Fan control module
    Tiptronic Switches
    Timing belt, water pump, tensioner etc etc replaced
    Serpentine belt
    cv boot
    cam adjuster and valve cover gaskets need to be replaced
    power steering leak
    Rear axle beam is bent, so i need a new one of those and the sub axels and wheel hubs and yadda yadda for that
    Warranty only covered the fan control, door latches and the tiptronic switch.
    Timing belt and all that is replaced, the only thing that isnt done is the gaskets, and rear axel beam. its gonna be expensive enough.
    But hey, I love my vw. lol
  2. Member alexandriak's Avatar
    Jul 27th, 2010
    York,PA
    Jetta 2.0, RIP GTI 1.8t
    09-29-2010 11:48 AM #2
    my traction control light is on and won't go off. it's something with a steering sensor or something. can't remember what exactly but that's it for now thank god
    female driven
    (_fishbowl society_)™
    IlleststanceGangBang2011
    Quote Originally Posted by static.20v View Post
    i just put "kidnap alexandriak" in my planner for the spring season
  3. Junior Member ggarza75's Avatar
    May 9th, 2009
    Grand Prairie, TX
    2002 Jetta 1.8T
    09-29-2010 11:53 AM #3
    Just a few minor things:
    1) Trunk wont open because a small plastic piece that the motor pushes on is broken.
    2) Passenger door wont open. Will need to take apart panels to connect whatever is loose.
    3) Driver side window control, one button broke
    4) Arm rest hinges broke, so whole thing just pops off.
    5) Glove compartment hinge is also broke, supported by only one.
    Just replaced #3 ignition coil. Now runs like a champ.
  4. Member Guitarman355's Avatar
    Apr 3rd, 2009
    Gboro, NC
    09-29-2010 11:55 AM #4
    Quote Originally Posted by ggarza75 View Post
    The best soloution for random misfires, is buy some bolt down hitachi coils from ecstuning, and some new sparkplugs and you will be golden. I love the feeling of new spark+coils.
  5. Member x_GTI_x's Avatar
    Apr 23rd, 2008
    MA
    BMP 20th - 1990 Cabriolet.
    09-29-2010 11:56 AM #5
    Mine isnt low enough.
  6. 09-29-2010 11:57 AM #6
    *Won't reverse
    *Doesn't make power in 5th
    *Head liner starting to come off
    *Steering wheel column vibrates and squeaks
    *No radio reception
    *Only getting 21 mpg
    *Doors don't always like to lock
    ...there's more, i'm just getting depressed so i'll stop.
    2012 Passat
    2003 VW 1.8T GTi: 3" DP, 2.5" CB, N75J, OEM AirBox, Drop-in High Flow, EIP Dogbone, Forge TIP, Vented Fender liner, Forge 008, Metal H2O Impeller.
    Quote Originally Posted by Strikelin View Post
    ...You get about the same performance gains from a good dump before driving due to the weight loss then you do from a CAI...
  7. Member Mr.Tan's Avatar
    Jun 9th, 2004
    York, PA
    '01 GTI, '13 Wrangler Sahara Unlimited
    09-29-2010 11:58 AM #7
    both front tires wont hold any air, don't know if anything else is wrong haven't driven it for a few weeks
  8. Member AThom92's Avatar
    Aug 8th, 2009
    Norwell, MA
    2002 VW Jetta 1.8T
    09-29-2010 11:58 AM #8
    1) Check engine light is on for "cooling system performance"
    2) Im rubbing sway bar
    3) i have some sort of electrical shortage making my passenger side tail light and blinker not turn on.
    4) its dirty
    5) its naht low enough!
    i could go on for hours.....
    Jan 13th, 2010
    Wake Forest NC
    2002 Jetta 1.8t
    09-29-2010 12:02 PM #9
    This thread has mad potential.
    Intermittent coolant light on cold startups
    sagging headliner
    chipped paint on the rear bumper
    not low enough
    not on "baller wheels"
    front plate holes need to be filled
    front grill blacked out (looking for a cheep stock replacement)
    Im sure theres more but I cant think of them right now.
    Quote Originally Posted by swirv View Post
    What is Vag com it? Some sort of website?
  10. Junior Member ggarza75's Avatar
    May 9th, 2009
    Grand Prairie, TX
    2002 Jetta 1.8T
    09-29-2010 12:02 PM #10
    Also need to add,
    1) Leak in rear passenger tire.
    2) Someone stole my two small front grills. BASTARDS!
  11. Member
    Sep 5th, 2010
    marietta, ga
    bagged mkiv
    09-29-2010 12:20 PM #11
    my jetta has been in the collision shop for 3 days already.....
    new:
    rear valence
    bumper
    exhaust system
    unibody fixed
    trunk
    driver side rear panel
    new rear suspension(struts, 4 wheel alignment, maybe more damage)
    also getting 2 dents fixed(not crash related)
  12. Member swagger rob's Avatar
    Aug 13th, 2009
    Virginia Beach, VA
    2000 Jetta VRT / 2003 Jeep Liberty
    09-29-2010 12:29 PM #12
    **** it, i'll give in...I've seen a thread like this before though...
    1. My intercooler is ghetto rigged until I get a new hardpipe made, looks super sketchy.
    2. First time in 3 years I have gone 50 miles with no CEL
    3. FSB bushings need lunrication
    4. No intake on SAI breather
    5. fuel pressure is at 36 psi and I have no idea why
    6. interior is in shambles, headliner approaching head.
    7. car is dirty, interior is dirty.
    8. dents all over
    9. interior trunk unlock/gas door popper does not work
    10. interior smells like mold from water intrusion
    that's my top ten for today
  13. Member Raybandar's Avatar
    Jul 22nd, 2010
    Leesburg,Va
    01 jetta 1.8t
    09-29-2010 12:29 PM #13
    I just fill up my gas tank and the gas light still on
  14. Banned jettaaddiction's Avatar
    Jun 22nd, 2008
    Royal Joke, MI
    2003 2.low jetta soon to be on Mercedes' Jawns
    09-29-2010 12:33 PM #14
    Shes perfect. I love her!!
  15. Member GliGirlDriver's Avatar
    Dec 15th, 2009
    NH
    2003 GLI VR6
    09-29-2010 12:36 PM #15
    Quote Originally Posted by x_GTI_x View Post
    x2
    ..but I will fix that
    faceoff
    Quote Originally Posted by the mad conductor View Post
    So my new girlfriend doesn't give Dome?
    Quote Originally Posted by 1.8Tquattro View Post
    You spelled ex-girlfriend wrong.
  16. Member alexandriak's Avatar
    Jul 27th, 2010
    York,PA
    09-29-2010 12:39 PM #16
    Quote Originally Posted by AThom92 View Post
    had this problem. got a new thermostat and problem was solved
    female driven
  17. Member
    Mar 11th, 2010
    nj
    12v gti, bt 20v gti
    09-29-2010 12:40 PM #17
    door card inserts are sagging
    plate holes in rubstrip
  18. Member jasonex's Avatar
    Jul 19th, 2009
    Hillside, NJ
    1999.5 2.0 GTi
    09-29-2010 12:55 PM #18
    hatch Wont lock, and its an 8V
  19. Member
    Aug 11th, 2008
    Vancouver, Not Canada
    mk4 Hoopty, e39 540i
    09-29-2010 12:59 PM #19
    Quote Originally Posted by swagger rob View Post
    8. dents all over
    I like how 50 miles of no CEL is a problem
  20. Member NTUNED's Avatar
    Sep 21st, 2010
    DFW & Houston
    04 BMP GLI, 81 Caddy, 89 Helios GLI (Sold)
    09-29-2010 12:59 PM #20
    My door speakers don't sound (previous owner made a mess with speaker cables)
    blinker light won't turn on, only blink for turns and when hazards are on
    it's dirty
    one seat is making sound when driving, I'm sure its the spring that I suddenly found, not sure
  21. Member RohclemGTI's Avatar
    Dec 4th, 2009
    San Juan,TX.
    2011 UG GTI base
    09-29-2010 01:02 PM #21
    cv boot needs to be replaced
    both front wheels bent on the inner side driver side leaks air
    sagging headliner
    20th ae rep lip kit(front lip is cracked)
    driver side window regulator is gone as well as window switches and switch cover broken(i have all parts ready to be replaced this weekend school gets in the way)
    needs an alignment
    needs some maintnance
  22. Member GliGirlDriver's Avatar
    Dec 15th, 2009
    NH
    2003 GLI VR6
    09-29-2010 01:02 PM #22
    Quote Originally Posted by guitarer1229 View Post
    I've got 67k on my GTI..and have NEVER had the CEL come on
    ...(knocks on wood desk at work)
    faceoff
  23. Member alexandriak's Avatar
    Jul 27th, 2010
    York,PA
    09-29-2010 01:03 PM #23
    Quote Originally Posted by GTIGirlDriver View Post
    bet it comes on within the next 200 miles
    female driven
  24. Member Tofik's Avatar
    May 6th, 2007
    908 - Jersey
    Bagged Galactic Blue Wolfsburg
    09-29-2010 01:04 PM #24
    .. only thing that was wrong with mine untill 2-3 days ago was the cel for missing o2 sensors because i ripped one off on a speed bump =P but all is good now no cel no nothing =P
    |Build Thread| Awesome New Picture Thread| AccuAir | Air Zenith | Airlift | Bag Riders |
  25. Member GliGirlDriver's Avatar
    Dec 15th, 2009
    NH
    2003 GLI VR6
    09-29-2010 01:06 PM #25
    Quote Originally Posted by alexandriak View Post
    ^^i bet you're right. I'll let you know lol
    faceoff
  26. Member limastock's Avatar
    Feb 17th, 2009
    the city
    1976 Rabbit
    09-29-2010 01:06 PM #26
    Just saw today someone left a nickle sized scuff/chip in my front bumper
    2001 Jetta 2.0 - Sold
    2003 GTI 24v VR6 - Destroyed
    1996 GTI VR6 - Sold
    1976 Rabbit - Driving
  27. Member alexandriak's Avatar
    Jul 27th, 2010
    York,PA
    09-29-2010 01:07 PM #27
    haha sounds good. it'll suck if it does but thats the way it goes
    female driven
  28. Member Mafiamike954's Avatar
    Mar 3rd, 2009
    Plantation FL
    2004/vw/Jetta GLI 1.8T
    09-29-2010 01:12 PM #28
    2004 VW Jetta GLI 1.8T
    My OEM exhaust hanger broke on my custom exhaust and i had to fix it myself,,, TODAY
    In general..!
    Air bag light has been on for a year,,,,CRAP!!
    Head liner is coming down....stapled it back..
    Need to rotate the tires...
    The door cards are coming apart..
    Sunroof slide needs to be replaced
    ...clips got mangled up...
    Glove box latch is broken..
    lot of minor things
  29. Member mushy's Avatar
    Sep 15th, 2008
    Banana Republic, getting jiggy with it
    '00 jetta
    09-29-2010 01:31 PM #29
    rubbing swaybar
    liner for the sunroof headliner panel unglueing itself
    sunroof motor cover saging (someone previously broke the taps tha hold it in place)
    front passenger door won't unlock unless you tap the door
    exhuast hits the rear axle when the A/C is on while stopped (annoying tatatatata.... sound)
    ocassionaly doesn't want to get into gear
    armrest hinge broke, fixed it by screwing in small metal hinges
    But I won't trade her for the world
  30. Member Incubusions's Avatar
    May 22nd, 2006
    Bondsville, MA
    MKIV Jetta 1.8t......... Revo'd & low on Ksports
    09-29-2010 01:38 PM #30
    Thankfully mostly cosmetic (amazing for having 113k)
    No CEL
    recently dropped and need another alignment, pulls to the right
    Key fobs dont unlock doors
    both front fogs bulbs are fried
    drivers side rubs need to be replaced
    plate holes in front rub so I cant cleanly pull off a front plate delete
    one wheel needs repainting
    a few spots of dried up compund on the inside trim of headlights (from recent diy refinish job)
  31. Junior Member
    Sep 29th, 2010
    Easton, MD
    2004.5 BL GLI
    09-29-2010 01:53 PM #31
    drivers side rubstrip's paint is chipped to hell
    brand new dent on top of the trunk thanks to an acorn tree
    stitching on the drivers recaro is ripping
    seatbelt light wont go off when i have my seatbelt on
    theres also a giant screw in the left rear tire
    i could go on...
  32. 09-29-2010 01:59 PM #32
    hail damage.
    2 big 2 in chips in the front rubstrips.
    traction control light wont go off.
    abs light is on.
    brake light is flashing but works fine.
    brake pads light is on.
    airbag light is on.
    in this past month i blew at least 6 coil packs. and last night i blew another 2 more.
    need alignment.
    need new wheel bearings.
    ticking noise in engine. thinking its the timing chain.
  33. Member Vettes, Volvos and VWs's Avatar
    Mar 5th, 2006
    Sudbury, ON
    76 Corvette, 94 960, 01 Passat Wagon, 02 Jetta 1.8T, 07 A6 S-line
    09-29-2010 02:44 PM #33
    It's a VW!
    -Reverse lights don't work
    -Burnt taillight
    -Sometimes my car does'nt register the driver's door is open
    -Not low!!!!
  34. Member JTorpedo's Avatar
    Sep 8th, 2010
    Canada
    2.0L Jetta GLS
    09-29-2010 02:46 PM #34
    Owned for 4 weeks, here's my list:
    PO's spraypaint touch up spots along passenger side and roof
    No cupholder
    Needs new brake pads/rotors
    Remote key needs new batteries or reprogrammed
    Cracked windshield
    It's a 2.0
    ...But I still love it
    8v Society #240
    Quote Originally Posted by vdubfrodo09 View Post
    Every time you post a child in Alaska gets eaten by a walrus
  35. Member Guitarman355's Avatar
    Apr 3rd, 2009
    Gboro, NC
    09-29-2010 10:12 PM #35
    Quote Originally Posted by Incubusions View Post
    No CEL
    a few spots of dried up compound on the inside trim of headlights (from recent diy refinish job)
    I hate to ask the obvious, but do your fobs have new/good batts in them?
    And if they do (and this was my case) then it might be your ignition cylinder. Mine had some cable not aligned or something and it wouldn't go back to full lock when you turn the car off. So my key less didn't work and my radio wouldn't turn off and neither would my clock and odo.
