Page 4 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 106 to 140 of 163
Thread: build thread: 16v + cbr900 carbs + high compression
  1. Member yeayeayea's Avatar
    May 29th, 2005
    md
    89 GTI 16v with carbs, 99 528i, 95 gsx600
    03-09-2012 08:40 AM #106
    Yesterday. Drove it around the block the day before actually. The white oil pressure sender is leaking oil out the top, a new one should be here today. Other than that, and being low on oil for said reason, it seems to have weathered winter unharmed.
    Feel free to follow me on instagram @wesmurphy for pictures of bikes, bimmers, vws, etc
    my "build" thread: 16v+carbs FOR SALE!!!
    My gti is for sale, check it out! http://forums.vwvortex.com/showthrea...7#post79821897
  2. Member yeayeayea's Avatar
    May 29th, 2005
    md
    03-13-2012 10:50 PM #107
    So I pulled the plugs because the car was still misfiring after a couple days of driving it. I found the #4 spark plug had a chunk of the porcelain missing. This was an old plug I threw in there a few months ago after breaking the porcelain on the previous spark plug.
    Two plugs, both with broken porcelain, both #4 cylinder. Any ideas? Im thinking it may be carb related, maybe a lean run situation that is making the plug extra hot, but I am pretty much clueless right now.
  3. Member mudanddust's Avatar
    Oct 23rd, 2007
    State College PA
    89 2.0 golf (for sale), 84 carbed 16v gti, 99 tdi golf
    03-13-2012 11:20 PM #108
    can you post up good pics of the broken plugs and the plugs from the other three cylinders? also how many miles are on the motor, good and even compression?
  4. Member Jones84's Avatar
    Sep 5th, 2007
    Gresham Oregon
    84 GTI 2.0 High comp 16vT on MegaSquirt, 00 Subaru Outback
    03-14-2012 02:03 PM #109
    I dont think its a carb thing. I have had the same thing happen in my low comp ABA 16v turbo. It was #4 as well.
    84 Rabbit GTI, 12.1.1 comp 16VT, 15psi 307whp 278wtq Winner 2012 bugRun Pro class
    JONES PERFORMANCE VW, Swaps, Custom Builds, MS install & tuning. MK1, MK2, Specialists
    2vwjones@gmail.com Website under construction.
  5. Member yeayeayea's Avatar
    May 29th, 2005
    md
    03-14-2012 07:41 PM #110
    I can post pics of the broken plugs. I cleaned the other plugs with the wire wheel on my bench grinder so looking at them wont help much. The car ran awesome before the first plug broke, I spent a whole day drag racing at Bug Out (made it to the semi finals, like 8 or 9 passes ) The plug broke that time on the ride home from bug out actually, while on the highway. When I got home, I swapped in an old plug, which has now failed. I posted on NGK's facebook, and they recommended a plug for me, problem is I have not found it locally yet.
  6. Member lilredcabby's Avatar
    Mar 28th, 2010
    CT
    mk1 cabriolet
    03-23-2012 12:32 AM #111
    hey ma ur inbox is full and wont let me send any messages to you...clear up some space i have another question haha thanks.
  7. Member yeayeayea's Avatar
    May 29th, 2005
    md
    03-23-2012 05:59 AM #112
  8. Member mudanddust's Avatar
    Oct 23rd, 2007
    State College PA
    03-24-2012 09:57 PM #113
    finally got my new motor in the wabbit today, hopefully get it buttoned up and try to fire it tomorrow
    May 17th, 2009
    Mexico City, Mexico
    2001 vw pointer - r1 bike carbs
    05-18-2012 10:24 PM #114
    yeayeayea, I read the entire post but i didn't find how big you drilled the main jets for you cbr900 carbs... I read in this same post a drill bit sized at .178 but ... sounds to big to be correct...? Help?
  10. Member yeayeayea's Avatar
    May 29th, 2005
    md
    05-18-2012 10:42 PM #115
    I believe it was 1.73mm, not .173 inches. .173 inches would be much too big.
    At least that is what I wrote in the info for this video back when I was piecing it all together
  11. Member
    May 17th, 2009
    Mexico City, Mexico
    05-22-2012 12:37 AM #116
    I thought it might have been a bit much at .173, so 1.7... nice, thanks for the info!
  12. Member rysskii3's Avatar
    Apr 18th, 2006
    SoCal
    MKII Race Car
    05-22-2012 12:42 AM #117
    What is done to the engine to run 173?
    OIF 06-07: Hospital Corpsman FMF. Al Habbaniyah, Al-Anbar Province, Iraq.
    Mk2 16v parts for sale.
    Mk2 Golf_GL 16v @ Streets of Willow Raceway.
    Project Гольф Мк2 (Carbed)
  13. Member yeayeayea's Avatar
    May 29th, 2005
    md
    05-22-2012 07:18 AM #118
    Quote Originally Posted by rysskii3 View Post
    1.8 16v, decked head, 3angle valve job, autotech cams, eurosport cat delete header, tt exhaust, no cat.
  14. Member rysskii3's Avatar
    Apr 18th, 2006
    SoCal
    MKII Race Car
    05-22-2012 10:03 AM #119
    Quote Originally Posted by yeayeayea View Post
    Hmm, I got very similar mods, with a few more little things, but I'm on 91 octane. I don't know of I should install the 170 or 175. And I got 2l
  15. Member yeayeayea's Avatar
    May 29th, 2005
    md
    05-22-2012 04:38 PM #120
    I run 93 octane in mine. You also have R1 carbs where I have cbr900 carbs. I think yours are 40mm versus mine being 38mm. That said I would shoot for the 175's.
    The mains were the only thing I changed on my carbs, I left all the other jets alone. I did play with needle heights to dial it in some.
  16. Member rysskii3's Avatar
    Apr 18th, 2006
    SoCal
    MKII Race Car
    05-22-2012 04:42 PM #121
    hmm, maybe i should get some 180 and 185. i do have mild p&p and TT 4 to 1 catless header.
  17. Member
    May 17th, 2010
    Portland, OR
    '91 Jetta 16V on R1 Carbs
    06-10-2012 11:07 PM #122
    So how is it daily driving this?? Your dyno showed your HP and torq were slightly under stock until 5k rpm. I'm putting together an R1 carb setup but I'm afraid intown driving will suck, right?
    I have a 9a with ported head and an exhaust. I'd like to see if I can hit vr6 150 whp with some cams and maybe a header. Shouldn't be impossible.
    Need a 16V manifold flange to build your custom carb intake mani!?! I can get you one laser-cut for $85 shipped!!! PM me!
  18. Member yeayeayea's Avatar
    May 29th, 2005
    md
    06-10-2012 11:19 PM #123
    Well I broke my ankle back on may 6th, so the car hasn't moved since. But I daily drove it for a couple years. No problems, no air filters, all year round.
  19. Geriatric Member steveo27's Avatar
    Aug 1st, 2005
    :faceplam: :beer: :thumbup:
    buncha junk
    06-10-2012 11:29 PM #124
    Hope ya feel better chief. And hope to see ya around
    Crooked Euros | Low is NOT a lifestyle | Slow & Quiet
    WTB - 04.5 GLI REAR VALANCE
    Pennsylvania Volkswagen Owners & Enthusiasts Page
    O/R/T
    We Do It Big In PA
  20. Member
    May 17th, 2010
    Portland, OR
    06-10-2012 11:33 PM #125
    Sounds reliable. Ever left you stranded? I'd like to DD mine to work/school when I finish it.
  21. Member yeayeayea's Avatar
    May 29th, 2005
    md
    06-10-2012 11:42 PM #126
    Quote Originally Posted by steveo27 View Post
    Long time no see steve, still got the 12v?
    Quote Originally Posted by bmwquick View Post
    The only carb related problem I have had was a broken throttle cable that was made from a bicycle brake cable. The new cable I have has been problem free.
    Other than that, I have had two spark plugs, both on cyl4 break the porcelain. Also have had two oil pressure senders fail, the second one being a used one I got from a friend though. Only other problem was a radiator clog, the little vent line on the top of the rad was clogged, causing the radiator to get filled with steam vapor and overheat the car. Pretty tame for a 23 year old car that gets driven hard every time it is running.
  22. Member
    May 17th, 2010
    Portland, OR
    06-10-2012 11:56 PM #127
    so slightly more reliable than mine. You said you may be able to hit 150 whp with some finer tuning, do you think that's possible? I would be very happy if I could get mine in the 145-150 zone without going for crazy cams..
  23. Member yeayeayea's Avatar
    May 29th, 2005
    md
    06-11-2012 12:04 AM #128
    Im sure its possible. I literally have only played with needle heights for tuning. no syncing, no idle jet adjustments. But it runs well enough that I dont care to bother with it.
  24. Member OrangeDUB's Avatar
    Sep 18th, 2006
    City of 5 Smells, IA
    VAG in my pocket
    06-14-2012 03:35 PM #129
    What throttle cable did you end up using? Last time I asked I think your reply was a bicycle cable, but I see that didn't last.
  25. Member yeayeayea's Avatar
    May 29th, 2005
    md
    06-15-2012 11:41 PM #130
    So its time to make a new throttle cable, since my bicycle brake cable finally died.
    I am using a honda hood release cable, as it has the right size barrel end for the cbr900 carbs
    It has a barrel on one end and a ball on the other, i cut the ball off
    next I cut the J hook off the stock cable, and drilled out the cable that was left crimped inside it
    Here is what ends I will have once I determine my length
    hopefully tomorrow I will cut it to the right length and crimp and solder the j hook on and have a nice new throttle cable with no cable clamps anywhere
    I think it came out of an early 90's honda accord.
  26. Member OrangeDUB's Avatar
    Sep 18th, 2006
    VAG in my pocket
    06-19-2012 09:16 PM #131
    Thanks for the info. So did you get the Accord's steel cable to take the solder in? I can solder better than most and couldn't for the life of me get the OEM cable to take the solder, even with more than enough intense heat and plenty of flux.
  27. Member yeayeayea's Avatar
    May 29th, 2005
    md
    06-19-2012 09:22 PM #132
    cant say for sure, but I think it flowed in ok, at least into the hook. I crimped it first, so it may be the crimp doing all the work.
  28. 08-10-2012 09:46 PM #133
    with line is the main fuel line the top hose or the bottom
  29. Member OrangeDUB's Avatar
    Sep 18th, 2006
    VAG in my pocket
    08-10-2012 10:22 PM #134
    Quote Originally Posted by marcabrams View Post
    The bottom is your fuel input. The upper 2 nipples that are between the carb pairs are your guel overflow/return, and the main big upper nipple in the center by the throttle cable attachment is a breather for the main venturi vacuum chambers, and that needs to breathe to atmospheric.
  30. Member yeayeayea's Avatar
    May 29th, 2005
    md
    08-25-2012 12:08 PM #135
    Soon
  31. Member scirocconaut's Avatar
    Oct 7th, 2011
    Dallas/pdx
    1979 16v mk1 scirocco S model black with roof rack and no sunroof :)
    08-30-2012 07:05 AM #136
    I would like to convert, wish I hadnt sold
    My hayabusa carbs
  32. Member yeayeayea's Avatar
    May 29th, 2005
    md
    08-31-2012 05:15 PM #137
    I wouldnt mind stepping up to some carbs with a larger Throttle plate diameter. the cbr900 carbs are 38mm, i think R1 carbs are 40. Do you know how big the busa carbs are?
  33. Member OrangeDUB's Avatar
    Sep 18th, 2006
    VAG in my pocket
    09-01-2012 02:35 PM #138
    Ever since I put carbs on my rabbit, I have since questioned why I didn't get hold of a digifant ECU with wiring and some injected motorcycle throttle bodies...
  34. Member yeayeayea's Avatar
    May 29th, 2005
    md
    09-09-2012 09:29 PM #139
    Quote Originally Posted by OrangeDUB View Post
    Well the carbs are a lot cheaper and simpler than going through all that hassle. But Fuel injected ITB's have a higher power potential if done right.
  35. Member yeayeayea's Avatar
    May 29th, 2005
    md
    09-20-2012 12:45 AM #140
    Say what!?
