Results 1 to 28 of 28
Thread: has anyone disabled their WOT switch with C2 software
  1. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    10-06-2010 07:13 PM #1
    I know it may sound odd, but my car makes significantly more HP when running off the O2 sensor than it does on the WOT closed loop.
    if i were to be able to disable the WOT switch or whatever it would be called, i think its possible that I could make more power.
    i do not run LEAN when running in the open loop so it shouldnt be a safety concern.
    anyone have thoughts?
    Thanks
  2. Member BoostedDubVR6T420's Avatar
    Dec 4th, 2009
    Detroilet, Michigan
    98' GTI VR6-T 98' GTI VR6
    10-06-2010 07:27 PM #2
    Do you have a dyno saying that it has made more power, or are you feeling that you have more power?
    98' GTI VR6-T | Stock Block and head, ARP Hardware, C2 Stg.2 Software, 9:1 Comp., 22 psi high boost, (NEW)Precision HP6765, Schimmel Performance SR, ATP Mani., TIAL WG, 3" SS Turbo Back exhaust and DP, Custom IC Piping, Greddy 3" IC and Type S BOV, MSD Coils, NGK BKR7E-11 (Gap .035), BFI stg.2 mounts, Preloquin LSD, Dual Stg. BC, LM-2 Wideband, FK Coils, Upgraded Suspension
  3. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    10-06-2010 07:56 PM #3
    i have a dyno that shows it. i will try to find it, but i think its on my other computer.
    if i can keep the AFRs around 11-12 it makes great power (for 30# injectors)
    but if i bury the throttle, it drops down to like 10 or less AFR and it makes less HP.
  4. Member KubotaPowered's Avatar
    Jan 27th, 2005
    Tucson, AZ
    2006 Subaru WRX
    10-06-2010 07:57 PM #4
    I forget how these sensors work, if the voltage increases based on throttle angle or decreases. If the voltage increases, you would need to put a resistor in the signal out line of the TPS sensor so that the ECU never sees maximum voltage.
    Quote Originally Posted by ..Derek.. View Post
    Clearly you aren't familiar with the "Golden Corrado". It's so clinically clean that in the event that you must urinate it must be done at least one zip code away in fear that it may catch a staph infection.
    Tucson Forced Induction
  5. Member sp_golf's Avatar
    Nov 28th, 2007
    Toronto
    88 Golf 16vT
    10-06-2010 10:11 PM #5
    OBD1 TPS is at 4.9-4.96v @ WOT, I think 4.5v should do the trick.
    Message me for tuning solutions.
  6. Member KubotaPowered's Avatar
    Jan 27th, 2005
    Tucson, AZ
    2006 Subaru WRX
    10-07-2010 01:37 AM #6
    It would be an easy trick, you would want a voltage clamp, not a resistor as I previously stated. If a resistor was used, the ECU would see low voltage all across the throttle position. With Vagcom and the engine off, watch the throttle postion and look at what point it goes into full throttle mode. Last step would to be to measure the voltage output just before it goes into full throttle. Now, if this is a good idea or not is the next question but its very feasible.
    Mar 20th, 2010
    Minneapolis
    10-07-2010 02:28 AM #7
    If you know anyone with a chip burner then read the chip file and I will take a look and fix it for you.
    Mar 20th, 2010
    Minneapolis
    10-07-2010 02:28 AM #8
    Quote Originally Posted by TIGninja View Post
    And get your dyno sheet from your WOT run.
  9. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    10-09-2010 01:08 AM #9
    I'm in Nashville for the next few days. I will post my sheet when I get back.
    I did get a pm from a tuner that said the wot switch is in the software and that he could tune it out.
    I'm just not sure that is a smart option yet. Either way my car runs very well. It's hard to mess with it. Hahaha.
  10. Member
    Mar 20th, 2010
    Minneapolis
    10-09-2010 01:37 AM #10
    The tuner that PM you is correct. As soon as you floor it the ecu switches to a different map.If you have a good running map then this is the easiest part of the tune to change.
  11. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    10-19-2010 12:44 AM #11
    so after talking to my brother and a friend of mine, im considering adding a set screw or stop block to my throttle body.
    there is a large flat area where the throttle cable holder stops against the throttle body. if i simply add a set screw to this or a stop block i can keep the car from going into WOT.
    i will NOT get the throttle body to open all the way , but it will be easier to drive the car.
    hopefully i can get to this soon.
    I will report back what i find.
    Dyno day should be Nov 20th. so i hope to have this sorted well before then.
  12. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    10-19-2010 02:01 AM #12
    Quote Originally Posted by jhayesvw View Post
    you need to figure out why its running so pig rich, rather than hiding the problem behind a tbody change.
    whats fuel pressure?
    whats your idle 02 fuel trim?
    whats your maf reading through the rpm range?
    cts reading?
  13. Banned DJ Gonzo's Avatar
    Apr 27th, 2010
    Bear, DE
    99.5 Jetta TDI, 02 GTI VR6, 00 Golf 1.8T
    10-19-2010 08:27 AM #13
    Quote Originally Posted by TBT-Syncro View Post
    cts reading?
    Or you could do this ^
    I would go by fixing this tuning wise but that is just me.
  14. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    10-19-2010 09:18 AM #14
    ive spoken to jeff.
    the 30# tune runs pig rich on WOT.
    thats just the way it is.
    under all conditions but WOT it runs perfect.
    none of my components are an issue.
    therefore disabling WOT is my only option.
  15. Member
    Mar 20th, 2010
    Minneapolis
    10-19-2010 09:47 AM #15
    ive spoken to jeff.
    Just turn the boost up until the fuel mixture is in spec. With the OBD1 you have to tune the full throttle map to fuel by RPM only. This means you have a set amount of fuel being delivered at each RPM interval. you can either change your feling via the full throttle map or add more air to your A/F mixture. Turn up the boost. The chip file was designed for more air then your giving it.
  16. Member pimS's Avatar
    Jan 7th, 2009
    Nearby Amsterdam
    96' VRT
    10-19-2010 03:54 PM #16
    ive spoken to jeff.
    Your only option is to get a 42# tune, runs perfect all the time, higher power potential.
    Your already looking for more power, so why wouldn't you change to the 42#, looks like the best solution to me.
    DCA Facebook
    Build it, Run it, Break it, Fix it, Repeat!
  17. Senior Member TBT-Syncro's Avatar
    Apr 28th, 2001
    Vancouver
    92 VR-T syncro GTI
    10-19-2010 09:04 PM #17
    Quote Originally Posted by pimS View Post
    because there is no c2 42lb obd 1 tune?
  18. Member
    Mar 20th, 2010
    Minneapolis
    10-19-2010 10:23 PM #18
    either turn up the boost or fix the chip file.
  19. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    03-10-2012 05:52 PM #19
    I recently got a Private message about this thread.
    I added a small little set screw to the throttle body
    i no longer hit WOT and the car runs like a champ.
    Jeff said he could sell me a new chip with WOT disabled and would run even better
    than my C2 tune, but I declined as this works great.
    I just thought I would update. Never did hit that dyno day, but the "butt dyno" says it works
    very well.
    if you add the set screw, drill the small hole first, dont just run a screw through the plastic as it could
    break the TB.
  20. Member DubmyRUCA's Avatar
    May 22nd, 2007
    Pittsburgh, PA
    91' VRT GLI... 12' Golf TDI
    03-12-2012 11:40 PM #20
    Jhayesvw, thanks again for the response. In the pic listed below I just glued a piece to the throttle body protrusion(circled in red) that the throttle body spring is sprung from and when the throttle body "stop"(arrowed in red) comes up and is fully engaged it would stop it early. It stops it about 3/16th sooner than WOT before and i'm still running super rich(in the process of VAGCOM'ing the actual TPS readings). You said earlier
    break the TB.
    You mentioning plastic throws me off a little, when i looked at the throttle body I assumed you were talking about the aluminum protrusion(circled in red) but i guess not. Maybe I'm just not stopping it early enough with the 3/16th inch pad i added. If that's the case let me know how much of the travel you cut off. If not could you specify what plastic piece you drilled into to create the "stop."
    ThrottleBody
  21. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    03-13-2012 12:17 AM #21
    Is your TB an obd1?
    Mine is obd2. I will have to look again but I thought mine was plastic on the throttle cable guide.
  22. Member .T.o.n.y.'s Avatar
    Apr 3rd, 2003
    Former user name: 2.Quick
    1997 Candy White Jetta GLS
    03-13-2012 12:48 AM #22
    Couldnt you just adjust the throttle cable? Im sure that would work just fine and work the same way.
  23. Member jhayesvw's Avatar
    Oct 3rd, 2001
    Tucson, AZ
    03 WRX wagon
    03-13-2012 02:24 AM #23
    i dont think so. if you loosen it you'd have slack before the throttle picked up. if you tighten it you'd have a wicked high idle.
  24. Member DubmyRUCA's Avatar
    May 22nd, 2007
    Pittsburgh, PA
    03-13-2012 08:39 AM #24
    Is your TB an obd1?
    Yea I am OBD1, most times that I see this issue its with OBD1 tunes, I guess I assumed you were OBD1 also. Either way, how much earlier is your set screw is stopping it? Mine is set to stop about 3/16th's of an inch early, you think maybe that's just not enough?
  25. Member DubmyRUCA's Avatar
    May 22nd, 2007
    Pittsburgh, PA
    03-14-2012 08:05 AM #25
    Ran a few tests and it appears i'm running super rich when the rpm's climb even when i'm only 75% throttle. Though for sure it was only when i went WOT but i guess not, gonna do a pressure test, might have a boost leak somewhere causing me to run rich. Thanks again
  26. Member CorradoFuhrer's Avatar
    Mar 21st, 2002
    Aalen, Germany
    1997 GTI VR6T DE
    03-23-2012 12:51 PM #26
    ive spoken to jeff.
    I'm having this exact same issue. I'm obd-2 though
    http://advanceautoparts.tellapal.com/a/clk/4G31dh
    40% off Advance Auto Coupon friends and family
  27. Member DubmyRUCA's Avatar
    May 22nd, 2007
    Pittsburgh, PA
    03-23-2012 12:57 PM #27
    Quote Originally Posted by CorradoFuhrer View Post
    The OP is OBDII also
  28. Member Fast VW's Avatar
    Sep 24th, 2002
    Central PA
    S/C 97 8v
    03-24-2012 06:38 PM #28
    So does this apply the the 30# software for the VR6 only or does the 30# software for the ABA run too rich as well?
